Old Jul 30, 2010, 11:03 AM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Help!
Best 90mm fan/motor, Recommended Electric Retracts for 90mm Super Sniper???
What is the best 90mm fan/motor combo???....I'm going to install it in a Super Sniper....I do not need the most expensive, just a good RELIABLE setup from Hobby King or whatever...I plan on using 6s for power...
Please tell me your 90mm setup!!!!....(Batteries, fan, motor, etc...)....It doesn't have to be in a Super Sniper and videos are encouraged!!!
Also---I want to install electric retracts...Any recommendations???
TIA!!! Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Jul 30, 2010, 12:05 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Kevin, I am a really happy with my wemotec 90mm fan, it comes dynamically balanced which is nice! I am using an HET motor it is a 600 series I think it’s the 600-37 and I am running a Castle Ice 100, on 7s It puts out 2200 watts and lots of thrust. Max temps I am hitting are about 120-130 degrees in 90 degree weather. This set up is good for 5 min flight times with 5000 mah batteries, maybe longer times but have not had the chance to really experiment yet! I am ok with the Turnigy/ HobbyKing batteries and have had lots of success with them but I wouldn’t do a cheap fan! Even on just 6s you are turning some pretty serious RPM’s and you don’t want that baby coming apart! The Wemotec is not the most advanced fan out there but it is reasonably priced and is a tried and true proven performer!
bri6672 is offline Find More Posts by bri6672
Old Jul 30, 2010, 05:48 PM
Phoenix426 is offline
Find More Posts by Phoenix426
Phoenix426's Avatar
Joined Mar 2009
Wemotec 90mm is awesome.
Stay away from the Turnigy motors. I just burnt one up and it wasn't even running that hard.
ARC & MEGA both make a very fine motor that will perform and last. Not too expensive either.
Turnigy would be fine for batteries and the ESC, just not the motor!
Phoenix426 is offline Find More Posts by Phoenix426
Discussion best motor for a 90mm fan walkingonair69 Foamy EDFs 9 Apr 18, 2010 01:05 PM
Discussion ¿Het Super Sniper 90mm? Ruyman Electric Ducted Fan Jet Talk 4 Mar 05, 2010 10:07 AM
Wanted 90MM Super Sniper J03yT Aircraft - Electric - Jets (FS/W) 1 Dec 19, 2009 04:22 PM
Sold HET SUPER SNIPER 90mm steve morris Aircraft - Electric - Jets (FS/W) 6 Nov 16, 2009 08:56 PM
Sold Yellow 90MM Jet w/ motor, fan, retracts $450.00 gliders Aircraft - Electric - Jets (FS/W) 4 Mar 14, 2009 08:51 PM
