Old Oct 03, 2012, 12:41 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by rcphreak View Post
the only way a c rating will cause an issue it if its too low . as that is how many amps the battery can safely put out . if higher than the requirement it hurts nothing but if too low it can in fact puff the batterys and ruin them or causing them to run hot and prematurely die faster or wirst case catch fire .
+1!
Also, using a higher C-rating often increases power & top speed. Higher-C packs with lower internal resistance will maintain their voltage under load much better than lower-C packs with higher internal resistance - which causes a greater voltage-drop under load.
Joel
turboparker is offline Find More Posts by turboparker
Old Oct 03, 2012, 11:59 AM
hotkiss is offline
Find More Posts by hotkiss
The Kraut
Joined Apr 2012
Switching the battery types
Originally Posted by raggedclaws View Post
My new brushless 2.4 Ghz micro SCT has a problem with my fully charged Hyperion 2S 240mAh battery packs. When I pull the throttle trigger on the TX I get no throttle response. I get steering response but the motor doesn't budge. When I use the stock 4.8 volt NiMH battery everything works fine. Also when I use a partially charged Hyperion 2S LIPO (storage charge) everything works fine. Is there some kind of over voltage protection built into the esc? These cars are supposed to work on a 2S LIPO battery. Some have even used 3S batts. Any ideas?
Thanks, Kim
Our new Losi racing team we founded in our company (7 Losis 1:24 Brushless 4WD) knows the same problems when we switch the battery types back and forth.
No straight solution, but switching on and off the car and the transmitter a couple of times seems to do the trick.
hotkiss is offline Find More Posts by hotkiss
Old Oct 03, 2012, 12:23 PM
valiantGLX is offline
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
Where are you based Kraut, Im guessing Germany, anywhere near Berlin?
valiantGLX is offline Find More Posts by valiantGLX
Latest blog entry: Please ignore....... for now
Old Oct 03, 2012, 12:24 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Thats good to hear
Old Oct 03, 2012, 12:27 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Originally Posted by turboparker View Post
I have yet to find a suitable upgrade, but then I haven't been looking as-of-late. During the flying season, I spend most of my RC time flying planes & helis. I'll get back into driving & upgrading the SCT this winter. I'll let you know if I find something. However, others may have already figured it out.
Joel
Me too, although I didnt do any actual flying this season
I have ordered this little number, the dimensions seem spot on: http://www.hobbyking.com/hobbyking/s...sec_0_8kg.html
Old Oct 03, 2012, 06:23 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Got SMD's
Here is a little sneak peak of my bling amplifying smd led system that slots directly on to the shock towers. However I ran into some problems: It was about 4am and I just finished up (I even had them covered in CF 3D textured vinyl) and I was doing some final testing when I hooked the wrong battery up to them, which ultimately lead to all 4 6030 leds blowing in a split second. But there's a moral in this story: Dont play with lipos when you're over tired
So Im working on version 2 which will sport 8 leds now to light up my bling aluminium parts when I get them.
Old Oct 04, 2012, 09:17 AM
hotkiss is offline
The Kraut
Joined Apr 2012
The other Kraut is based in the RheinMain area...
In case you arround sometime, gimme a shout and we will arrange an indoor race
Old Oct 11, 2012, 05:27 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Sounds good
Old Oct 11, 2012, 05:29 AM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Short Course Truggy
Here's one of my latest builds, enjoy
Old Oct 13, 2012, 02:11 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
But wait theres more!
... Sorry no steak knives, but cop an eye full of this!
Old Oct 14, 2012, 11:01 AM
Joined Jul 2009
ValiantGLX,
Very nice! Which wheels are you using? Also - is that a voltage display?
Joel
Old Oct 14, 2012, 02:30 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
ValiantGLX,
Joel
The wheels are from a stock losi 1:24 truggy along with the wing
The display shows the voltage of the battery in real time, so I dont need to time my runs any more. Think of it as a digital fuel gauge. It weighs a meer 6g and only cost 2 bux from HK
Old Nov 18, 2012, 09:12 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Photo Dump - 3 wire servo mod and dust gaurd
A quick look at my 3 wire servo mod and dust guard
Old Nov 18, 2012, 09:18 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Photo Dump - Carbon fiber vinyl and antenna mod
Heres a quick look at my Carbon fiber vinyl and antenna mod
Old Nov 18, 2012, 09:42 PM
Technomancer
valiantGLX's Avatar
Joined Sep 2011
Photo Dump - Carbon fiber vinyl covered credit card stone deflectors
Heres a quick look at my Carbon fiber vinyl covered credit card stone deflectors
Discussion losi micro 1/24 scale crawler mods custom t Rock Crawlers 0 Feb 15, 2010 10:58 PM
Discussion what is a good 1/10 scale electric rally car ? mortonj69 Off-road Cars 3 Jan 02, 2010 11:39 PM
For Sale perfect condition 1/8th scale 4WD gas powered racing car MRX-3 made by Mugen Seiki warming Cars - Cars and Parts (FS/W) 0 Dec 01, 2009 05:13 PM
Discussion losi 1/24 micro crawler specriv Micro Cars 4 Oct 17, 2009 07:59 PM
