Any thoughts. Thanks. Mike |
Also, I'm wondering, instead of adding weight to the nose to correct this maybe I should do a elevator>throttle mix to correct the tendency to stall and hover with throttle increase? Thanks. Mike |
If you examine the box, you can see that the right thrust is accommodated by the packaging, which I thought was cool; and, by the angle of the front of the fuse, when viewed from above, which is also cool. I appears that the front of the cowl is also angled to the down thrust. Try shimming the motor so the shaft is perpendicular to a plane described byt the front of the cowling, vice the center axis of the fuselage. The prop arc then becomes parallel to the circle described by the LE of the cowl. I used this "rule of thumb" to success at the last engine change. |
Latest blog entry: SAFE: Something new from Horizon Hobby
Thanks for the advice. I've now noticed that the front of the cowl is shaped to the right and my propeller follows that OK. It's also shaped a bit downward and my prop definitely doesn't follow that. So I have no downward thrust and thus the plane acts tail heavy and climbs uncontrollably at half or more throttle. Lucky me, and it was the second one they sent as the first got smashed by UPS. Made for an exciting first flight.
Really don't feel like opening the fuse to shim the motor though, but a good side project when I do. I'm wondering still about the use of weight to correct my problem as opposed to a throttle to elevator mix? Mike |
Can't get Horizon Hobby on the phone this morning. Got to looking at my T-28 and the problem is definitely the angle of the prop shaft. The shaft is correct on the right pitch, but no down pitch. I believe the correct action would be to solve this instead of adding weight or mix to elevator. davidterrell80 suggested opening the fuse and shimming the motor. I haven't opened a fuse yet, but having owned 7 Walkera helicopters I have plenty of experience repairing micros.
Questions Is the motor shimmable? Or is it glued in tight? Don't want to do surgery on my new UM T-28 unless I can adjust the pitch of the prop shaft. Mike |
United States, PA, Butler
Joined Jun 2006
For the record, I've had my Trojan for over a year now and have had a Canadian dime glued inside the nose since getting it. I couldn't control it, nor could I get level flight without the dime weight. Everyone told me the same, I don't need the weight in the nose, but my experience is, the airplane is all over the place uncontrollable without it and with the dime, I fly nice, stable, and slow at 3 inches of height above the ground every night through my yard. |
Still the question: Is the motor glued in solid or is there a way I can shim the motor downward to get the proper shaft pitch? ![]() Mike |
\Mike |
Re cutting the motor loose... I was replacing the whole assembly but, if you just need down thrust, I'd try partially cutting the motor away, from the aft end and stick in 3/8-inch tips, cut from wooden toothpicks and coated with some RTF Silicone. I've been using the silicone to great effect, when installing the motors in several planes, powered by the same motors.
| Thread Tools | |
| Discussion PZ Radian or PZ T-28????? | rclab1 | Beginner Training Area (Aircraft-Electric) | 10 | Jun 06, 2010 12:59 AM |
| Question Which is better for grass field pz t 28 or pz p51d bl | friz | Electric Warbirds | 25 | Mar 25, 2010 10:00 PM |
| Poll Which is better for grass field pz t 28 or pz p51d bl | friz | 3D Flying | 0 | Mar 22, 2010 08:20 PM |
| Sold TRADE PZ Corsair PNP for PZ T-28 | HBPD | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 14, 2009 12:18 AM |
| Wanted Will trade for PZ F4U or T-28... | WWIIace | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 12, 2009 11:41 AM |
