Old Aug 01, 2010, 11:42 AM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
Does anyone have any info about this rowboat?
Hi folks.. been goofing off in the beer mines again, and this caught my interest
a little R/C rowboat!
The Remote Control Pirate Rowing Boat! (1 min 8 sec)
thing is, I can't really find that much information about it, other than it apparently uses four servos to control the movement, and that movement can either be controlled by clever servo mixing or a special control board made by some guy in Germany.
I also believe the servos are rebuilt for continues rotation.
I figure that if anyone knows more about it, then it would be you guys
bgnome is offline Find More Posts by bgnome
Old Aug 01, 2010, 12:29 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Looks like it may be an old Graupner Tina or maybe a bit of a variation on the indian paddlers..
http://www.th-privat.de/mbau/graupner-tina.html
http://www.rcuniverse.com/forum/m_59.../anchor/tm.htm
http://www.rcgroups.com/forums/showthread.php?t=1239159
_________________________________________
There were also these paddlers, first posted by Kmot in 2008...
http://www.rcmovie.de/view_video.php...9f55a43db2ce04
A bunch of links were posted on the second page here.
http://www.rcgroups.com/forums/showt...indians&page=2
Viking ships at Bellevue Regatta
RC Viking Ship @ Bellevue Regatta (1 min 23 sec)
Another Viking ship
RC Viking Ship @ Toronto Hobby Show 11B4 (5 min 10 sec)
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Aug 01, 2010, 01:36 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
I was fascinated watching the first video above... plenty of servos and linkages to get me all excited, sure... but note the syncronization of the oars after a turn! If they were independent, they'd get out of sync and the boat would wobble along like a pollywog... left right, left right... but they don't.
How'd he do that?
patmat2350 is offline Find More Posts by patmat2350
Old Aug 01, 2010, 01:48 PM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
thanks Umi!
though most of the links on that one thread were dead, I eventually found this:
grampas rowboat internals
from what I can tell whats going on is that you have the back servos pushing the oar forwad and backwards, and another lifting the oar up and down with a Adriano (sp) chip co-ordinating the movement. The doll's just along for the ride
I'm actually pretty sure if thats the case theres probably a program for the chip lying around some where on the web.
Old Aug 02, 2010, 10:18 AM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
If it runs like the Tina, there is a common eccentric drive that runs both oars at the same pace and in sync. Another mechanism modifies the arc of one oar.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Aug 02, 2010, 11:20 AM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
thanks dave, I figured the Tina Mechanism used some type of clutch. Its a shame they're so hard to come by nowadays.
looks like the more modern ones uses servos and a programmable mixer. from the pages I found it looks like an arduino chip with a custom program on it.
Old Aug 02, 2010, 12:20 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
So the servos may not be modified at all.
You could achieve the same rowing and sycnronization by
constantly rolling your joysticks around the gimble arc.
The Arduino takes over that function and probably allows the
rowing action to take place using two channels.
Old Aug 02, 2010, 12:53 PM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
nope.. no need to, and would be counter productive i would believe... the servo modification.. removing the stop.. was to turn the servo into a continuous movement geared motor for a more... clock work approach I saw in another description...
this method looks the most elegant and versatile. just like you said, two channel operation. the arduino takes the X,Y and translates it to the gimble action you described.
the chips are cheap and easy to work with, just gotta figure out the programming. the chip also has the ability to take the encoder data from the servos to synch everything back up.
Old Aug 02, 2010, 01:36 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
About 15 or so years ago, a former member of our club scratchbuilt a rowboat that worked rather well. I think he used a single modified servo to operate the oars, and another to turn a rudder. Simple, but impressive---.
der kapitan is offline Find More Posts by der kapitan
Old Aug 04, 2010, 05:36 PM
Nederlander is offline
Find More Posts by Nederlander
Joined Feb 2009
I remember the transmission in Jim McCouls Viking ship well. Pat M. may have a picture of it. Jim used a separate timing belt pulley for each oarsmen that rotated the respective oar in a circular motion. His biggest problem was coordination of the two sides which were independent of each other. Typical automatic transmission engineer; about 40 pulley wheels and just as many belts, lol.
Nederlander is offline Find More Posts by Nederlander
Old Aug 04, 2010, 11:54 PM
CaptLee is offline
Find More Posts by CaptLee
United States, CA, Hayward
Joined Feb 2006
This Is a setup that was in the next to last month's Marine Model International and there was a link to the maker. He is doing a beta test of the mixer unit and I want one. Will see if I can Liberate my issue from the Boat Mafia at the Lake and include it here.
CaptLee is offline Find More Posts by CaptLee
Old Aug 05, 2010, 12:26 AM
lulu86 is offline
Find More Posts by lulu86
goole east riding yorkshire
Joined May 2010
there been an article not so long ago in the mag. marine modelling hers some of the pics. lulu
lulu86 is offline Find More Posts by lulu86
Old Aug 05, 2010, 12:08 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
The servo gear stop may be removed, but they are not continuous rotation servos.
1. The potentiometer giving feed back to the Arduino board are not able to rotate continuously.
2. The linkages are not designed to pass the center of rotation.
Old Aug 05, 2010, 04:10 PM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
Never having seen a video of the servo's in action, I don't think they need to travel more than 45 degrees. Well maybe 90. I would think dead rest stick would have the oars ot of the water
Old Sep 11, 2010, 06:21 AM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
What issue of Marine Model Int'l was that??
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Discussion does anyone have any experience with this motor? veggieslinger Rock Crawlers 4 Mar 20, 2010 10:17 PM
Discussion Anyone have info about this plane? Kadet RC-31 vwchappy Beginner Training Area (Fuel) 1 Oct 12, 2009 05:52 PM
Discussion Does anyone have any info on this? haz 3D Flying 1 Sep 27, 2006 09:05 PM
Does anyone have any info about these motors? hate Power Systems 1 Aug 06, 2005 03:57 PM
Discussion Does anyone have any info about these new Lipo packs? Aobid Batteries and Chargers 11 Oct 07, 2003 07:43 AM
