Old Jul 29, 2010, 12:29 PM
USA, NY, Jamestown
Joined Jun 2000
Aurora 9- Heli- Swash mix function
I finally figured out why I don't have enough travel on collective (for pitch). The Swash Mix function defaults to 60 %(?) (I don't think I changed this) which is an measure of travel. Dial it up to 80,90,100 and I now have quite a bit more. One problem though I really don't need as much positive collective. Is there a way to adjust this outside of the swash mix? I can't remember if EPA is a servo level function or an eCCPM level function.
Along with the realization above I also realized that this same 60% is also limiting my roll rate (aileron on the swash mix screen).
Why no mention of this functionality in manual?
JoeR is offline Find More Posts by JoeR
Old Sep 11, 2010, 07:31 AM
USA, NY, Jamestown
Joined Jun 2000
bump
Old Sep 14, 2010, 01:09 AM
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
EPA and dual rate would add role rate.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Sep 23, 2010, 11:34 AM
Because I can!
joe1l's Avatar
USA, NJ, Chester
Joined Apr 2010
You must do some serious 3d that 60% does not give enough collective pitch? I actually run mine at 50% and still get plenty. What kind of heli are u setting up?
joe1l is offline Find More Posts by joe1l
Old Sep 24, 2010, 11:14 AM
USA, NY, Jamestown
Joined Jun 2000
Definitely not 3D- I wish. Probably more likely just have stuff set up wrong. But for some reason I can not get full servo movement for negative pitch unless I dial that up. The servo arm movement is very limited compared to their full range.
I have a Trex450 and a Protos that I am currently flying.
Old Sep 24, 2010, 03:12 PM
Joined Aug 2002
Following may assist:
Aurora A9 - Gyro Heading Hold etc set up 450 Heli - a.
Aurora A9 - Gyro set up 450 Heli - b.
Aurora A9 - Helicopter Set Up -Finless Bob's Helifreak Tech Room - Review Tips and how-To Videos
Aurora A9 - Gyro Set-up - How to interpret numbers & modes on screen.
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Discussion Aurora: Trainer / Buddy system Master & Slave function Set-up & Data Transfer A9<>A9. A.T. Hitec/Multiplex USA 51 Oct 31, 2012 02:47 PM
Discussion Aurora 9 Video Walkthough now w/Heli & GLID MikeMayberry Hitec/Multiplex USA 39 Jul 06, 2010 04:56 PM
Question 450 sport swash mix -- new build neilg. Electric Heli Talk 6 Apr 25, 2010 06:08 AM
Discussion Swash mix trex 500 esp P 39 3D Electric Heli Flying 2 Feb 02, 2010 08:52 AM
Discussion Aurora trainer function JoeR Hitec/Multiplex USA 5 Jul 08, 2009 11:53 AM
