Old Mar 15, 2013, 05:16 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by kevnkev View Post
does anyone have actually race this car other than bashing it?
Bashing just isn't my thing. I prefer to work on improving my precision driving skills & maintaining the racing line, or work on making things look scale. However, I have not raced the SCT against anyone in formal competition.
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 15, 2013, 09:12 PM
r46 is offline
r46
Find More Posts by r46
r46
huggin dat apex!
r46's Avatar
United Kingdom, London
Joined May 2005
no truggys?
heres mine (for indoor racing)
sheer blaze truggy
nactan bellcrank system
18a esc
hitec servo
3980kv
2s nano tech
r46 is offline Find More Posts by r46
Old Mar 15, 2013, 11:15 PM
Atown93 is offline
Find More Posts by Atown93
Joined Jul 2012
I purchesed the brushed model and just got done dropping anothe 400 or so in upgrades.
Spektrum 2.4 radio and esc.
8740kv brushless motor
3s lipo
All aluminum suspension
Aluminum shocks
Exotek chassis
Aluminum spur
Heatsink for motor
Its actually scary fast on 3s. I had to turn the throttle travel to 55% in order to keep it under control.Name: uploadfromtaptalk1363407286931.jpg
Description: Name: uploadfromtaptalk1363407268751.jpg
Description: Name: uploadfromtaptalk1363407247687.jpg
Description: Name: uploadfromtaptalk1363407227344.jpg
Description:
Atown93 is offline Find More Posts by Atown93
Old Mar 16, 2013, 02:18 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by FoamNub View Post
Hi all,
Not sure if that is a good place to ask for help but here it goes:
I bought my losi 1/24 rally a few months ago. I have driven it indoor only about 3 hours in total. Just when I got a hang of this thing drifting on my living room wood floor..two out of 4 wheel stopped turning. Actually they did not stop completely. They still spin, but slower than other wheels and I can stop them with light touch of a finger. I could not find any help with google search.(that usually works well for my Blade helis). What could it be and could a layman fix it?
Thanks in advance for any help
If its not a build up of hair it sounds like it could be the dog bones. What you described has happened to me a few times, and everytime it was an issue with the dog bones. First time it happened one of the dogbone pins fell out. the 2nd and 3rd times were due to the dogbones not putting enough pressure on the outdrives, the simple fix was to cut a small circle of rubber and stuff it into the outdrives so there was enough pressure when the dogbones were installed to lock the outdrives into gear.
Google: 1/24 LOSI outdrives and 1/24 LOSI dogbones if you dont know what these parts are
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Mar 16, 2013, 10:47 AM
robster94gt is offline
Find More Posts by robster94gt
Joined Oct 2003
I've got a Hobby King servo on the way. I was wondering if the stock servo saver is going to fit, or if it needs modification.
Cheers,
Rob
robster94gt is offline Find More Posts by robster94gt
Old Mar 17, 2013, 06:30 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
Very nice kagayama.
H.D. is offline Find More Posts by H.D.
Old Mar 18, 2013, 09:03 PM
DVUSHELI is offline
Find More Posts by DVUSHELI
DVUSHELI's Avatar
Bermuda, Pembroke
Joined Jan 2012
Just got one and......
....I'm flippin hooked on the SCT!! I never thought I'd like a sct but this thing sweets me!The BL system is pretty damn good on the stock battery, but I can't wait to get some lipos for it! I can see myself moddin the hell out've this thing!! Here comes the aluminum! The Exotek chassis is lookin really good. Is there a bellcrank steering system out so a regular servo can be used with a regular Rx?
DVUSHELI is offline Find More Posts by DVUSHELI
Old Mar 20, 2013, 01:44 AM
r46 is offline
r46
r46
huggin dat apex!
r46's Avatar
Joined May 2005
Thanks H.D
DVUSHELI The bellcranks available are for aftermarket chassis only.
the system i'm using (3 configurations available)
http://www.shapeways.com/shops/NactansCustomParts
items need:
aftermarket chassis
4x 4x7 x 2.5 bearings
1 x 3racing Micro-t turnbuckle set (MI-01)
2x Walkera HM-5#10-Z-04
very small drill bits
For exotek chassis:
http://www.shapeways.com/model/97430...ductBox-search
The kit includes 3 servo mounts for:
Hobbyking HXT500, Hitec HS5055, 1x universal mount.
