This thread is privately moderated by Lafayette, who may elect to delete unwanted replies.
Old Aug 01, 2010, 12:21 AM
Lafayette is offline
Find More Posts by Lafayette
'scuse me while I kiss the sky
Lafayette's Avatar
Joined Nov 2009
Build Log
My new AP plane design! The "SeeBee"
"The SeeBee amphibious AP plane" by Lafayette.
Build for the Gopro.
PART #7 POSTED JAN 8 2011click this link!
At this stage, part 6, The aircraft will carry the weight of a DLSR or small camcoder. The fuse and float were tested in water with 40 ounces of weight, no problem. My goal was to carry 2 cameras to shoot video and still pics at one time.
Build log posted here:
Info On building the Hot Wire Router, as well as the gravity hot wire cutting table.
You can build both of them in 3 to 4 hours.
Construction pics and videos posted and updated as work progresses.
Check it out!
Lafayette
http://www.rcgroups.com/forums/showt...8#post15679349
Part #7 now Posted.
Lafayette is offline Find More Posts by Lafayette
Old Aug 02, 2010, 08:26 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Salut M.Lafayette !
interessant ton blog !
tu demeure dans quel coins ?
interessant tes liens et video sur avion pleine grandeur
electric et le planneur !
je me suis payer une balade en France l'automne passé et
j'ai addoré :
Mont Blanc avec AIRMONIE et le planeur STEMME (10 min 11 sec)
Je participe a un tournage sur la conception d'avion dédier
a la photographie aérienne... voir le sujet:
http://www.rcgroups.com/forums/showthread.php?t=1228091
je vais suivre le montage de ton prototype flotteur !
salutation
GGTRONIC = Yves Auger
ggtronic is offline Find More Posts by ggtronic
Old Aug 02, 2010, 02:07 PM
Lafayette's Avatar
Joined Nov 2009
Yves,
Le Mont Blanc.
Je passais tous mes hivers e etes a Abondance, pres de chatel depuis que j'avais 9 mois!
Le coin est magnifique, le reblochon, la tomme le morbier le jambon fume....Haaaaaa.
Je reside en Caroline du Nord.
Ca fait plaisir de communiquer en Francais,
Merci,
Lafayette.
Old Dec 09, 2010, 10:16 PM
Lafayette's Avatar
Joined Nov 2009
Resuming the build after family matters took over the last few months...
Pics posted soon.
Old Dec 16, 2010, 09:08 AM
Lafayette's Avatar
Joined Nov 2009
Well,
Modified the elevator to full stab, 2 engine pods for different payloads, one is a 2409-18 the other is a C3542-1100.
Flaperons almost full wingspan.
Having a wing so much wider than scale put the CG way back.
It will balance well with the 2409 and gopro in the case, with 2200 3S in the nose. With the 3542-1100 and the go pro, 2 2200 3s in the nose. Only one when using a heavier dlsr or video camcoder.
The last thing is to add the removeable landing gear, and mid wing floats.
The wing to tail has a short ARM and hopefully it will not be to squirly!
Maiden coming soon.
Ice storm last night!
Build pics and video will be posted soon, as well as a maiden with gopro on board, and TR 800 helmet cam!!! Should be interesting!!!
Old Jan 08, 2011, 01:16 PM
Lafayette's Avatar
Joined Nov 2009
Update video.
Here is the part #7 of the build.
Part #7Scratchbuilt "SeeBee" amphibious AP RC plane for GOpro HD and dslr. (5 min 48 sec)
Build Log Introducing the "SeeBee" amphibious AP platform Lafayette Aerial Photography 25 Jan 09, 2011 08:44 PM
Discussion My 1st AP pics w/ my 1st AP plane Matt Gunn Aerial Photography 15 Apr 05, 2010 12:13 AM
Question my design AP plane dose it need poly? rumplestilskin Aerial Photography 6 Nov 21, 2006 04:34 PM
My new AP plane design that works (My 1st AP flight!) mrbisset Aerial Photography 6 Sep 10, 2005 10:18 AM
Here's The New AP Plane I'm Building...Would like Some Opinions On Wing Design Randy Due Aerial Photography 68 Feb 23, 2004 02:38 PM
