This thread is privately moderated by kinderkram, who may elect to delete unwanted replies.
Old Sep 04, 2011, 01:37 AM
worms is offline
Find More Posts by worms
Romania
Joined Mar 2010
I have much better results with FMP04. with 2.0.39 I have seven satellites in 2 sec and 30 sec are 12 satellites. version v1.4, I will try and v1.6.
worms is offline Find More Posts by worms
Old Sep 04, 2011, 03:48 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Originally Posted by DaniSaez View Post
I love it Matt!!! congratulations!
I like very much the KISS principle! Keep It Simple & Stupid ;-)
Well done
Dani
Thanks Dani
OK, test flowen this morning, better PID settings
Does anyone want the mix file ?
matwelli is offline Find More Posts by matwelli
Old Sep 04, 2011, 03:58 AM
helicoblast is offline
Find More Posts by helicoblast
Geneva, Switzerland
Joined Jan 2009
Great work Matt!
I would love to get your mix files!
Any chance to see a video with your new PIDs?
Bastien
helicoblast is offline Find More Posts by helicoblast
Old Sep 04, 2011, 05:46 AM
robert b is offline
Find More Posts by robert b
Switzerland, Aargau
Joined Mar 2011
Originally Posted by matwelli View Post
Thanks Dani
yes, if you are willing to share your mixer code - that would be great.
also you experience generating the mixing relationships.
robert
robert b is offline Find More Posts by robert b
Old Sep 05, 2011, 08:50 AM
drmgcm is offline
Find More Posts by drmgcm
drmgcm's Avatar
Cayman Islands, Grand Cayman, Patricks Island
Joined Nov 2005
Originally Posted by xchurchx View Post
Hi,
I haven't read back, but have you verified your back left prop is balanced?
Just to let you know, i sourced the problem for this excessive trim issue, it happened to be one of my ESC's had a different firmware version to the other three. They were all identical ESC's so i thought, but it turned out one of them was running a different firmware to the others, this was causing the excessive trim issue.
Changed them all out and the problem has gone away
drmgcm is offline Find More Posts by drmgcm
Old Sep 05, 2011, 11:12 AM
Thunderbirddimka is offline
Find More Posts by Thunderbirddimka
Joined Nov 2010
Hello Forum!
my English is translated by Google so do not be surprised!
I've since May of this year I built a Hexakopter with ArdupilotMega, the software is transferred to AMP Planner! it all works. 3 steps on the switch, I Stablemode, Baro, GPS!
that works too! 'm in the air! and there is 2 problems, the first in Stablemode I must talk to Roll and, vobei the radio setup performs korreckt is (min which values ​​and maximum reach I have to because that is nowhere where 1000 - 2000) and how do I fix it ? by Subtrimm?
Problem No. 2 is even worse, I do not know how I can prevent the rocking of the copter, as in Stablemode only P and I values ​​are not a D on this problem for months I'm going right now I have P = 4, 5 and I = 0.06
When I look at the videos on the net as the boards are the copter in the air, what am I doing wrong?
Help?
greeting
Dimi
Thunderbirddimka is offline Find More Posts by Thunderbirddimka
Old Sep 06, 2011, 12:54 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
How did you figure out the firmware version? Nice debugging work!
marhar is offline Find More Posts by marhar
Old Sep 06, 2011, 03:38 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Crop Circles
Ok, help please guys - this happened with the NG code and with the 2.039 code
Quadcopter, Running an APM with Magnetometer and GPS
in loiter/position hold it ends up doing big, fast CCW circles
what could be the cause ? im suspecting the magnetometer is getting thrown out by the magnetic field from the powerwires, maybe 20-30 deg, so the quad is correcting in the wrong direction
Thoughts ?
