Old Dec 10, 2012, 05:17 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
I've had both. Definitely go with the 2.4 GHz brushless version! Not only is it faster - it's more efficient, and you won't be replacing motors all the time. Also, there is a huge difference in resolution between the toy-grade 27 MHz AM tx/rx and the Spektrum 2.4 GHz system. Compared to the Spektrum DSM system, the 27MHz system is like driving a car with shot ball-joints, bad tie-rod ends, and a half-turn of play in the wheel!
Stick with the factory NiMH packs for the youngsters, and pick up a few aftermarket 2s LiPo packs for the oldsters.
Joel
turboparker is online now Find More Posts by turboparker
Old Dec 10, 2012, 08:59 PM
mdelling is offline
Find More Posts by mdelling
Joined Jan 2005
Appreciate the advice, thanks!
mdelling is offline Find More Posts by mdelling
Old Dec 11, 2012, 08:07 AM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Originally Posted by fryfrog View Post
Thanks, I'll order those pinions. I'd be open to aluminium parts for things that might break easily, but after bashing this little thing around it seems like the cover does a good job of protecting most of it. I am a little disappointed in the steering, maybe a strong spring on the servo saver. When you turn left and go back to straight, it goes left a little... and when you turn right and go back to straight, it goes right a little.
Are there any parts that tend to break? I like to have a couple spares on hand for frequently broken parts, but I've no idea what might break on these guys.
I have only broken the chassis and a front lower arm. The chassis was totally my fault, but the lower arm was wear and tear, so I replaced the fron and back lower arms with aluminium ones and I have never had any problems since with the arms.
EDIT: Also I forgot to mention one of my dogbones broke, and the front set of diff outdrives, It would be handy to have those as spares, and bot parts should cost no more than 10bux combined.
valiantGLX is offline Find More Posts by valiantGLX
Old Dec 11, 2012, 08:12 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Joel
+1
thats some sound advice.
My SCT started as a AM brushed car, but I got the 2.4 BL losi kit + 2s and WOW. Words cant describe the performance difference
Latest blog entry: Please ignore....... for now
Old Dec 11, 2012, 08:23 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
In my house, the car does *not* do very well on carpet. It requires a significant amount of throttle to get moving and quickly bogs down if you go to slowly. Outside, it goes fast and slow just fine on concrete and even blasts through wood chips.
I'm going to try using a smaller pinion and larger main gear to see if it'll help on carpet and that'd lower top speed as well if I cared about that much.
before going to the higher gear ratio try loosening the gear mesh ever so slightly. If the gears are jammed too close together it will cause unnecessary strain on the motor and your car will run louder too.
Old Dec 11, 2012, 08:55 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
PHOTO DUMP: Foam hot box, for below zero temps
This is a fully enclosed hot box, with an air circulation unit for running in freezing temperatures. The theory behind it is that the air enters the chassis from the top hits the warm esc, flows over the motor and through the battery compartment, finally being sucked through the cooling chamber (aluminium foil heat sink plate) and re circulated through the fan. This helps keep everything at a more desirable operating temperature for better performance, especially with the lipo. Also because it is fully enclosed no snow can get into the electronics now
Method behind the photo dump madness? Because there is a greater audience, and a plethora of losi micro info at www.microtforum.com, but I dont like their photo upload tool. So, I load the photos here, and then paste the links to the photos in between this [IMG](photo link here)[/IMG], to get wonderful big pictures on the micro T forum.
Old Dec 11, 2012, 12:45 PM
Joined Jul 2009
Excellent job on the cold-wx setup! Have you had a chance to see how it works? It's common for us to see highs of -10 F or colder for a number of days in a row during January & February. That might be just what I need.
Joel
Old Dec 11, 2012, 01:15 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Joel
Thanks, give me an hour and you'll be even more impressed though.
I havent had a chance to try it yet out in the cold, but I there's no reason why it shouldnt work. Maybe if it was -10 F i'd consider removing the fan and making a foam flat top instead.
