Using 2.2 or even 1.7g Servos and an R415 RX would save about 6g... A 60g plane doesn't need 4g servos.
Removing the bellcrank and connecting direct to the servo arms would save another gram. Doing it that way is good if that what you have on hand, but if you are are going to have to order stuff anyway.... |
Latest blog entry: AR6400 guillows Space Shuttle
I third that.
When I assembled the new airframe, first thing I did was tape Cf rod along both leading edges. I do it with all my UMs right out of the box, even the F4U. Besides stability, it saves the wing. I flew it into a set of bleachers and a chain link fence (twice) last night, no damage whatsoever. Cartwheeled it too getting fancy, again, no issues. Before the mod, I would have had a mess of tape on it by the end of the night. |
msdumo, and others who use a CF spar on the main wing:
Do you use one long piece of CF and "poke" it through the main fuse? If so, do you put a slight bend in it or is this how you straighten the wing out? Any tips on getting it to poke through straight? Same question applies for the spar on the horizontal stab - poke it through? I'd imagine it would be easier as the fuselage is much narrower back at the tail. msdumo, also one more question for you - on your 2S conversion post, I see that you mentioned that you used a diode. I don't know that much about electronics (but I'm learning!), but I looked up what a diode is and its function, and I read that a diode works like an electrical "check valve", i.e. it allows current to flow in only one direction. Is a diode necessary for the 2S conversion, or are you just playing it safe? Thanks in advance. I really love my UM T-28, like others have said, I have many planes (I am up to 5 now, holy smokes!) and I am most proficient with, and enjoy flying the UM T the most of my fleet.
Horsham, PA
Joined Aug 2007
I did not put the rod through the fuse. Where the wings were flexing was about a third of the way to the wing tip. Since this was the problem I wanted to solve, I taped a carbon rod to each wing a bit back from the leading edge. The only reason I used tape was so that I could remove them easily if I did not like this modification.
Could you / is it advisable to do a 2S conversion without the diode? |
Canada, ON, Calabogie
Joined May 2011
I'm into kiting so I used a sliver from a broken carbon fibre tube. It would be around 1 x 4 x 400mm in size. Length is about 1/2 inch shy of each wing tip. I drew a line on the wing through CG point since this adds around 4 grams in weight. I pushed the carbon through the fuselage and glued it to the bottom of the wing with gorilla glue on the CG line. It took out most of the dihedral in the wing and really flattened the wing out. It still has some dihedral (~ 1/2 inch). It probably could have been less stiff and a little lighter but I like it. Looks awesome in the air. |
| Thread Tools | |
| Discussion PZ Radian or PZ T-28????? | rclab1 | Beginner Training Area (Aircraft-Electric) | 10 | Jun 06, 2010 12:59 AM |
| Question Which is better for grass field pz t 28 or pz p51d bl | friz | Electric Warbirds | 25 | Mar 25, 2010 10:00 PM |
| Poll Which is better for grass field pz t 28 or pz p51d bl | friz | 3D Flying | 0 | Mar 22, 2010 08:20 PM |
| Sold TRADE PZ Corsair PNP for PZ T-28 | HBPD | Aircraft - Electric - Airplanes (FS/W) | 4 | Oct 14, 2009 12:18 AM |
| Wanted Will trade for PZ F4U or T-28... | WWIIace | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 12, 2009 11:41 AM |