Items you will need:
Exotek chassis
3 x Walkera ball link for 5#10 (HM-5#10-Z-04)
1 x Xray 2x12mm pin (XRA981212)
1 x Losi Mini-t Servo Mount/Steering Pin set (LOSB1033)
4 x Ball bearing 2x5x2.5mm
1 x Losi Micro-t screw set (LOSB1524)
3 x M1.6x3mm FHSC screw
4 x M1.6x5mm FHSC screw
4 x M2.5x4mm set screw
1 x Hitec HS-5065MG servo or HXT500 Servo
Old Mar 24, 2013, 05:59 PM
Spouny is offline
Find More Posts by Spouny
Spouny's Avatar
Joined Jul 2007
Hi,
Do you know if it's possible to programm the throttle endpoints for a micro rally brushless (as for a losi mini 8ight) ?
In the familly we've got 4 cars and one is really more powerfull than the 3 others, or it's seems that at 20% of the throttle travel it's like 100% on the other cars. So it's very hard to accelerate just a little.
Thanks.
Spouny is offline Find More Posts by Spouny
Old Mar 25, 2013, 10:13 AM
cat0 is offline
Find More Posts by cat0
Norway, Akershus
Joined Apr 2009
Hi all,
Check if the axles/wheel nuts spin while you stop the wheels with your finger. I have three wheels with the axle hole shaped as an O, instead of D. A couple of my friends have the same problem. Between us I think we have 8-9 of the white standard wheels go bad. The black / gold ones seems to be stronger.
cat0 is offline Find More Posts by cat0
Old Mar 25, 2013, 05:49 PM
Spouny is offline
Spouny's Avatar
Joined Jul 2007
+1, the white wheels are very bad quality, a few runs with the car and the axle hole shaped as an O, instead of D.
I bought gold wheels and it is stronger
Old Mar 26, 2013, 05:38 PM
DVUSHELI is offline
DVUSHELI's Avatar
Bermuda, Pembroke
Joined Jan 2012
Thanks for the info Kagayama for all the info! Lookin good!!
Originally Posted by kagayama View Post
Thanks H.D
items need:
aftermarket chassis
For exotek chassis:
Exotek chassis
Old Mar 29, 2013, 01:35 AM
wehan is offline
Find More Posts by wehan
wehan's Avatar
Joined Jan 2013
I have a brushless sct on the way and am wondering what 2s lipos fit. Not overly concerned with the plug as I will most likely switch the truck to micro deans but it must have a balance plug so I can use my low voltage alarm.
wehan is offline Find More Posts by wehan
Old Mar 29, 2013, 04:22 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
You cant beat naon-techs by hobbyking for both price and performance.
300mah 2s or 180mah 3s fit the stock chassis well. They both use red JST plugs.
The stock BL sct is good for 3s out of the box, but for prolonged use or racing in warm weather you may want to add a 12mm heat sink, and/or a small cooling fan.
EDIT: Also micro deans are useless and dangerous IMO. I had MDs but I swapped them for JST and never looked back. The batteries I mentioned wont fit in the stock chassis with a MD plug, but the slimmer JSTs fit well.
Old Mar 29, 2013, 09:04 AM
Joined Jul 2009
I use Hyperion 240s. Their voltage-holding ability under load is second to none & they last for 300+ cycles at 5c charge before they start to fade away, when properly cared for.
Joel
Discussion losi micro 1/24 scale crawler mods custom t Rock Crawlers 0 Feb 15, 2010 09:58 PM
Discussion what is a good 1/10 scale electric rally car ? mortonj69 Off-road Cars 3 Jan 02, 2010 10:39 PM
For Sale perfect condition 1/8th scale 4WD gas powered racing car MRX-3 made by Mugen Seiki warming Cars - Cars and Parts (FS/W) 0 Dec 01, 2009 04:13 PM
Discussion losi 1/24 micro crawler specriv Micro Cars 4 Oct 17, 2009 06:59 PM
