Old Jul 28, 2010, 06:10 PM
the rat is offline
Find More Posts by the rat
Joined Jul 2010
what shock oil should i use for the traxxas slash
i use 50 in the back and 50 in the front and i have two hole piston it keeps bottoming out help
the rat is offline Find More Posts by the rat
Old Jul 28, 2010, 06:50 PM
veggieslinger is offline
Find More Posts by veggieslinger
bashing on vancouver island
veggieslinger's Avatar
Joined Sep 2008
are you using the stock springs? ifso you will want to get stiffer springs to prevent bottoming out.
veggieslinger is offline Find More Posts by veggieslinger
Old Jul 28, 2010, 07:43 PM
vicovaludemero is offline
Find More Posts by vicovaludemero
vicovaludemero's Avatar
USA, NY, Cedarhurst
Joined Mar 2010
If bottoming out is your only issue this could be easily solved with a piece of silicon fuel tubing on each shock rod. All this does is prevent your shocks from fully compressing but still allows them to work throughout their effective range of travel... You don't even need to take your shocks apart.
It may take some tweaking to get it right but it does work, I do this on ALL or my RC cars.
If this sounds confusing I will post a picture for you, but I don't have one so let me know and I'll take a picture and post it.
vicovaludemero is offline Find More Posts by vicovaludemero
Old Jul 28, 2010, 10:44 PM
the rat is offline
Joined Jul 2010
thanks ill try it no need for pic but thank u for asking
Old Jul 29, 2010, 02:45 PM
jettrooper02 is offline
Find More Posts by jettrooper02
jettrooper02's Avatar
USA, WA, Bonney Lake
Joined Aug 2008
the other thing you can do is move the shocks in on the a-arms and out on the shock tower(if necessary).
jettrooper02 is offline Find More Posts by jettrooper02
Old Jul 29, 2010, 02:47 PM
USA, NY, Cedarhurst
Joined Mar 2010
That wont keep him from bottoming out, it will however increase body roll.
Old Jul 29, 2010, 02:49 PM
Joined Aug 2008
it will increase ride height which can help with bottoming out. also, is the car bottoming out from landing a jump or from accelerating? there's a big difference, jump bottoming out can be expected, but not acceleration.
Old Jul 29, 2010, 02:53 PM
USA, NY, Cedarhurst
Joined Mar 2010
Read this:
http://www.rc-truckncar-tuning.com/Shock-angle.html
It will explain everything...
And the root link which explains every aspect of suspension tuning:
http://www.rc-truckncar-tuning.com/r...on-tuning.html
Old Jul 29, 2010, 03:06 PM
Joined Aug 2008
well, i did what i suggested to my slash once and it never bottomed out, and it was high! huge travel, it just couldn't compress it enough to get it to bottom out from accelerating. just to much travel for it to bottom out.
Old Jul 29, 2010, 03:17 PM
USA, NY, Cedarhurst
Joined Mar 2010
Your right jet, it will increase ride height but thatís not all it will do. It will affect handling, and not for the better... It really depends on your driving stile, where you are running, terrain and last but not least how crazy you are about the perfect setup; some may not notice the difference, I do, so I'm just giving the best advice that I can from my point of view.
Ultimately in the end itís the end-userís decision...
BTW, I used to do the same jet, but then I learned more about suspension setup and got more into getting it to really do what I wanted.
Also, Iíll be the first to admit that occasionally I still use the quick fix like just raising ride height with spacers, but only when I'm feeling lazy.
Old Jul 29, 2010, 11:21 PM
the rat is offline
Joined Jul 2010
i got new shock because the traxxas big bores where broke so i got the Integy XSR2 Heavy-Duty Piggyback Shock and thes work great
Question Should I mix in castor, or just use after run oil? buechelr Engines 16 Jul 30, 2010 08:04 AM
For Sale FS: Shock oil, diff oil, charger, lipo batteries edu01jose Cars - Accessories (FS/W) 2 Dec 03, 2009 12:55 PM
Help! 1/5 rear shock oil? what and where? dragbikebam Motorcycles 11 Nov 22, 2009 10:29 PM
Discussion What should i do to my traxxas slash Traxxas12 Off-road Cars 8 Nov 15, 2008 08:45 PM
