Old Jan 04, 2011, 01:21 PM
Mera'din is offline
Find More Posts by Mera'din
Mera'din's Avatar
Joined Dec 2006
jaejw1, I sent you a pm concerning a losi brushless combo I have for sale.
Mera'din is offline Find More Posts by Mera'din
Old Jan 16, 2011, 10:24 AM
kymoonshine is offline
Find More Posts by kymoonshine
Drag and Destroy
kymoonshine's Avatar
United States, KY, Stanford
Joined Nov 2006
so we been running these little cars in my basement on a track we built...fun little cars...we were having no problems until we started running lipos... now we keep breaking pinion gears...are you guys using metal pinions? if so what car you buying them for? would we also need a metal spur?
kymoonshine is offline Find More Posts by kymoonshine
Old Jan 16, 2011, 12:16 PM
A Rdnek is online now
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
I use the 10 T from this seller.
http://cgi.ebay.com/Losi-Micro-SCT-R...item3a61a57a10
Ron
A Rdnek is online now Find More Posts by A Rdnek
Old Jan 16, 2011, 12:24 PM
Drag and Destroy
Joined Nov 2006
Ron
I just looked at these..do you use the glue on ones or the press fit? I wonder how well the glue on ones work?
Old Jan 16, 2011, 12:25 PM
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
press
Old Jan 16, 2011, 06:27 PM
Drag and Destroy
Joined Nov 2006
I also have a lot of interference in my basement due to overhead electric wires..its driving the 27 mhz crazy I was wondering if I could use the MRX-3100 ESC & DSM from a Losi Micro Crawler to convert it over to Specktrum?
Old Jan 16, 2011, 07:34 PM
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
Yes you can. But, the 3100 from the crawler uses a 3 wire servo. The servo in the Rally/SCT is a 5 wire. I don't know if the servo from from the crawler will fit in the Rally/SCT chassis.
Ron
Old Jan 22, 2011, 12:42 PM
Heavy Chevy is offline
Find More Posts by Heavy Chevy
Vanadu
Heavy Chevy's Avatar
Canada, YT, Whitehorse
Joined Dec 2008
Hi Guys,
It seems that I'm likely to be doing a trade to get one of these losi micro rally cars. I don't know much about them but I have one concern, maybe one of you could offer some clarification?
It seems that the esc and RX are one unit, am I right? So do I have to use the stock TX if I stick with a stock setup? SUrely I can swap a different RX in right?
Thanks and they really look like fun, especially the jumping
Heavy Chevy is offline Find More Posts by Heavy Chevy
Old Jan 24, 2011, 09:09 AM
Mera'din is offline
Mera'din's Avatar
Joined Dec 2006
The ESC and RX are on the same circut board. You will have to swap them out separate if you wish to upgrade. You will then have to swap out the servo as it is a 5-wire servo and wont work with most aftermarket RX's. There are many cheap 2.4ghz radio/rx combos out there that work reallt well and some really good brushed esc's that would allow you to change the radio/esc/servo, but keep the brushed setup.
However, doing a complete upgrade isn't that hard and there are a lot of good threads over at the microt site detailing how to do the swaps. Here is mine...
http://www.microtforum.com/forum/viewtopic.php?t=14314
Old Jan 24, 2011, 08:22 PM
Vanadu
Joined Dec 2008
^^Thanks
Old Feb 25, 2011, 10:36 AM
ovidiugm is offline
Find More Posts by ovidiugm
Joined Mar 2010
Originally Posted by ruststang94 View Post
Just picked up the sct and looking to do different wheels. I heard the rally tire/wheels are a little bigger? Can someone with the rally messure there wheels Im a little curious? Thanks.
Could someone please measure the wheels (for both SCT & Rally, if possible)?
I am thinking of throwing a 4WD Rally agains our RWD Mini-Z's on the track, as it would fit the class restrictions .
However I need to make sure that Mini-Z tires will fit, there's a great selection of compounds and ratings available for them. If not it would be very bad, as a wrong tire would negate the 4WD advantage on the track (we race both carpet and RCP).
Or, where do you buy your tires from? Are they available in various hardnesses?
Thanks!
ovidiugm is offline Find More Posts by ovidiugm
Old Mar 16, 2011, 08:06 AM
Potter is offline
Find More Posts by Potter
Potter's Avatar
Adamstown, MD
Joined Jan 2009
What lipos are you guys running?
I currently have a hobbyzone 300mah 7.4 velcroed to the top of the chassis, but I'd really like to find a 2s that would fit in the battery tray.
Losi wanting $30 for their lithium is crazy. Surely there is a 5 buck hobbyking battery or something...
Thanks -Brian
Potter is offline Find More Posts by Potter
Old Mar 16, 2011, 08:33 AM
Mera'din is offline
Mera'din's Avatar
Joined Dec 2006
You can check here for the batteries I am using. Or here...
I like the hobbyking 360 rhinos and haven't used the 350 zippies they offer but will try those next. I modify them to fit my setup but from what I read, they should fit with no modification as well. You will have to change the plug unless you follow my lead and just use the balance tap.
Old Mar 16, 2011, 09:23 AM
Potter is offline
Potter's Avatar
Adamstown, MD
Joined Jan 2009
Cant see your links, and I dont really want to sign up for another forum.
Thanks for the tip on the Rhinos and zippys.
Old Mar 16, 2011, 09:31 AM
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
Go sign up to the other forum....... If you are going to fool around with this car YOU NEED THAT FORUM.
Ron
Discussion losi micro 1/24 scale crawler mods custom t Rock Crawlers 0 Feb 15, 2010 09:58 PM
Discussion what is a good 1/10 scale electric rally car ? mortonj69 Off-road Cars 3 Jan 02, 2010 10:39 PM
For Sale perfect condition 1/8th scale 4WD gas powered racing car MRX-3 made by Mugen Seiki warming Cars - Cars and Parts (FS/W) 0 Dec 01, 2009 04:13 PM
Discussion losi 1/24 micro crawler specriv Micro Cars 4 Oct 17, 2009 06:59 PM