I've made plans for the basic hot box with a flat top (no cooling chamber, or cut out for the fan), if you want I can upload them. Sadly everything else on it I did freestyle (so no rear section, no front snow shield etc)
EDIT:
Snow shield? When I first ran my sct in the snow the section between the chassis and the body filled up with snow (thats why I bash it against the wall in my last vid, trying to get the snow out). So, I made the snow shield to stop the snow spraying off the tires and over the chassis. See the finished thing below.
Photo dump: snow shield + painted hot box
Old Dec 11, 2012, 04:12 PM
mdelling is offline
Joined Jan 2005
I had another question regarding a car like this for my sons and me. Can this size car make it across short grass or is it limited to flat surfaces mostly? I know my kids will want something fast but they probably want some versatility in use. I'm also trying to keep the price under $150, a balancing act I know. I was thinking of something in the mini size but price starts climbing for decent quality.
Thanks again,
Mark
Old Dec 11, 2012, 05:54 PM
fryfrog is offline
Find More Posts by fryfrog
United States, CA, Mountain View
Joined Sep 2010
I've run mine in wood chips, but only going between bits of pavement. It bounces around and is very unpredictable in the wood chips. I suspect it would be extremely fun in fairly clean dirt, but have no proof.
I have no evidence to prove it won't work, but I wouldn't take a "runs in grass" bet. IMHO, you're going to need something with tires that have a radius that are close to the depth of the grass.
fryfrog is offline Find More Posts by fryfrog
Old Dec 11, 2012, 06:42 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Thanks again,
Mark
Short answer is no, it wont handle grass very well. The SCT/Rally/Truggy's are more directed at indoor use. If your children would have fun upgrading/modifying the car, you could put Truggy tires on an SCT which would handle the grass better.
I guess you are looking at these for a christmas present, so hobbyking stuff is out of the question, but if time wasnt an issue Id suggest these:
http://www.hobbyking.com/hobbyking/s..._SCT_ARR_.html
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
http://www.hobbyking.com/hobbyking/s...io_System.html
http://www.hobbyking.com/hobbyking/s..._GENUINE_.html
Thats everything you need under $150, includes hobby grade battery charger, top quality batteries, a computer radio (TX), and a good size 4x4 SCT
Heres a running vid:
Turnigy 1/16 Mini SCT Short Course Truck (4 min 29 sec)
Old Dec 12, 2012, 07:54 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
photo dump
Old Dec 12, 2012, 09:57 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Just got my new servos in the mail...
http://www.hobbyking.com/hobbyking/s...dProduct=24720
Someone had said these fit so hopefully they do. The stock servo is just terrible. I did the mod to the turning radius. I'm guessing they made the stock turning radius so bad because the servo can't handle being thrown that far. On the two trucks I have one would randomly stop working and the other would sputter real bad when put in a full turn. And both trucks probably only have about 3 hours use. For the $150 they charge for it you think they could spend a few cents more on a better servo.
grimbeaver is offline Find More Posts by grimbeaver
Old Dec 12, 2012, 10:45 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Nice, those servos are very good. Youll just need a piece of credit card to fit them
Old Dec 12, 2012, 11:28 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
here's a vid of the sticky tape roll drift tires in action:
LOSI Micro SCT Sidewayz Action (6 min 32 sec)
remember watch in HD
Discussion losi micro 1/24 scale crawler mods custom t Rock Crawlers 0 Feb 15, 2010 09:58 PM
Discussion what is a good 1/10 scale electric rally car ? mortonj69 Off-road Cars 3 Jan 02, 2010 10:39 PM
For Sale perfect condition 1/8th scale 4WD gas powered racing car MRX-3 made by Mugen Seiki warming Cars - Cars and Parts (FS/W) 0 Dec 01, 2009 04:13 PM
Discussion losi 1/24 micro crawler specriv Micro Cars 4 Oct 17, 2009 06:59 PM
