View Poll Results: Add Another Option: BMN (Bare Minimum Necessities)
no batteries, no charger, and no tx! $59.99(BMN) 760 86.36%
were just asking for too much 120 13.64%
Voters: 880. You may not vote on this poll
Old Nov 06, 2012, 02:35 AM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Originally Posted by w4yn View Post
I fly Ember (and new mini Ember when it arrives) Champ and HZ Albatros in gym. My old thumbs may not be quick enough for t-28 AND p-51 indoors, will also break out some heli's.
Tim
In doors always throws me.
Lighting were I fly sucks.
Naturally helies, but I love planks.
Vapor can stay very close. Less than 1/2 court.
My fave is a hopped up Champ. T -28 keeps me on my toes and uses 3 full courts.
Mustang gets me in trouble.
The little albatros is a winner.
Experienced guys are flying the gws pico tigermoth and simler size bipes in the same space.
the experts are flying large flat out 3D units.
I make do with the um 4-site.
In door ceased being fun for me.
There was a movie were surfers followed the weather. Good idea!
Have fun! Chris
Wamp is offline Find More Posts by Wamp
Old Nov 06, 2012, 09:28 AM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
i'm hoping replacing the motor will give it some more pep. i got this plane from a friend that said he couldn't fly. no telling how long it and set, or how old it really is. all i know is the wing and tail feathers were broke. i replaced all that, and it's a great flyer, but it won't do a loop to save its life. it just pitches up about 45*, almost stops, then falls over.
it just seems very weak in power. sometimes (getting more and more often) i gotta give the prop a little spin to get the motor running. usually a sign of motor going bad. gear mesh is good, and gears are clean.
hoghead5150 is offline Find More Posts by hoghead5150
Old Nov 06, 2012, 09:42 AM
ScottGridley is offline
Find More Posts by ScottGridley
United States, MA, Rutland
Joined Oct 2011
The stock motor works fine for simple aerobatics like loops and your LHS should have them for under $15. If you want something a little more peppy, RCBabbel (he's on the forums here, check his blog) has some XS motors which I recently used. A bit more power, but supposedly much longer lifespan - since I just installed, you'll have to wait until 2014 for me to confirm.
You might also move the push rod in to get a little more elevator authority. Just watch that the U doesn't get obstructed by hitting the underside of the elevator.
ScottGridley is offline Find More Posts by ScottGridley
Old Nov 06, 2012, 10:01 PM
Motorbikebruno is online now
Find More Posts by Motorbikebruno
Crash Expert
United States, MN, Circle Pines
Joined Oct 2012
I ordered up my 2s conversion parts, so I'll post happily when it arrives..until then..
On a sad note, I can't fly while I wait, the motor finally gave out
Motorbikebruno is online now Find More Posts by Motorbikebruno
Old Nov 08, 2012, 06:06 AM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Good luck in there. I wonder if there is room for the nose gear.
Definitly move the rods in!
You can get a free flight rubberband powered Gillows to get a fix!
Chris
Old Nov 08, 2012, 10:22 AM
Crash Expert
Joined Oct 2012
Chris
I will take note of the nose gear. I really enjoy using it to taxi around so I'll do my best to keep it in there.
As for my fix...got me a typhoon that I fixed up after I crashed it on maiden...5 seconds of good quality LEARNING. And this scratchbuilt foamy that I can't seem to get to fly. I'll keep tweaking until it does!
Old Nov 08, 2012, 07:38 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Keep on tweak'n'!.
Gee from here the tail feathers look small.
What is the ratio of fuse l to wing spand?
Angle of wing incidence?
Not that I have done a scratch built in the last 40 years. But those things all made a big difference.
what is the trouble?
Torque roll?
Keep at it man! Very cool!
Got a start on the back burner. Balsa build, old school tisue / dope, mixed with new lipo / Brushless gear.
