| Thread Tools |
| This thread is privately moderated by bighead93, who may elect to delete unwanted replies. |
The Airfoilz NX Extra 300
Check it out! I am busy building the NX Edge and NX Katana!
This is the info on the Airfoilz NX Extra 300; Wing Span: 40 in (1016mm) Overall Length: 36.3 in (922 mm) Wing Area: 350 sq in (22.4 sq dm) Flying Weight: 19-21 oz (215/241 g) That is a lot of plane for $59.99!! Check out the build thread! http://www.rcgroups.com/forums/showthread.php?t=1080862 Get yours here! http://stores.3dxhobbies.com/-strse-...0NX/Detail.bok |
Latest blog entry: More FPV flying! Checking out a couple...
There you go! |
Depron is really easy to fix...Epp holds up better in a crash but is really flexiable and to me has a sloppy feel in flight. The Airfoilz planes fly like larger balsa planes if that makes sense...very rigid and handle wind awesome! If you are just learning 3-D you will do well with any of the Airfoilz planes...just fly a little higher when trying new stuff!
Joined Feb 2008
My first depron foamie I retired after a year and a half because it looked so beat up. My second foamie is two and a half years old and although beat up I just glue and fly. I broke it in half three times. The elevator has five brakes that are glued and reinforced. The lower front half has had dozens of brakes that I glued and sonetimes spliced in a new lower front area to get rid of multiple old brakes. Still flies great. Flew it this morning four times. Great hover and KE even though the body is not straight anymore. If I straighten it it may not fly as well.
HK--Phils.
Joined Dec 2006
bighead and e-gull,
Thanks a ton for all the tips and info, i think i'm going for this beauty then. Just have to find a nearer(asian) online shop that carries it. Btw, bighead, thanks a lot for the build thread, learnt a lot from there, but still haven't done reading all the pages. |
Matt |
| Thread Tools | |
| Discussion Airfoilz Extra 300 NX | Melnic | 3D Foamies | 58 | Jan 11, 2011 08:58 PM |
| Discussion NEW- Airfoilz The Bipe NX | furyflyer2 | 3D Flying | 18 | May 06, 2010 08:14 AM |
| Discussion Airfoilz Edge NX | Vintauri | 3D Flying | 24 | Apr 13, 2010 11:14 AM |
| Discussion Airfoilz Katana NX | Tubeheadz | 3D Foamies | 25 | Mar 06, 2010 02:34 AM |
| Discussion NEW AirFoilZ YAK-54 NX build | cyoung450 | 3D Foamies | 18 | Mar 04, 2010 07:24 AM |
