Old Oct 17, 2011, 08:18 PM
exit44rc is offline
Find More Posts by exit44rc
exit44rc's Avatar
Cleveland, OH
Joined Dec 2009
What battery connectors are you guys running? Where can you buy the stock ones for a good price?
exit44rc is offline Find More Posts by exit44rc
Old Oct 22, 2011, 08:36 PM
ho50ca is offline
Find More Posts by ho50ca
Joined Nov 2004
I'm converting it to the same connector as my Beast aircraft uses so, I can use the homemade Hyperion 180 packs I made for it. Should work ok, I think, I'm just waiting on delivery of said connector.
ho50ca is offline Find More Posts by ho50ca
Old Oct 24, 2011, 08:46 PM
ho50ca is offline
Joined Nov 2004
Gang,
This is gonna sound dumb, I bet but, I haven't done it before. I got 3 leads on my 2s Beast batteries and 2 going into the ESC. Do I just splice the 2 power leads from the lipo together or ??? IOW, how do I hook this to the existing 2 lead car wiring?
Old Oct 24, 2011, 08:57 PM
rcphreak is offline
Find More Posts by rcphreak
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
that is the balance plug there should be another lead with only two wires red and black . do not splice the balance lead .
rcphreak is offline Find More Posts by rcphreak
Old Oct 24, 2011, 09:48 PM
ho50ca is offline
Joined Nov 2004
These are homemade 2s packs so they don't have a second lead...only the 3 wire lead
Old Oct 24, 2011, 10:30 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
then you have a problem as the balance lead does not have wire that is made to support the ampdraw . you need to solder the proper leads onto them .
Old Oct 24, 2011, 10:57 PM
ho50ca is offline
Joined Nov 2004
these packs support a 2300 Kv brushless aircraft motor, I'm sure they can support the amp draw of a little brushed motor in this car, if I can hook them up right.
Old Oct 25, 2011, 05:06 AM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
actualy your beast air craft may draw less than this as its brushless and way less friction than these cars . remember planes require far less hp than cars to move as with your beast it weighs a fraction of the losi sct and does not run on the ground .
im not saying it will not work just use caution .
Old Oct 25, 2011, 07:31 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
How did you put together a 2s pack that only has a lead with 3 wires? Any pictures of it?
wparsons is offline Find More Posts by wparsons
Old Oct 25, 2011, 08:25 AM
ho50ca is offline
Joined Nov 2004
yeah, here's the video I used:
Eflite Beast - Hyperion 180 mah 2 cell Lipo Build Video (10 min 37 sec)
Watching this video again, it suggests to me that I can wire the red lead on the battery to the red lead on the ESC wiring and the black lead batt to the black lead on the ESC wiring, because there's a wire balancing the 2 cells draw inside.
This is a full on aerobatic aircraft so, the draw can be pretty high at times, especially since it's swinging a fairly large, steep pitch prop. I'll grant you, it's all up weight is low but, aerodynamic forces need to be considered as well, which magnify the weight and increase amp draw.
Old Oct 25, 2011, 08:04 PM
ho50ca is offline
Joined Nov 2004
Yep, that worked, just red to red, black to black, ignoring the centre wire. Car scoots alot better now.
Old Oct 25, 2011, 09:26 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Those balance lead wires are on the small side to be using as the main power leads, I'd keep an eye on the wire temps.
Old Oct 25, 2011, 10:01 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
when going to lipo on these little brushed motors the amp draw increases dramaticly as it was designed around 4.8v not 7.4 as parson suggested keep a close eye on the wire temps . can not compare this truck to any plane its oranges to apples .
im not pickin im just looking out for your best intrests i hope the battery works good for you just be sure to check it .
Old Oct 26, 2011, 10:40 AM
ho50ca is offline
Joined Nov 2004
I hear ya. I think I'll just make some custom packs out of 240 Hyps and go Dean's micro for connectors, as I hate JSTs.
Old Oct 26, 2011, 05:36 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Why not just buy a premade pack?
http://www.allerc.com/hyperion-g3-cx...ck-p-4501.html
Discussion losi micro 1/24 scale crawler mods custom t Rock Crawlers 0 Feb 15, 2010 09:58 PM
Discussion what is a good 1/10 scale electric rally car ? mortonj69 Off-road Cars 3 Jan 02, 2010 10:39 PM
For Sale perfect condition 1/8th scale 4WD gas powered racing car MRX-3 made by Mugen Seiki warming Cars - Cars and Parts (FS/W) 0 Dec 01, 2009 04:13 PM
Discussion losi 1/24 micro crawler specriv Micro Cars 4 Oct 17, 2009 06:59 PM
