View Poll Results: Add Another Option: BMN (Bare Minimum Necessities)
no batteries, no charger, and no tx! $59.99(BMN) 648 85.38%
were just asking for too much 111 14.62%
Voters: 759. You may not vote on this poll
Old Nov 16, 2011, 02:30 PM
johnd
1 Stoplight town East of Lansing, MI
Joined Aug 2006
So just killed about an hour looking, can someone please point me to a proven brushless upgrade for this T28? Mine's not quite dead yet, but I hate the gearbox thing...
Also, I have to say I'm surprised that my wing has developed a large crack at the root, halfway from trailing edge forward. I thought these things were supposed to flex easy without breaking? All I did was fly it, and not even crazy! Already have the tape to fix, and figuring on a carbon strip to minimize future issues..
jondon69 is offline Find More Posts by jondon69
Old Nov 19, 2011, 02:34 PM
Fly, crash, glue. Repeat.
Belgium, Walloon Region, Plombières
Joined Jul 2011
Originally Posted by msdumo View Post
Love this tough little bird. It has way more than 9 lives
Yes!
Great repair job, well done!
4x4rc is offline Find More Posts by 4x4rc
Old Nov 19, 2011, 03:56 PM
Canada
Energy's Avatar
Joined May 2009
Would the brushless setup used in the new eflite micros not work? Its expensive, but if you don't mind dishing out the cash, I think its a pretty good setup.
Energy is offline Find More Posts by Energy
Old Nov 19, 2011, 08:12 PM
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
http://www.rcgroups.com/forums/showt...t+mod+s+thread
Good thread on micro brushless up-grade, I did one in a Champ, the XP-7A esc works on both 1 & 2-S li-po's
mike3976 is offline Find More Posts by mike3976
Old Nov 21, 2011, 05:07 AM
Tom_1971's Avatar
Italy
Joined Jun 2008
Originally Posted by Tom_1971 View Post
Thanks to everybody for the amount of answers! I'll try it in the air, then and see. Hope to have some free time next saturday.
Bye.
My T-28 still flies but it's no more the same after the crash. It tends to go right and upwards, almost going to stall with 3/4 or so throttle. This is not so good, especially since I was to start doing some aerobatics... For slow flight is works still ok, but I get bored soon if I cannot try doing something more. Trim doesn't work that much, I think I should either
  1. Try to reshape the nose with steam as suggested, or
  2. try with some mix, I have in mind some throttle --> elevator mix as in my UM J-3 to prevent too much climb when increasing power.
I'll see, maybe the latter is the simplest to try, SW solutions are usually simpler than HW ones... as far as they work!
P.S. Changing the fuse is not an option for the moment. I'm wondering how could I remove and safely put in place again the sensitive stuffs, especially the motor and gearbox... I'm afraid that if the new placement will not be perfect, it could then fly even worse with the new fuse than it is doing now with the bended nose... mmhhh...
Tom_1971 is offline Find More Posts by Tom_1971
Old Nov 21, 2011, 05:26 AM
United States, MA, Rutland
Joined Oct 2011
Try not to correct flight performance issues with trim or other control surface changes - a plane should fly with surfaces neutral, and corrections should be made by moving the center of gravity if at all possible.
Since your repairs have you rebalanced the plane with the battery on? T-28 should be balanced inverted, remember. It should also be pretty well balanced upright too.
My T-28 had a pretty sharp left bank going and I noticed that when holding the spinner and rudder with a finger tip, the plane would tip left. I added a touch of clay to the right side and the plane is flying great once again. Just to reinforce that the CG balance is not just a fore-aft adjustment, many people overlook left-right balance.
If CG is spot on, then you may need to adjust the thrust - many of these little guys require the prop to point slightly down and to the right (2-3degrees) because of their slight weight. Given that you had to reform the nose quite a bit, this may be the issue, but it's an easy fix.
