Old Jul 29, 2010, 12:54 AM
the rat is offline
Find More Posts by the rat
Joined Jul 2010
what lipo should i use in short Course races
i have a 40c 5000mah lipo and it takes to long for a good charge on it and in races i run low on mah so what is a better lipo to use in races and the names of the lipo help
the rat is offline Find More Posts by the rat
Old Jul 29, 2010, 06:27 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
If you run low on MAh in a 4-5 min race with a 40C 5000mah then something is wrong.
Your pack is dying or your not running the right gearing.
And that is a big heavy pack to race with BUT I havent been racing for long time and that was before lipos.
freechip is offline Find More Posts by freechip
Old Jul 29, 2010, 10:45 AM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
How are you charging you lipo - what charger, what brand lipo? Somethings not right, poss you not charging your lipo completely?
I don't race, but use a 35C 5000mah 2S lipo in my Slash and I can bash for 20-25min easy.
Duster_360 is offline Find More Posts by Duster_360
Old Jul 29, 2010, 12:29 PM
the rat is offline
Joined Jul 2010
duster 360 how long does it take u to charg yours because mine take like 50 min
Old Jul 29, 2010, 03:24 PM
jettrooper02 is offline
Find More Posts by jettrooper02
jettrooper02's Avatar
USA, WA, Bonney Lake
Joined Aug 2008
they should take like 50 minutes, just get 2 more lipo's and you'll be set. even then, at my local track i have time to charge a 5000mah 20 2s lipo between heats, and it takes mine about an hour to charge. also, you shouldn't need that much of a c rating with a 5000mah, i'd go with a 30c instead.
jettrooper02 is offline Find More Posts by jettrooper02
Old Jul 29, 2010, 07:23 PM
Texas
Joined Aug 2006
It takes me about that long, prob a little less since I don't run down to the lvc, I stop running as soon as I see it start to slow down. I usually see 3500-3800mah go back into the lipo on charge. Prob 40-45min. Basically same as you're seeing.
I understand better now - you're trying to makes all the races on one lipo, thats why you're running out. If your charger has a FAST charge mode for lipos, try using that. That should cut charging time by almost half.
Prob best to get one more lipo at least.
Old Jul 29, 2010, 09:39 PM
Joined Aug 2008
yeah, definetly get 2 lipo's for racing, it's a bad idea not to. i usually make 2 heats on one battery before lvc will hit in a race, so you need at least 2 batteries. i have had lvc hit in a race to, did a pit stop and still won(very little competition.)
Old Jul 30, 2010, 12:12 AM
the rat is offline
Joined Jul 2010
i went to go and buy a new 30c 5000mah it charges fast and i get a long run time on it to so thank guys
Old Jul 30, 2010, 06:20 AM
stampede vxl is offline
Find More Posts by stampede vxl
simon burrows
england
Joined Apr 2009
up your old lipo in the bin then . do you race in the uk or usa
stampede vxl is offline Find More Posts by stampede vxl
Old Aug 01, 2010, 10:07 PM
the rat is offline
Joined Jul 2010
us
Discussion How do you tell if you should use a Lipo battery that has been in a crash??? greenmonsta79 Batteries and Chargers 4 May 31, 2010 08:56 AM
Help! What spinner should I use? mrleenagle High Performance 5 May 20, 2010 05:20 AM
Discussion New to model boating, what motor should I use? kec011va Dock Talk 11 Apr 03, 2010 12:20 AM
Help! What equipment do I or should I use to cycle batt's? TRITONZEUS Batteries and Chargers 0 Mar 16, 2010 07:41 PM
Discussion What loctite should I use to afix a pinion to my main motor? hidavi Micro Helis 6 Feb 28, 2010 02:59 PM