Old Sep 06, 2011, 03:53 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Vtail Octo custom mix
Ok , i modified a Y6 mix, as it required not alot of work
first, define how much "authority" pitch and roll corrections have
my mix has them at 100%, but in some cases you may want less
int roll_out = g.rc_1.pwm_out;
int pitch_out = g.rc_2.pwm_out;
if i wanted for example to have pitch to have 80% authority the code would look like this
int pitch_out = g.rc_2.pwm_out * .8 ;
second step is decide what motors will run from what channel
for me channel 1 = front motor pair, channel 2 = left motor pair, channel 3 = right motor pair, channel 4 = right rear motor(CW yaw) and channel 7= left rear motor (CCW yaw), channels 5 and 6 are skipped as they are used for camera control
Now the mixes
in my example i have the front motors responding to throttle and pitch only, so the code looks like this
motor_out[CH_1] = g.rc_3.radio_out + pitch_out;
the left two motors are throttle and Roll only
motor_out[CH_2] = g.rc_3.radio_out + roll_out;
the right two motors are throttle and roll also, but this time you need to correct for roll in the other direction, so we put a negative sign in front of the roll term
motor_out[CH_3] = g.rc_3.radio_out - roll_out;
Ok, almost there
the rear motors, individually controlled, take care of throttle, pitch (- this time) and Yaw
first - for throttle and pitch
motor_out[CH_7] = g.rc_3.radio_out - pitch_out;
motor_out[CH_4] = g.rc_3.radio_out - pitch_out;
and now for yaw
motor_out[CH_4] -= g.rc_4.pwm_out;
motor_out[CH_7] += g.rc_4.pwm_out;
hope the above makes sense, remeber this isnt my work, i just bodged it around
Old Sep 06, 2011, 11:03 AM
isojed is offline
Find More Posts by isojed
Netherlands, ZH, Ridderkerk
Joined Aug 2010
The below makes sense to me. Thank you for taking the time to write it all up!
Is there an (scientific) reason behind the 45 degrees angle of the tale motors other than looking really cool?
Now the mixes
Ok, almost there
and now for yaw
isojed is offline Find More Posts by isojed
Old Sep 06, 2011, 01:10 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
the rear angle is not quite 45, closer to 35, its a compromise between lift and yaw control, if the angle was less, it would take more thrust for yaw, which would start to induce some roll, if it was more, you would start losing alot of lift, as it is its calculated that the rear motors are down about 15% on thrust
but looking cool is also a worthy design spec
Old Sep 06, 2011, 04:45 PM
Geneva, Switzerland
Joined Jan 2009
Hi Matt,
Thanks for your explanations, it also make sense for me.
I hope to find enough time to build a new frame and test your code soon, I really like the idea and it seems to be a nice AP/AV platform.
Thank you!
Regards,
Bastien
Old Sep 07, 2011, 03:30 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Thanks Bastion
personally if you dont need 8 motors, i would build the Y6 Vtail, 6 motors and alot lighter, if you do, i will write the code (it only needs 4 channels and flies like a tricopter)
Old Sep 07, 2011, 02:00 PM
Geneva, Switzerland
Joined Jan 2009
Hi Matt,
I was exactly thinking on building an Y6 Vtail, so if you can write the code, it would be really helpful... Thanks for your offer!
Old Sep 07, 2011, 03:05 PM
isojed is offline
Joined Aug 2010
Thanks (again) Matt.
I am gonna build me a Y6 Vtail too.
Build Log What to Build??? O What to Build????? helidude2 Micro EDF Jets and Power Systems 10 Jul 10, 2014 10:14 AM
Discussion ArduCopter Project Update km28104 Multirotor Talk 176 Apr 18, 2011 11:56 AM
Poll Tamiya Wild One- To build or not to build? peacekeeper94 Off-road Cars 11 May 29, 2010 05:05 AM
Discussion Build Log: Monogram "build'n fly" DHC-2 Beaver lw_hughes Scratchbuilt Indoor and Micro Models 9 Nov 17, 2009 08:01 PM
Question AMD Phoenix (Wingeron) Build Questions, Build, and Pics Greygoosegregg Slope 82 Sep 11, 2009 04:40 PM
