I like the flights at dusk, now if I could just get some navigation lights on it
I got the wiring and the plugs that would work great for nav lights, but I need to find a good source for the LED's someone at work gave me some incredibly light weight wiring that is just a little thicker than a strand of hair, and it's shielded in white so it would hide well on the T28, I'll probably go looking for some micro LED's. one solid green a solid red, and a couple of flashing reds for anti collision beacons. one on the tip of the tail and the other one on the bottom of the plane. |
Marc |
I have a 10 foot wide by 100 foot long runway mowed into my front yard that lines up with my driveway, there's a 4 foot tall fence that parallels the runway, then kind of curves around the yard about 20 feet past the end of the runway, and I get a kick out of doing scale take offs and landings and watching the plane climb out against the back drop of the old fence and hay field beyond that. it just looks vintage, or something out of the old barn storming days, kinda cool. I like shooting touch and goes and making them look as scale as possible |
So...after my first fuse opening and learning how to cut out an over glued gearbox I got the thrust angle of the prop shaft lined up better than it came in the box. Out of the box the plane was unflyable without 3 grams of weight in the nose, the elevator trim all the way downward (forward on the TX screen ) and the battery all the way forward.
Now that the shaft is set down and to the right and the propeller plane matches the front of the cowl (the nose) I feel my T-28 flys a bit more normal. Still have to put the battery up all the way forward and give it elevator down trim but with out the weight in the nose it flys much lighter and at slow speeds floats a bit more so I guess I'm happy. Sure would like to check out another T-28 at a LHS to see how it's prop thrust angle is set. Thank you to all that took the time to give me advice. BTW Horizon was awesome on the phone, really very patient and helpful. Mike |
I'm going to try something different other then epoxy next time. |
| Thread Tools | |
| Discussion PZ Radian or PZ T-28????? | rclab1 | Beginner Training Area (Aircraft-Electric) | 10 | Jun 06, 2010 12:59 AM |
| Question Which is better for grass field pz t 28 or pz p51d bl | friz | Electric Warbirds | 25 | Mar 25, 2010 10:00 PM |
| Poll Which is better for grass field pz t 28 or pz p51d bl | friz | 3D Flying | 0 | Mar 22, 2010 08:20 PM |
| Sold TRADE PZ Corsair PNP for PZ T-28 | HBPD | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 14, 2009 12:18 AM |
| Wanted Will trade for PZ F4U or T-28... | WWIIace | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 12, 2009 11:41 AM |
