Old Oct 02, 2001, 12:58 AM
Daren is online now
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
SU-27 Flanker update
Here's the latest status update on Dan and my Flankers. The fan units (Wemo Mini 480s w/Speed 480 Race BB) are installable and the inlet and exhaust ducting has been completed. The other systems (retracts and elevons) were installed before the final sheeting went on and are complete. The rear hatch (where the speed board normally is) allows access to the battery pack (16 - 1100mah AU) and the front hatch allows access to everything else. Now it's on to sanding and finishing.<P>
<img src="http://www.allaboutguppys.com/flanker/flanker01a.jpg" width="800" height="606"><P>
<img src="http://www.allaboutguppys.com/flanker/flanker05a.jpg" width="800" height="294"><P>
<img src="http://www.allaboutguppys.com/flanker/flanker07a.jpg" width="800" height="566">
Daren is online now Find More Posts by Daren
Old Oct 02, 2001, 01:24 AM
p471701
p471701
Guest
n/a Posts
daren: the pic's didnt show up...............gregg
Old Oct 02, 2001, 01:32 AM
Daren is online now
Daren's Avatar
Joined Nov 2000
Better?
Arggh! How about now?
Daren
Old Oct 02, 2001, 01:38 AM
p471701
p471701
Guest
n/a Posts
that's one good looking sukoi! the framing is so impressive it's a shame to cover it up.............gregg
Old Oct 02, 2001, 03:48 AM
avie is offline
Find More Posts by avie
Tel-Aviv,Israel
Joined Apr 2001
congrat on one piece of work !!
one thing, what is the metal in the nose ?
once again,congratulations !!
Avi
avie is offline Find More Posts by avie
Old Oct 02, 2001, 09:05 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Great looking ship guys!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 02, 2001, 09:20 AM
dorysch1 is offline
Find More Posts by dorysch1
Electriaddict
dorysch1's Avatar
Melville Saskatchewan Canada
Joined Mar 2001
the thing in the nose looks like a big Capacitor? But Great looking Jet wow!
dorysch1 is offline Find More Posts by dorysch1
Old Oct 02, 2001, 09:33 AM
Plane Crazy is offline
Find More Posts by Plane Crazy
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
Nope, looks to me like a retract air cylinder in the nose. This thing have retracts??
Can't wait to hear about first flights.
Gordon
Plane Crazy is offline Find More Posts by Plane Crazy
Old Oct 02, 2001, 10:07 AM
Daren is online now
Daren's Avatar
Joined Nov 2000
Air cylinder
Gordon gets the kewpie prize. The air cylinder will be housed in the hollowed-out nose cone (not yet attached).
Gregg:
Thanks for the kind words. Dan's is just as pretty.
Gordon:
Both do have retracts. We are using the Spring-aire 600 series.
To all:
Estimated AUW will be between 4.75-5.25 lbs. Once they're finished, we have a pretty stringent test program planned before the first flights; thrust and tailpipe velocity, then low and high speed taxi tests. Fortunately, we have a rather large paved flying field on which to perform these tests. We'll be posting more pics as the airframes progress.
Daren
Old Oct 02, 2001, 11:03 AM
avie is offline
Tel-Aviv,Israel
Joined Apr 2001
Hi
another question. do the fans deliver enough thrust and power ? it seems quite heavy for the thrust they would provide (400 grams each by wemotec ?)
Avi
Old Oct 02, 2001, 11:22 AM
dorysch1 is offline
Electriaddict
dorysch1's Avatar
Joined Mar 2001
you may want to run brushless motors to get adequate thrust on a small fan no? but I am new at this and relatively lazy to do the math I am getting burned out trying to get mine finished before it snows
Old Oct 02, 2001, 11:58 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally posted by avie
Hi
Avi
Each MF480 will deliver about 14 oz of static thrust on 8 cells. With a weight of about 5pds and an est 10% in ducting losses, static thrust to weight is around 0.31, and Watts per pound around 55.
Herb is offline Find More Posts by Herb
Old Oct 02, 2001, 11:59 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Sweet!
I hope the powerplants will do - power seem low as each fan wont provide more than ~140W in/84W out.
Haldor is offline Find More Posts by Haldor
Old Oct 02, 2001, 12:23 PM
Daren is online now
Daren's Avatar
Joined Nov 2000
Hope so...
Hi
Avi
The WB-57 weighs about the same and flies pretty well on this set up. Granted it has more (lots!) wing area, but also a higher amount of parasite drag. The Flankers' estimated wing loading is approximately 24 oz./sq. ft.
Our own concerns as to whether the power will be enough is why we have the testing planned that we do. If the static thrust and tailpipe velocity look okay, we'll move onto taxi tests. Fortunately, our runway is about 900 ft. of 150 ft. wide asphalt, so there's plenty of room to get slowed down (or land) in case it doesn't look like they'll fly. This is one of the advantages of ROG, you have a much wider go/no go window in which to decide.
Daren
Old Oct 02, 2001, 03:29 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
ssssssswwwWWWWWWEEEEEEEEEEEeeeeEEEEEEEEETTTTTTTTTT TT!!!!!
Ahhhh I just LOVE that thing! Eeeahhhhh Its so cool I just cant take it! (Jason goes into crazed fit, contemplates quiting job and locking himself in a tool shed with a 2 year supply of balsa, tools, supplies and some food )
Ok, Im ok now, that thing is great guys! I love the SU 27, go figure . I also happen to have 2 minifan 480s and 2 race speed 480 bbs, so I am very optimistic (spelled hopefull) about your low cost power config .
Just imagine such a cool scale twin EDF with ROG retracts that could fly with less than $200 worth of power plant,,,,,,,, .
JasonJ is offline Find More Posts by JasonJ
Fanfold Su-27 Flanker - Drawings and Construction Guide Thomas Nelson Foamies (Kits) 419 Jan 10, 2012 11:05 PM
Fanfold Su-27 Flanker Thomas Nelson Electric Ducted Fan Jet Talk 297 May 20, 2004 08:58 AM
Another SU-27 Flanker Ralph A. D'Amelio Foamies (Kits) 39 Mar 29, 2004 10:45 PM
Su.27 Flanker pusher thread from Tom Nelson,free templates bipeflyer Electric Ducted Fan Jet Talk 4 Jan 18, 2004 12:28 PM
Su-27 Flanker for FMS? Thomas Nelson Simulators 7 Oct 31, 2003 01:54 PM
