Old Aug 01, 2010, 06:26 AM
Big_Mac is offline
Find More Posts by Big_Mac
Big_Mac's Avatar
Netherlands
Joined Jul 2007
Helicopter set-up sheet
I have developed a setup sheet that allows you to fill out all of the most important parameters that you can setup on a helicopter.
The form is a Adobe Acrobat PDF file that you can download from my site once you have downloaded it you can fill in the information of your particular helicopter and when you are done you can save or print the set-up sheet.
I was used to using set-up sheets from the time is raced 1:8 scale nitro buggies. And found it to be a simple way to get a set-up history build up that lets you look back on previous set-ups that you used. A second benefit of these sheets is that you can very easily share your setup with other pilots. Also when you have a problem and you want to ask for help on a forum people usually want to know what your set-up as so they can help you better to find a solution, now you can attach your set-up file to your post and people can see what set-up you are using in a very easy way.
I only made the set-up sheet for a electric helicopter because that's what i fly and that's what i'm familiar with. A gas version will follow as soon as i have the proper information for it.
The use of the sheet has no limitations other then that it may not be altered or used commercially unless i give the o.k. to use it. I expect that there will be things that i left out and that one of you would liked to have in the form, i will collect any remarks and decide based on those if i will ad or change something to the sheet(s).
I have attached a blank sheet and a sheet that i put information in from a flight with my Swift.
Well see what you think and try it out if you want.
-Hans
Big_Mac is offline Find More Posts by Big_Mac
Last edited by Big_Mac; Aug 10, 2010 at 01:25 PM. Reason: Attached new PDF files v1_1
Old Aug 01, 2010, 01:30 PM
cajun rx8 is offline
Find More Posts by cajun rx8
I luv Doritos on a Stick!
cajun rx8's Avatar
Da swamps of La!!!
Joined Nov 2009
Thanks Bro, that is really a cool thing to have. I love someone thinking outside the box.
cajun rx8 is offline Find More Posts by cajun rx8
Old Aug 01, 2010, 03:51 PM
Big_Mac is offline
Big_Mac's Avatar
Netherlands
Joined Jul 2007
Thanks man i hope you like using it!
Old Aug 01, 2010, 06:38 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
Hans,
Great job, I like the idea of the heli schematic diagram in the spread sheet.
Another idea would be, is to have a spread sheet for tracking and logging battery statistics for each battery the flyer has.
Example:
Date Purchased
Manufacture
Number of cells (3s,4s,5s etc)
Milliamp Rating
C Rating
Size of battery in mm (optional)
Number of flights used
Number of mAh's used for that flight
Flight time for that session
Heli / Plank used on
And anything else yourself/someone comes up with.
Dave
choppersrule is offline Find More Posts by choppersrule
Old Aug 02, 2010, 09:45 AM
Big_Mac is offline
Big_Mac's Avatar
Netherlands
Joined Jul 2007
That would be a nice thing to have, i think a spreadsheet would be the best choice for this. First a few fields with general data regarding the battery and than a top line with measured parameters than you could make an entry on every line below that.
You would have to mark the packs like you did in the picture to keep good track of them.
I'll see what i can come up with.
-Hans
Old Aug 06, 2010, 09:09 PM
bigW is offline
Find More Posts by bigW
heli mad
North Bondi, NSW,
Joined Jul 2006
Nice Work MAC,
angels is misspelt ..... Do You mean ANGLES
Big W
bigW is offline Find More Posts by bigW
Old Aug 06, 2010, 09:24 PM
Cici528 is offline
Find More Posts by Cici528
Joined Jul 2009
what?
Cici528 is offline Find More Posts by Cici528
Old Aug 06, 2010, 09:27 PM
Got Helis
Joined Mar 2010
Originally Posted by bigW View Post
Nice Work MAC,
Big W
I'm sure he means "Angles". I wasn't aware that this was a spelling contest.
It's all about sharing information and ideas, Mac is doing great.
Did I sepll eevverythnig rghit? Thousands of errors out there, who cares? It's something in my life that WON'T make a difference.
BTW, angels isn't misspelt. Angels are messengers of God. And right now we need them.
Dave
Old Aug 06, 2010, 09:58 PM
desertdweller is offline
Find More Posts by desertdweller
LOOK MOM! TEN THUMBS!
desertdweller's Avatar
USA, AZ, Mesa
Joined Aug 2009
That's awesome Mac!
Thanks for sharing.
desertdweller is offline Find More Posts by desertdweller
Old Aug 07, 2010, 01:19 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I don't like the setup on that heli... the receiver is too close to the motor...
Really though, this is a great idea. I like the box for the radio setup, but you might want to add the actual settings - the servo reversing and swash mixing, and the name of the radio used.
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 07, 2010, 01:59 PM
Big_Mac is offline
Big_Mac's Avatar
Netherlands
Joined Jul 2007
Yep i mean angles, thanks for pointing out my typo i will correct it next time i edit the form, thanks for the tip!
I also agree with you choppersrule we do need some angles every know and then.
I to wanted to do more radio setup but was a little out of room for it, maybe i should make room for a few important setting like the ones you mentioned servo reversing and swash mix i will browse my radio and see what i come up with. As for the name of radio used there is already room for that in the radio section.
Old Aug 07, 2010, 02:06 PM
USA, AZ, Mesa
Joined Aug 2009
Or another sheet specifically for radio settings.
Old Aug 07, 2010, 02:15 PM
Big_Mac is offline
Big_Mac's Avatar
Netherlands
Joined Jul 2007
I could make the form stretch out over two pages, one for heli setup and one for the radio set-up.
Old Aug 07, 2010, 02:21 PM
USA, AZ, Mesa
Joined Aug 2009
Better for my old eyes too!
Old Aug 07, 2010, 02:39 PM
Got Helis
Joined Mar 2010
I agree, getting old sucks.
Help! Set Up Sheet RC 18T AE Factory Team Kit? rbbaby Micro Cars 0 Jan 15, 2010 06:52 PM
Discussion Set Up Sheet 1/8 Venom GPV-1 621clay Motorcycles 1 Dec 30, 2009 04:51 PM
Discussion anyone has ta02 set-up sheet/hop-ups? karlo Electric Power Cars 4 Aug 20, 2007 05:52 PM
Discussion Baudis Banana set up sheet, anyone? HCDLC Slope 2 Jan 16, 2007 10:09 PM
