Old Aug 03, 2010, 06:33 PM
bristol
Joined Nov 2008
help with graupner flex shafts ?
right i would like to put one of these shafts into my mini mono so do they have at the end of the coupling a flex bit instead of soild ?
http://www.cornwallmodelboats.co.uk/...ex-shafts.html
sorry if i sound dumb just need to know so i have a bit of flex beacues i dnot think motor will go low enough also i thought they were cheap ? are they worth it ?
cheers alex
taffy047 is offline Find More Posts by taffy047
Old Aug 03, 2010, 07:46 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
The picture is small but it says: "Stainless Steel Shaft with Nickle Plated Brass Tube and Brass Bushings."
I would take that as being a solid shaft.
Graupner makes flex couplers, dont know what size you need... http://www.offshoreelectrics.com/pro...?prod=grp-3344
scorpion1 is offline Find More Posts by scorpion1
Old Aug 04, 2010, 02:10 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Alex,
These shafts are designed for scale boats with slow revving motors, hence the brass bushings.
If you use a flex coupler and put stress on the inside bushing, it'll wear relatively fast and will start to rattle and leak.
If you only run the boat every once and a while that's no problem, 'heavy' use will result in the above situation.
I'd rather go for a 'real' flexshaft and strut/stinger in that case.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Aug 04, 2010, 02:23 AM
nick 30
nick30head's Avatar
Joined May 2009
i agree with scorpion and jan, could use a solid shaft with flex coupler or buy a complete flex shaft, go with the flexi shaft, its cheaper
nick30head is offline Find More Posts by nick30head
Discussion Help with Graupner Ultramat 12 Charger FlyingKiwi22 Batteries and Chargers 0 May 22, 2010 08:47 AM
Discussion Flex shafts hammer nitro zen3 Racing Boats - Internal Combustion 0 Oct 20, 2009 10:15 AM
Discussion flex cable shafts ericthetree Dock Talk 1 Jun 27, 2007 07:02 PM
Soldering flex shafts slip knot Racing Boats - Internal Combustion 1 Jul 12, 2004 06:11 PM