50 years ago we were looking for better rubber bands, or even any we could find! Chris
Old Nov 08, 2012, 08:10 PM
sathanas2 is offline
Find More Posts by sathanas2
Billy D
United States, PA, Monaca
Joined Nov 2011
I put a new battery lead on my t-28 and now there is no rudder or elevator they are stuck in full extreme positions. But the ailerons and the motor still work? Any help would be greatly appreciated!!! hopefully just a reset of some sort. Ca,t afford a new reciever right now!
sathanas2 is offline Find More Posts by sathanas2
Old Nov 09, 2012, 11:52 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Without knowing more about your rework, I am guessing that the battery polarity was reversed when the Lipo was first connected to the Brick and thus damaged several of the transistors that drive the servos.
Easy enough to test the transistors by manually recentering the servo arms then connect battery and if they run to the extremes again the parts are toast.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Nov 09, 2012, 05:59 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Yikes! it happens.
Have a um mustang were only one servo did this.
Call Horizon Support. Good Luck Chris
Old Nov 11, 2012, 07:52 PM
walter3rd is online now
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
wamp, love that typhoon! sweet! going to cut open my micro t-28 AGAIN!!!!! going to lube the servos with fader lube and limit throws even more. stupid ailerons caused a crash of a almost mint plane and broke the motor mount or something! so pissed! i really want to try a last ditch effort to save this plane but.... i just maidened my BEAST tonight so im not too pressed!
walter3rd is online now Find More Posts by walter3rd
Old Nov 11, 2012, 08:29 PM
JudahBenHur is offline
Find More Posts by JudahBenHur
JudahBenHur's Avatar
Joined Sep 2012
I finally got to fly my micro T-28 today. I've had it for a week or two but have been waiting out the high winds, rain, and everything else the hurricane threw our way. I let my brother trim it out and he ran the first battery out. My turn was going good for 4 or 5 minutes and then it ended up in a pine tree. The ball park we fly in is surrounded by a couple of pine trees and that one had my name on it. It was a soft "landing". I tried shaking the lower branches but it wouldn't budge. I had to poke it out with an aluminum pole that I had down home. I did run another battery through it and like the plane much better than the Spitfire at this point in my fledgling flying career.
JudahBenHur is offline Find More Posts by JudahBenHur
Old Nov 11, 2012, 08:50 PM
Matt Ls Thumbs is offline
Find More Posts by Matt Ls Thumbs
Joined Aug 2012
Dude! I got that servo sitting on my desk, and I need to get it in the mail! Been busy and all those excuses. PM me your address...
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Old Nov 12, 2012, 04:32 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Have almost done a Beast a few times. Waited for the Carbon Cub, then changed my mind after reading about the qc.
Did a Millennium SSX instead.
would love to see a brushless T-28 with a 21" ws! Chris
Old Nov 12, 2012, 06:30 PM
Joined Jul 2012
well my t-28 had a rough day. my motor had been acting up, so i put a new motor in it (stock). after this i noticed that it would sorta cut out a little and if i gave it full throttle it would cut in/out and then quit!! the esc would flash for a couple seconds and then reset. this was all on the workbench. well i had a new gearbox (noticed a little slop in the old one) so i changed the gearbox. on the workbench it ran good then.
today i took it out, on the first flight just after launch (hand launch) it cut out and belly landed. well i swapped batteries (not sure if the first one was charged or not), and the second flight it went about 50 feet, cut out, rolled over, and augered in on the concrete. broke the cowl off just behind the motor mount, broke a chunk out of the side of the fuse. i can fix it, but not sure what is causing the motor to cut out and the esc to reset like its doing.
Discussion PZ Radian or PZ T-28????? rclab1 Beginner Training Area (Aircraft-Electric) 10 Jun 06, 2010 12:59 AM
Question Which is better for grass field pz t 28 or pz p51d bl friz Electric Warbirds 25 Mar 25, 2010 10:00 PM
Poll Which is better for grass field pz t 28 or pz p51d bl friz 3D Flying 0 Mar 22, 2010 08:20 PM
Sold TRADE PZ Corsair PNP for PZ T-28 HBPD Aircraft - Electric - Airplanes (FS/W) 4 Oct 14, 2009 12:18 AM
Wanted Will trade for PZ F4U or T-28... WWIIace Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2009 11:41 AM
