Old Feb 19, 2012, 03:11 PM
clearprop88 is online now
Find More Posts by clearprop88
Joined Apr 2011
@Bad400
Good analysys of motors, thanks.
All motors are designed diferently, some are more efficient than others.
An efficient motor is one that has low heat loss.
In converting electrical energy into mecanical energy, one of the products of the conversion is heat. This is wasted energy. I squared R losses occur in all electronis systems.
I have several Walkera heli's that use innefficient motors, and ESC's that are inadequate to handle the current required by the motor. Sometimes they brownout, other times they just drop to the ground. I've replaced the ESC's with higher current rated ESC's, and they work just fine, and run much cooler.
I'm not a Walkera basher, quite the opposite. I think they put out a good product, but their motors, and ESC's leave something to be desired.
Anyway, I'm looking for a better motor because I like this heli.
clearprop88 is online now Find More Posts by clearprop88
Old Feb 19, 2012, 03:20 PM
bad400 is offline
Find More Posts by bad400
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
maybe this motor will work http://www.cnchelicopter.com/servlet...ushless/Detail
i had it with a 13t pinion in one of my 450`s, wasnt a big block nitro injected v8, but it wasnt a dog either.
bad400 is offline Find More Posts by bad400
Old Feb 19, 2012, 04:00 PM
Joined Apr 2011
Looks good , and the right size shaft.
Thanks for the tip.
Old Feb 19, 2012, 07:54 PM
HeliFlyer711 is offline
Find More Posts by HeliFlyer711
♘ Heli's Lives Matter ♘
HeliFlyer711's Avatar
United States, PA, Philadelphia
Joined Oct 2009
Align DS410M's on the V450
Put DS410M's on the V450 cyclics, now Im actually glad i didnt sell this heli. One word.......SOLID
No more vibes and winceing while flying wondering if those Walkera servos were gonna give up the ghost at any time, or watching the heli wobble with the gains turned up. It has the cyclic power now to do hard punchouts and the swash moves smoothly with the 3 axis without that jerking movement from the 09's metal gear slop.
Lesson learned;
If spending 80 bucks on a set of 09's might as well spend 100 on the DS410m's. or the Savox equivalent. One thing to be aware of is in order to keep the stock geometry and your radio settings is to drill a hole 10mm on center from the servo spline on the DS4 servo arm, the servo rod sits back a few degrees instead of it being straight up and down with the walkera 08/09 servos. But only on the front Aile and Pit, Elev stays straight. Other than that they are a drop in fit for anyone looking to put these in.
HeliFlyer711 is offline Find More Posts by HeliFlyer711
Old Feb 19, 2012, 10:24 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
FYI - the WK-09-9 are ~$20-30 overpriced at WOW. You can pickup a set from Helipal for $50 plus shipping. The quality remains the same though.
thwaitm is offline Find More Posts by thwaitm
Old Feb 20, 2012, 02:44 PM
Heli Biggie is offline
Find More Posts by Heli Biggie
They call me plan B
Heli Biggie's Avatar
United States, GA, Covington
Joined Mar 2011
2650 mah blue lipo
These batteries really make the heli wake up. As if it needed it.....l but then i tryed to swap my main blades to some white ones and my wobble came back really bad. I guess it could be the blades needing balancing. But i had this wobble when it was brand new . I turned my gyros down to make flyable, should i turn them down more. What is everyones rx settings. But my gyros on my smaller helis are turned up more than this one,
Heli Biggie is offline Find More Posts by Heli Biggie
Old Feb 20, 2012, 05:30 PM
Joined Apr 2011
How does it like the added weight?
They weigh about 100g more than the 2.2 amp ones I'm using.
Do they fit under the stock canopy?
I have my gyros set at 12 O'clock. Right between the - + signs. It fly's great, no wobble, hunting or vibration.
Old Feb 20, 2012, 07:29 PM
They call me plan B
Joined Mar 2011
It dont care about the weight, thats for sure, its a very snug fit , i put tape around canopy to not have any problems, i think my wobble may have been a servo bolt missing, and then i broke off a swash ball
Thanks for rx settings
Old Feb 20, 2012, 10:37 PM
Torch8 is online now
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Originally Posted by Torch8 View Post
Tail wagging after changing main blades from stock to Align 325 carbon? Gyro rate was at 80%, it wag even when lowering it to 60%. I don't want to go back to stock main blades because the Align 325 are suppose to break upon impact causing less damage to heli.
