Old Aug 03, 2010, 05:32 PM
5zigendes is offline
Find More Posts by 5zigendes
anaheim, ca
Joined Nov 2003
Help!
Need your advice in selecting new 3d plane
Hi,
I've been flying mostly foamy 3d for a while now.
I'm ready to fly balsa 3d planes now,
Can you recommend a 3d wood/balsa plane that's built stronger than other kits?
Here's what I found so far:
Precision Aerobatics: Mini Katana
AJ Slick
Looking for 30-40" wingspan. Thanks a bunch!
5zigendes is offline Find More Posts by 5zigendes
Old Aug 03, 2010, 05:34 PM
thomer is offline
Find More Posts by thomer
Off roading with the Fun Cub!
thomer's Avatar
CA
Joined Mar 2003
Here is your plane right here:
http://www.3dhobbyshop.com/detail.aspx?ID=2684
thomer is offline Find More Posts by thomer
Old Aug 03, 2010, 05:39 PM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
Skip the PA Katana Mini as various reports suggest it's not for balsa beginners. Take a look at the 41' Edge in the link above and compare it to the 42' AJ Slick. Either of those planes should suit your needs very well but there is a big price difference between them so the 41' Edge is a safer bet as a first balsa plane in case you totally trash it and need to buy another plane :O. The 41' Edge also has nice "foamy-like" wire landing gear to cope better with less than perfect landings.
groovejet is offline Find More Posts by groovejet
Old Aug 03, 2010, 05:48 PM
thomer is offline
thomer's Avatar
CA
Joined Mar 2003
And the 41" Edge was designed with pilots in mind making the transition from foamies to balsa.
Plus, there are 15 build videos you can watch on the website, so that will put all of your fears of assembling a balsa plane to rest. Not that it takes that long to assemble, but the build videos are extremely comprehensive and very detailed.
Old Aug 03, 2010, 05:53 PM
anaheim, ca
Joined Nov 2003
Wow thanks for your quick response.
The reason why I was considering PA was because they use a lot of carbon. I thought carbon makes it more durable.
Old Aug 03, 2010, 06:01 PM
GPT is offline
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
I didn't find them any more durable than 3DHS planes, if anything probably less durable overall than 3DHS.
GPT is offline Find More Posts by GPT
Old Aug 03, 2010, 06:06 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Got two more videos cookiog now.
Doc Austin is online now Find More Posts by Doc Austin
Old Aug 03, 2010, 11:17 PM
Elixir220 is offline
Find More Posts by Elixir220
Ku-Meeeeeeeeezzzzzz
Elixir220's Avatar
central tx
Joined Apr 2009
5Z
the owner of 3DHS is alot more visible and is willing to go beyond the sale to ensure you are a happy customer. if you do your homework on these threads you'll see this is a true statement. question, what foamie have you been flying 3d with?
Elixir220 is offline Find More Posts by Elixir220
Old Aug 03, 2010, 11:41 PM
anaheim, ca
Joined Nov 2003
I've flow various types of foamies. Grayson hobby Yak, Blade 3d, Revolution 3d.
I actually have a Fliton Edge Mini that I fly too (it's balsa), which I enjoy very much.
Sounds like Slick is very popular.
Old Aug 04, 2010, 02:08 AM
crackup007 is offline
Find More Posts by crackup007
Israel Montoya
crackup007's Avatar
Joined Jan 2007
PA Addiction 3D, the best!
Check this!
Precision Aerobatics ADDICTION! (2 min 54 sec)
PA Addiction 3D by Aerofun (3 min 33 sec)
The RC Mafia Wars (15 min 20 sec)
The RC Oasis (10 min 46 sec)
crackup007 is offline Find More Posts by crackup007
Old Aug 04, 2010, 07:49 AM
Kachu is offline
Find More Posts by Kachu
USA, TX, Katy
Joined Mar 2009
Carbon is very ridgid and reduces weight. Wire gear, properly designed as Ben has done, is insanely strong and will bend rather than break. If you want durability the wire gear on the 41 edge is unbeatable.
At $12~15 for a bad landing do you want CF landing gear on your first balsa?
Kachu is offline Find More Posts by Kachu
Old Aug 04, 2010, 08:01 AM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
PM ipsmotors as he lives in your hood and will let you test drive the 3DHS line up.
blakevan is offline Find More Posts by blakevan
Old Aug 04, 2010, 08:19 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Yes ....the new 3dhs 41" edge would be my first choice. $99...just cant be beat for a plane of this quality ANYWHERE.
GoldCraft is offline Find More Posts by GoldCraft
Old Aug 04, 2010, 08:25 AM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
I have to agree. The 41" Edge is an amazing "bang for the buck". At $99, I just don't think you're going to find anything close in terms of quality and design. On top of that, you'll get top notch support from the 3dhs crew. There's a great set of build videos, too.
6L6Amp is offline Find More Posts by 6L6Amp
Old Aug 04, 2010, 08:49 AM
Ku-Meeeeeeeeezzzzzz
Elixir220's Avatar
central tx
Joined Apr 2009
5Z
my only concern was you going from a foamie which you harrier land to a plane that you actually need skills to land (any balsa built up plane) since you already fly a fliton edge...ohhhh yeeeaaahhh go get either the 99 buck huck(EDGE) or 42 in Slick.
Help! Need advice selecting a plane to build potshot Foamies (Scratchbuilt) 15 Mar 03, 2010 06:47 PM
Discussion Advice on selecting a new plane Blackhawk217 Fuel Plane Talk 15 Jan 16, 2010 12:50 AM
I need advice for the right Outrunner on a new 3D plane... Argyle Power Systems 15 Nov 26, 2005 10:18 AM
Need Advice on Selecting a Plane - considering a Sunracer Dynomike High Performance 24 Dec 17, 2004 09:57 AM
Need advice selecting first fullhouse plane. fogflyer Parkflyers 24 Mar 17, 2003 04:29 PM
