View Poll Results: Add Another Option: BMN (Bare Minimum Necessities)
no batteries, no charger, and no tx! $59.99(BMN) 752 86.24%
were just asking for too much 120 13.76%
Voters: 872. You may not vote on this poll
Old Jan 25, 2013, 10:05 AM
robgau is offline
Find More Posts by robgau
Pineville, LA
Joined Dec 2006
Is it possible that the control rod has slipped in the heat shrink?
robgau is offline Find More Posts by robgau
Old Jan 25, 2013, 12:07 PM
Motorbikebruno is offline
Find More Posts by Motorbikebruno
Crash Expert
United States, MN, Circle Pines
Joined Oct 2012
+1 mine did this and it took me a minute to figure that out. Also make sure it's in the control horn correctly.
Motorbikebruno is offline Find More Posts by Motorbikebruno
Old Jan 25, 2013, 06:50 PM
Iplumb is offline
Find More Posts by Iplumb
Joined Aug 2012
Yep, that's what happened...well I don't know if it slipped or was glued that way? I had to strip the heat shrink and remove the glue. I then re glue it straight. I wish I would've done this before my maiden that resulted in a broken prop shaft and ripped the elevator.
Iplumb is offline Find More Posts by Iplumb
Old Jan 28, 2013, 05:13 PM
Crash Expert
Joined Oct 2012
Dang, well at least it's sorted now! Happy flying!
Old Jan 31, 2013, 03:07 AM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
That happened on my um Mustang.
The only place I found shrink tube that small was in um replacement kits.
You got glue to hold!
Good news. Chris
Wamp is offline Find More Posts by Wamp
Old Jan 31, 2013, 06:36 PM
Iplumb is offline
Joined Aug 2012
Good news. Chris
I just used foam safe CA. Man this thing is fun. Finally got it up inside what a pleasure. Just wish I wouldn't have busted it up before. ...Should've listened to myself. 1st four channel and I'm hooked on how much control I have. What a blast. I was getting ready to replace my Champ for our indoor club. Glad I didn't. My buyers remorse is gone
Old Feb 05, 2013, 03:58 AM
Tom_1971 is offline
Find More Posts by Tom_1971
Tom_1971's Avatar
Italy
Joined Jun 2008
While making my second deep repair of the nose after abuse from my son and myself, I decided to strengthen the nose with some pieces of carbon fibre 2 mm rod I had around my garage.
In the attached pictures you can see what I did on both upper and lower fuselage. Still have to check CG (glue not dried completely, yet) then see how it flies...
Tom_1971 is offline Find More Posts by Tom_1971
Old Feb 08, 2013, 08:29 AM
impmotor is online now
Find More Posts by impmotor
Horsham, PA
Joined Aug 2007
My UM T-28 had become unflyable because of a worn out battery connector. Power to the brick had become spotty at best. I bought a new connector from RC-Connectors and am now back in business. The new connector is pennies, but the soldering is tricky. This poor plane has been through significant damage after hundreds of flights but is still going strong. Time to invest in some new batteries.
impmotor is online now Find More Posts by impmotor
Old Feb 14, 2013, 11:27 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
FPV with UM T-28
UM T-28 FPV 5.8ghz (3 min 15 sec)
The micro t-28 makes a great FPV platform! Its stable but can still roll and loop. Its also easy to land! Never knew I could get so much fun out of this trainer!
Cheese5 is offline Find More Posts by Cheese5
Old Feb 15, 2013, 10:57 PM
ryramZ is online now
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Call Horizon and tell them what happened. Maybe they'll send you a new shaft gearbox assembly. If not they are pretty cheap. once you get the assembly you can replace shafts without replacing the whole assembly. Sorry your having trouble, once you get it ironed out you'll be golden. Your one of our friends aren't you?
Parkzone UM Trojan Flight Lesson 2 (6 min 51 sec)
ryramZ is online now Find More Posts by ryramZ
Old Feb 17, 2013, 10:51 AM
Iplumb is offline
Joined Aug 2012
http://www.youtube.com/watch?v=Ko3V_vIB2Fs
I am...You guys are a lot of fun to watch.
Old Feb 17, 2013, 11:07 AM
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
Awwwchucks, thanks man! Mike just posted a dual rate and expo lesson.
Old Feb 18, 2013, 08:05 PM
Iplumb is offline
Joined Aug 2012
I'll check it out, Thanks!
Old Feb 19, 2013, 07:20 PM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
Just caught your video the other day on the um t-28 and champ wish I would have seen them when I first got them. Still good information for anyone just flying either plane. Now do one on an AXN I bought myself one for xmas but have not taken it up yet. Mainly due to crappy weather in Ohio. Keep up the good work. Will paste your vids when I see people asking questions on these 2 planes. I know you have way more vids covering other planes but these 2 are generally the threads I read.
Greg
Ginohio is offline Find More Posts by Ginohio
Old Feb 19, 2013, 07:47 PM
npinnau is offline
Find More Posts by npinnau
Kaysville, Utah
Joined Jul 2003
My T-28 seems to be balanced at the CG suggested in the manual however it seems as if it is slightly tail heavy when it flies as it is always nudging upwards. Has anyone else experienced this? I have attempted to search through the thread to find anyone with similar issues but haven't really found anything. I am also running a 190 mah battery that is about 20% heavier than the stock battery and it still seems tail heavy. Any suggestions or recommendations?
npinnau is offline Find More Posts by npinnau
Discussion PZ Radian or PZ T-28????? rclab1 Beginner Training Area (Aircraft-Electric) 10 Jun 06, 2010 01:59 AM
Question Which is better for grass field pz t 28 or pz p51d bl friz Electric Warbirds 25 Mar 25, 2010 11:00 PM
Poll Which is better for grass field pz t 28 or pz p51d bl friz 3D Flying 0 Mar 22, 2010 09:20 PM
Sold TRADE PZ Corsair PNP for PZ T-28 HBPD Aircraft - Electric - Airplanes (FS/W) 4 Oct 14, 2009 01:18 AM
Wanted Will trade for PZ F4U or T-28... WWIIace Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2009 12:41 PM
