Old Jul 29, 2010, 12:21 PM
titantech is offline
Find More Posts by titantech
Joined Jul 2010
Help with dx7 and sabertooth speed controller
I am using the spektrum dx7 and the spektrum ar6100 receiver. The speed controller that I am using is the sabertooth 5 RC. The problem that I am having is that I plugged the flip function of the speed controller into the gear slot on the receiver. But when I flip the gear switch the direction of the motors doesn't flip. The speed controller's manual says that if it gets a signal of 1500uS or higher on the flip channel then it will reversed the motors. So I think that it isn't getting a high enough signal. I have already adjusted the travel all the way out on that channel, but when I tested it with a servo it only rotated about 90 degrees (the servo has a range of 180). So is there a way to get the value up to 1500uS
Thanks in Advance!
titantech is offline Find More Posts by titantech
Help! Brushless speed controller/motor Problem! HELP! con100 Off-road Cars 6 Mar 02, 2010 11:04 AM
Help! Speed controller help captaintomo Power Systems 9 Mar 02, 2010 05:10 AM
Discussion Speed controller help robbstech Electric Power Cars 5 Jan 26, 2010 08:46 PM
Discussion [Hobby Lobby] CRASH Sale SPEED 400 PLUS motor with controller built-in $9.99 justplainold Hot Online Deals 2 Nov 11, 2009 09:12 PM
Help! Looking for brushed speed controller circuit with reverse (non programmable) oracle_9 DIY Electronics 7 Oct 23, 2009 05:51 PM
