Old Jun 24, 2003, 07:24 PM
Shawn Palmer is offline
Find More Posts by Shawn Palmer
Schumacher USA
Tampa FL
Joined Jul 2000
Tell us what YOU want!
The title sez it all - go nuts!
Personally, I want a 24 cell 70ish amp controller w/a BEC that will drive 6 standard size servos, but that's just me....
We strive to provide the cutting edge in an ever-changing industry, and Patrick's genius knows no bounds, so what's "on the horizon" as far as your needs go?
Shawn Palmer
Product Specialist
Castle Creations
www.castlecreations.com
Shawn Palmer is offline Find More Posts by Shawn Palmer
Old Jun 24, 2003, 09:37 PM
wattsup is offline
Find More Posts by wattsup
wattsup's Avatar
Canton, MI USA
Joined Mar 2001
Shawn,
How about:
a frequency channel scanner for under $75 or
a receiver with a built-in plane finder(beeper) or
a brushless controller that can handle twin motors or
an inexpensive Aiptek type digital camera control that plugs into the receiver or
a receiver that can be programmed at the field to any channel without having to change a crystal and weighing less than 10 grams or
a receiver that can identify a stalled or bad servo or
a receiver that beeps or flashes a light at turn on when there is interference on the frequency or the receiver power is low or
a receiver that can plug into a computer's USB port and be checked out for any problems by provided software or online by Castle Creations or
a brush/brushless motor ESC with digital real time power readout!
Regards,
wattsup
wattsup is offline Find More Posts by wattsup
Old Jun 25, 2003, 07:05 AM
Anks is offline
Find More Posts by Anks
United Kingdom, England, London
Joined Jun 2001
Simply a change to the 35 and 45 controller to make them 40 & 50 respectively, although I know the controllers are deliberately underrated if the both could be uprated it would certainly level the playing field. There are many motor combinations that draw around the 35 amp mark where jumping to the 45 would be wise but this is then not as cost effective as other 40amp controllers.
Anks is offline Find More Posts by Anks
Old Jun 25, 2003, 06:10 PM
locomoto is offline
Find More Posts by locomoto
locomoto's Avatar
San Pedro, CA
Joined Mar 2002
How about a Phoenix line that will smoothly and reliably start the new type of outrunner motors and some of the other European brands.
locomoto is offline Find More Posts by locomoto
Old Jun 25, 2003, 06:18 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
I guess I'm the only one that likes the line already without needing more!
boomer
boomerace is offline Find More Posts by boomerace
Old Jun 25, 2003, 06:34 PM
Schumacher USA
Tampa FL
Joined Jul 2000
C'mon boomer!
Are you that easily pleased?
Shawn
Old Jun 25, 2003, 06:38 PM
boomerace's Avatar
Joined Sep 2001
Originally posted by Shawn Palmer
C'mon boomer!
Shawn
That's just TODAY! I'm feeling mellow!
boomer
Old Jun 25, 2003, 08:08 PM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
OK, a big request, Smaller, lighter, cheaper, the Phoenix 10 and any of its smaller siblings. I want to get another Phoenix 10, but the Jeti 04-3 has some advantages, mainly price and physical size.... I run mostly really small BL motors anyway..
Looooeeee! is offline Find More Posts by Looooeeee!
Old Jun 30, 2003, 07:16 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
I would guess that we need higher advance on the brushless controllers to get more efficiency on the outrunner motors.
Also would like the Pixie20P to have a brake for flying S400 electric sailplanes with folding props. Yes, you can get the Sprite25, which has the brake, and maybe this is what the Pixie20P with a brake would end up weighing anyway.
10Thumbs is offline Find More Posts by 10Thumbs
Old Jul 01, 2003, 09:38 AM
Schumacher USA
Tampa FL
Joined Jul 2000
I'll post this again elsewhere about the outrunners in more detail, but our controllers DO automatically run the outrunners at a high advance (28 to 35 deg depending on the motor).
Loooeee - Smaller lighter Pheonix 10 you say? You got it! Going into production in a month or two....
Shawn
Old Jul 01, 2003, 10:38 AM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Shawn
Since the cat is out of the bag -
I saw this ESC some weeks back and it looks really nice, light and small. You will be very happy with it I am sure.
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jul 01, 2003, 01:23 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Shawn,
I would like to see analysis and options for running an AXI 2820/10 with the Phoenix 45.
My setup runs roughly in the low and mid-range, but smoothly at full throttle. I tried a few tweaks with the timing and switching frequency, but the problem just became apparent at different RPMs.
This is currently OK for me, because I am using it in a sailplane application. But I plan to use it in a sport plane soon - and will them require smooth operation over the entire throttle range.
Paul
FlyingW is offline Find More Posts by FlyingW
Old Jul 01, 2003, 01:29 PM
Schumacher USA
Tampa FL
Joined Jul 2000
FlyingW - ongoing research is happening w/most outrunners right now - solutions forthcoming.
Shawn
Old Jul 01, 2003, 03:47 PM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
I'll check here periodically.
Paul
Old Jul 02, 2003, 10:36 AM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
With the new USB programmer that is coming, I want the ability to set whatever LVC level I want rather than only choosing among a handful of choices.
I'd also like it to have the ability to update the firmware when newer stuff becomes available.
In other words more features than just what you can now do with a transmitter.
GBR2 is offline Find More Posts by GBR2
Tell me what you think, please Wolfman Power Systems 5 Dec 17, 2003 03:23 PM
Discussion Tell us how you really feel Mr. Kerry.... Arbo Life, The Universe, and Politics 2 Dec 09, 2003 08:33 PM
C'mon guys, tell us where you're from. Highflight Site Chat 0 Nov 07, 2003 08:50 AM
Show us what you are building! balsaman Sport Planes 87 Feb 10, 2003 10:19 AM
Awesome "Mini" Laptop tell me what you have to trade Spin_Doctor Aircraft - Electric - Airplanes (FS/W) 8 Dec 17, 2001 11:11 AM