Finally got rid 99% of tail wag, by lowering gyro rate to (works good at 65 and 70%). Just weird that tail wag after changing main blades to shorter Align 325 blades.
Torch8 is online now Find More Posts by Torch8
Old Feb 21, 2012, 05:28 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Remember the whole initial purpose of the tail rotor is to counter the torque generated by the main rotors (and to then be able to alter it's own output slightly to 'allow' the tail to yaw on command also).
So it doesn't surprise me a lot that changing main blade size (or weight or profile) might impact what the gyro (and therefore the tail) does, unless it is 're-tuned' for the changes.
tracknoob is offline Find More Posts by tracknoob
Old Feb 21, 2012, 09:31 AM
Torch8's Avatar
NYC
Joined Aug 2010
See, ok I understand it now, anyone using Align blades and what are your gyro rates on it? Mine set to around 65%.
Old Feb 21, 2012, 09:34 AM
usmonkey is offline
Find More Posts by usmonkey
Joined Feb 2011
Mainshaft Alternative?
Dear All,
Any idea if other brands of main shaft will fit this bird?
Trex 450 perhaps?
Thanks!
usmonkey is offline Find More Posts by usmonkey
Old Feb 21, 2012, 02:35 PM
Joined Oct 2009
Thats ashame, what can you say........I guess I got a bad batch of Walkera servos. Out of the original 3-08's that came with the heli 2 still work and are actually tighter than the 09-MG's, out of the 3-09's i bought for 80 bux, all 3 burned out the fet driver board, which is a non repairable board. I tried to do a fet transplant to fix them, but the board is so cheap the traces just burn off with the slightest amount of heat.
When I took apart the DS410m, inside you find that there is a decent circuit board circa 2010 with good soldering, the POT and the motor are hard soldered to the circuit board, so no undergauged thin wires are stuffed in the case. This eliminates any extra wireing beside the 3 servo input wires. With the walkera servos the soldering was poor, very poor, and there were a few close calls with shorts from the hand soldering done at the factory. The motor and pot are connected to the main boad via these thin red wires that get jammed into the servo case and its just an accident waiting to happen if you ask me. On that famouse hoopla advertisement what they dont show you is the back of the servo where all the wireing mess is.
Guarenteed way to burn out at least one of your WK servos........go in to throttle hold and move the pitch and cyclic sticks up and down side to side agressively and continuously for 30-60 seconds, watch the RX start to blink and finally shut off from the shorted servo. Thats how easy it was to burn out 4 of these WK 08/09 servos. Did the same test with the 410's and no problem, head is nice and smooth.
One good thing, at least the WK-2702V had short protedtion circuitry as it still works fine after 4 burnt out servos.
If i cant run the servos at full collective and cyclic for 30 seconds on the bench, I dont trust the heli as safe to fly I had a belt CP come at me once when a servo died in mid air and since then im slightly paronoid with cheap servos.
That's my 8,600 cents worth.
Old Feb 21, 2012, 04:21 PM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
Nice, in-depth, servo pro's n con's post. I also had one 09-8 servo die in the box. I replaced all the originals with 09-9s but haven't flown it much since and from what you're saying maybe its a good thing. I do have some Savox servos for it and I had no idea the insides were so different.
Even a well set up heli vibrates a bit and fewer flapping wires in critical control components seems like the right way to go.
On a 120 it's not such a big deal but a dead 450 coming your way in a hurry is not a good thing.
Old Feb 21, 2012, 04:27 PM
jhebbel is offline
Find More Posts by jhebbel
"Watch this!.... Oh crap"
jhebbel's Avatar
United States, FL, Seminole
Joined Jan 2012
Can someone send me the sports setup for the 2801? thanks
jhebbel@gmail.com
jhebbel is offline Find More Posts by jhebbel
Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 07, 2010 08:03 PM
Discussion Walkera 4#6 or Walkera 4#6s? red_storm Micro Helis 8 Jul 07, 2010 12:17 AM
Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? tumble2k Micro Helis 7 Mar 26, 2010 07:30 PM
For Sale Walkera 68 & Walkera 36 Parts bretware Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 05:23 PM
Wanted Walkera Lama2 or Walkera 5G6-1 night_life Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 04:20 AM
