This thread is privately moderated by Heli Hacker, who may elect to delete unwanted replies.
Old Jul 31, 2010, 03:15 PM
Heli Hacker is offline
Find More Posts by Heli Hacker
Hang on, turbulence ahead
Heli Hacker's Avatar
St. Louis
Joined Dec 2007
Heat-Shrink covering
With clear heat-shrink wrap, the PhuBar3 is about 7.5 grams. The heat-shrink stuff works best if I cut it larger than needed, then trim it around the connector after shrinking it. This one has an 8-position header on it, instead of having cables soldered directly to it.
Heat-shrink tubing is the clear 54mm material from this ebay seller:
http://stores.ebay.com/TUBING-EXPRESS
Heli Hacker is offline Find More Posts by Heli Hacker
Discussion Elapor and Heat Shrink Covering? dashunde Foamies (Kits) 3 Nov 08, 2009 08:13 PM
WTB heat shrink for covering Lipo's BIGSAPPY Aircraft - Electric - Airplanes (FS/W) 2 Jan 09, 2005 03:16 PM
Covering Undercambered Blades with Heat Shrink nolasco Micro Helis 3 Jan 26, 2004 03:15 AM
Covering Undercambered Blades with Heat Shrink nolasco Micro Helis 0 Jan 23, 2004 11:10 PM
Heat shrink battery covering? wsmalley Batteries and Chargers 3 Aug 14, 2003 09:35 PM
