View Poll Results: Add Another Option: BMN (Bare Minimum Necessities)
no batteries, no charger, and no tx! $59.99(BMN) 763 86.41%
were just asking for too much 120 13.59%
Voters: 883. You may not vote on this poll
Old Aug 07, 2012, 07:24 PM
civichb98 is offline
Find More Posts by civichb98
REALJDMEK9
civichb98's Avatar
Miami, FL
Joined Oct 2005
It's super easy to fly this thing inverted and I can fly it like that as long as I want to.
civichb98 is offline Find More Posts by civichb98
Old Aug 07, 2012, 07:56 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
What spot in the elevator control horn are you in?
rcrich is offline Find More Posts by rcrich
Old Aug 07, 2012, 08:23 PM
kman24 is offline
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
To fly inverted you basically roll the plane over on its back and then pretend that up stick is up and down stick is expensive
Kman
kman24 is offline Find More Posts by kman24
Old Aug 07, 2012, 08:29 PM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
I have cut through the tap and am at the tail..is putting this puppy in the freezer for abit the best way to go? I have been reading on hrre and you-tube thinking my motor is dropping down and binding my rudder servo..am at the tail end so to speak..razor blade through or better approach..any thoughts?
Ginohio is offline Find More Posts by Ginohio
Old Aug 07, 2012, 09:11 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
If this is your first time opening the fuse I would tape the decals first then slice through them with a fresh razor. I have never heard of the motor dropping onto the rudder servo......never know though! I would check clearances though once you have it open and when you take the top off just make reference to where your motor lead is on the board before un hooking it! If the rudder control rod slipped in flight the crash most likely put it back in place!
goodhumormarc is offline Find More Posts by goodhumormarc
Old Aug 07, 2012, 09:15 PM
Joined Jul 2010
Originally Posted by rccessna View Post
My t-28's battery leads have come apart...... the all in one that it has is discontinued. What should i do?
call Horizon hobby! they will probably send you a new brick...if you're nice!
Old Aug 07, 2012, 09:40 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Kman
Good one!!!
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Aug 07, 2012, 09:48 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
I know how to fly inverted but this bird seems to be losing altitude even with full down elevator.
Old Aug 07, 2012, 09:53 PM
REALJDMEK9
civichb98's Avatar
Miami, FL
Joined Oct 2005
I have it in the 3rd hole.
Old Aug 07, 2012, 09:57 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
You may need to pinch the U bend of the elevator control rod a little to compensate. Also, if you have the battery too far forward it may be too nose heavy. Move it back a little and see if it improves.
Kman
Old Aug 08, 2012, 05:51 AM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Thanks I will try that.
Old Aug 08, 2012, 11:21 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
If they have come off at the brick someone good with a soldering iron can fix it.
If it broke in the middle or at the connector another connector on a set of wires can be soldered on even if you're not too good at soldering.
If RCBABBEL is still poking about he used to have connecterized leads, I might have an extra poking about, pm me with your address if you'd like it (if I have one).
CNY_Dave is offline Find More Posts by CNY_Dave
Old Aug 08, 2012, 06:08 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
did they break off the board ? any chance to solder them back on ? may have to look in the micro classifieds for a used one..or possibly a new one
KCinNC is offline Find More Posts by KCinNC
Old Aug 08, 2012, 07:21 PM
mrodgers is offline
Find More Posts by mrodgers
United States, PA, Butler
Joined Jun 2006
Opening the fuse - tape a semi wide piece of tape wider than regular scotch tape the entire length of the fuse seam covering both the seam and the decals. Then you cut this same entire length with a razorblade to open. To close, a few pieces of scotch tape on top of the tape that you cut allows you to just pull tbe scotch tape off easily in the future if you ever need to get back in.
Flying inverted - I could never fly mine inverted. Needed way too much elevator and was way too twitchy and always wanted to flip back over and right itself. When I put a thin fiberglass 7 inch rod through the wing mount and taped the wings down, it completely flattened the wings. 0 dihedral. First flight I flew the entire battery inverted no problem. I have a 7% elevator deflection on 50% and higher throttle mix for level full throttle flight so I just added a 2nd mix on my DX6i to give 50% elevator deflection on trottle so I can just throw the switch any time I want to flip inverted. Now I have no need at all for giving down elevator when inverted. I just flip the switch and continue flying as usual but inverted.
mrodgers is offline Find More Posts by mrodgers
Old Aug 08, 2012, 09:52 PM
REALJDMEK9
civichb98's Avatar
Miami, FL
Joined Oct 2005
Here's where I got the idea. I wouldn't push it through the bottom fuse. Just cut them into two pieces and go with the:
http://www.rcfoam.com/product_info.p...679926e50632ca
Ultra Micro Wing Repair.mp4 (1 min 28 sec)
I used Foam Safe CA for the Cabron strips
Discussion PZ Radian or PZ T-28????? rclab1 Beginner Training Area (Aircraft-Electric) 10 Jun 06, 2010 12:59 AM
Question Which is better for grass field pz t 28 or pz p51d bl friz Electric Warbirds 25 Mar 25, 2010 10:00 PM
Poll Which is better for grass field pz t 28 or pz p51d bl friz 3D Flying 0 Mar 22, 2010 08:20 PM
Sold TRADE PZ Corsair PNP for PZ T-28 HBPD Aircraft - Electric - Airplanes (FS/W) 4 Oct 14, 2009 12:18 AM
Wanted Will trade for PZ F4U or T-28... WWIIace Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2009 11:41 AM