ScottGridley is offline Find More Posts by ScottGridley
Old Nov 21, 2011, 10:15 AM
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Great advise Scott. That is almost to the word what I would have said. haha, good show.
leethetreeguy is offline Find More Posts by leethetreeguy
Old Nov 21, 2011, 12:03 PM
F18
United States, MA, Onset
Joined Apr 2008
Scott...that advise is spot on!
F18 is offline Find More Posts by F18
Old Nov 23, 2011, 05:42 AM
East Midlands, UK
Joined Oct 2010
I have found, particularly with the Cubs, but maybe with the T28, that a frontal collision can sometimes change the thrust line.They are generally delivered with down and side thrust. Any raising of the thrust line promoted a climb, particularly as the throttle is increased.
RC1389 is offline Find More Posts by RC1389
Old Nov 24, 2011, 12:58 AM
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Mitsubishi t-28 Zero
Not content with buzzing around in a 1950s trainer while my friend ripped it up in his mustang I have begun Japanifying my T-28 after noticing it looks a lot like a Zero. I also read somewhere that the Comemorative Air Force has used real t-28s as zeros in their shows. If the T-28 is good enough for them, it's good enough for me!
It's probably been done before, but here it is. I've since removed the paint on the vertical stabilizer using scotch tape to peel it off, though I may make a new more rounded tail out of the takeout packaging from tonight's sushi. I found a Tamiya Zero decal sheet on Google images that I printed for the decals, they're even pretty close in scale, though it's not like it's hard making red circles! Anyways, I'm not sayin' it's a work of art, but maybe it's enough to inspire someone else to do a better job. I haven't worked up the courage to round the wingtips like on a real zero, I figure I need all the lift I can get with my flying!
Happy Thanksgiving.
eltreato is offline Find More Posts by eltreato
Old Nov 24, 2011, 04:51 PM
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
Happy Thanksgiving.
Nice Job, looks great
RTF Thumper is offline Find More Posts by RTF Thumper
Latest blog entry: Some very nice 3d work
Old Nov 25, 2011, 12:05 PM
Winder Ga
Joined Sep 2008
I think so too. Sweet. Lee
Old Nov 25, 2011, 12:42 PM
McCarthy, Alaska
Joined Jun 2004
Very nice. Thanks
WSEN is offline Find More Posts by WSEN
Old Nov 25, 2011, 01:48 PM
F18
Joined Apr 2008
Looks good as a tail dragger.....Zero!
A 3 blade prop from the UM Corsair or Mosquito would give a more scale look.
Ready for some air combat with your friends
Old Nov 25, 2011, 01:55 PM
eltreato's Avatar
Joined Oct 2011
EDIT: I wrote this moments before seeing your post F18 :-) Your suggestion is appreciated. I'll post up how it flies once I get the prop and spinner in the next couple weeks.
Thanks guys. I will be putting a Corsair prop on it so it has a triple blade like the real zeros, but man the blades are short compared to the T-28's. I suppose the third blade compensates for the shorter length. The Corsair prop should also offer more ground clearance with this tail dragger landing gear setup. The Corsair blade may also improve the climb rate at the expense of the cruising speed from what I've read.
On a separate note. I cannot wait to fly my first AS3X plane and I would love to see this technology in these micro warbirds SOON! I get so little time to fly, and when I do the planets need to align with the weather. I'd love to be able to take out the t-28 comfortably in a 5mph breeze.
Discussion PZ Radian or PZ T-28????? rclab1 Beginner Training Area (Aircraft-Electric) 10 Jun 06, 2010 12:59 AM
Question Which is better for grass field pz t 28 or pz p51d bl friz Electric Warbirds 25 Mar 25, 2010 10:00 PM
Poll Which is better for grass field pz t 28 or pz p51d bl friz 3D Flying 0 Mar 22, 2010 08:20 PM
Sold TRADE PZ Corsair PNP for PZ T-28 HBPD Aircraft - Electric - Airplanes (FS/W) 4 Oct 14, 2009 12:18 AM
Wanted Will trade for PZ F4U or T-28... WWIIace Aircraft - Electric - Airplanes (FS/W) 0 Jun 12, 2009 11:41 AM
