View Poll Results: Add Another Option: BMN (Bare Minimum Necessities)
no batteries, no charger, and no tx! $59.99(BMN) 763 86.41%
were just asking for too much 120 13.59%
Voters: 883. You may not vote on this poll
Old Dec 14, 2012, 01:12 PM
Iplumb is offline
Find More Posts by Iplumb
Joined Aug 2012
Originally Posted by Gharddog03 View Post
Not bad other then the trimming. But once I sorted that out. Everything was go to go. Set DR 80% / Expo 20 and flys great. Yes, my first 4 channel.
I think it's gonna be mine also. Thx.
Iplumb is offline Find More Posts by Iplumb
Old Dec 15, 2012, 12:06 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Whyyyyy
Now this was utterly ridicolous... today i flew it a bit until it got a bit nasty-windy so i landed... i was dissasembling the landing gear and holding it with one hand as i dissasembled it with the other, i had to grab it by the wing to not yank the gear out of the fragile wing .. and then as i was holding it by the wind.. one gust of wind and... bent wind
so... how can i fix this.. or should i think in buying a new wing?
it bent upwards.. in the lower intrados of the wing the crack is "open" if you pull the wing.. i think i could pour a bit of foam safe CA in there... what do you think?
JLT_GTI is offline Find More Posts by JLT_GTI
Old Dec 15, 2012, 12:49 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
I had a lot of cracks which made the wing even more flexible than when it was new. I used a CF strip glued into place with epoxy: http://www.rcgroups.com/forums/showt...3#post22533343
The wing had to be removed for this work, and a new wing would have been easier, but the CF strip really stiffens the wing. No longer do the ailerons flex the rest of the wing.
I used polyurethane glue (brown Gorilla glue) for the cracks.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Dec 15, 2012, 06:30 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The easily creased wings is why I put CF on mine.
UNGN is offline Find More Posts by UNGN
Old Dec 15, 2012, 07:22 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
well.. i poured CA in the crack part wich was open (underside) and put streetech tape over both sides... seems ok now...
flight tests will say... but its deeply ironic that this wing can take touch and gos and landings and cant take its own weight when moved by a not so strong wind (10/15km/h?) when being hold by hand
Old Dec 16, 2012, 07:58 PM
Joker 53150 is online now
Find More Posts by Joker 53150
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
I'm re-building my UM T-28 thanks to a rather nasty crash. What glue/adhesive is recommended to hold the electronics down like they were from the factory? It seems like a thin caulking, as it's very rubbery.
Joker 53150 is online now Find More Posts by Joker 53150
Old Dec 16, 2012, 08:01 PM
Joined Aug 2012
Silicone glue. I use a product made by GE, that claims to release methanol. I try to avoid products that release acetic acid while curing (as do most silicone caulks).
Old Dec 17, 2012, 11:27 AM
Motorbikebruno is offline
Find More Posts by Motorbikebruno
Crash Expert
United States, MN, Circle Pines
Joined Oct 2012
Joker, I found a low-temp glue gun to work wonders. Don't even need that much to keep things in place.
Motorbikebruno is offline Find More Posts by Motorbikebruno
Old Dec 17, 2012, 12:00 PM
Joined Aug 2012
I found that the low-temperature hot glue just barely holds. It is extremely easy to break free, and I would not recommend this.
But I do use hot glue in the process. I use two tiny dabs to keep the part in place while the silicone glue cures. It makes things much easier.
Old Dec 17, 2012, 12:07 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Oh yes.. i used it too to glue one of the landing gear bases (before i bought foam safe CA) and it works quite well .. actually i use a dual temp glue gun.. low setting works more than well in foam and wont burn it ... the "but" is that you have less time before the glue cools down and sets.. so use it in small places or very fast if over a large area.
Still i dont use it on the T-28 unless absolutelly necesary.. hot glue is one of the heaviest glues out there (along with epoxy) so making many repairs will increase the weight.. and these planes like it light.... yes they will fly even with 75% more weight ... but not as well
Old Dec 17, 2012, 12:48 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
I use white gorilla glue for everything! Not extremely flexible, but i like how its thick, expands twice its size and dries white. You can also influence drying time by how much water you coat the surfaces with and spray on it.
airpower is offline Find More Posts by airpower
Old Dec 17, 2012, 01:00 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
I have ear a lot about Gorilla glue, but unfortunatelly its not avalaible in europe and dont know what the equivalent would be
Old Dec 17, 2012, 01:14 PM
Joined Aug 2012
Gorilla glue is a brand of polyurethane glue. There are other brands, but I do not know what might be sold in Europe.
Old Dec 17, 2012, 01:16 PM
LowlyElevated is online now
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Personaly, I have fount that 5min epoxy makes for a lot cleaner joint that is still pretty strong and dosen't create a hard point, and dosen't expand like gorrila glue.
LowlyElevated is online now Find More Posts by LowlyElevated
Old Dec 17, 2012, 05:37 PM
GoAround is online now
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
When I creased my wing badly, I used a length of 1mm CF rod underneath. After bending the wing straight, I just poked it right through the fuselage and laid a length of epoxy underneath and held it in place with paperclips. Once dry, I covered it with a length of clear tape. Now I can pull back as hard as I want on max elevator travel and it simply does a tight loop. I am convinced the wing would fold without the rod. My only disappointment is that the CF did not remove any dihedral - I should have thought about it and bent the wings down a bit before I glued it ....
I have used this T-28 to mess about with whilst learning up the club on bigger aircraft. You can imagine what a mess it looks now but it all functions well and some new Miniaviation 190's have given it a new lease of life. I set 7 mins on the timer but it will go about 8:30 before using up 80%.
GoAround is online now Find More Posts by GoAround
Discussion PZ Radian or PZ T-28????? rclab1 Beginner Training Area (Aircraft-Electric) 10 Jun 06, 2010 12:59 AM
Question Which is better for grass field pz t 28 or pz p51d bl friz Electric Warbirds 25 Mar 25, 2010 10:00 PM
Poll Which is better for grass field pz t 28 or pz p51d bl friz 3D Flying 0 Mar 22, 2010 08:20 PM
Sold TRADE PZ Corsair PNP for PZ T-28 HBPD Aircraft - Electric - Airplanes (FS/W) 4 Oct 14, 2009 12:18 AM
Wanted Will trade for PZ F4U or T-28... WWIIace Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2009 11:41 AM
