Old Dec 29, 2010, 04:50 AM
koshka is offline
Find More Posts by koshka
Joined Jan 2009
Originally Posted by wowhobbies View Post
This is the difference between this receiver and the RX2610S/V. The receiver must be setup specifically for the WK2801pro you are going to be using. The same settings are no good when exported to another radio. The set button is used to identify the mode under which it's been set and to memorize the end points of the sticks. The flashing sequence is confusing because some of the mistakes in the original manual.
Jonathan
WowHobbies.com
Thanks for your reply. How to use the set button in your user manual is written? When I turn on the receiver, aileron servo are not takes its lowest position.
koshka is offline Find More Posts by koshka
Old Dec 29, 2010, 11:10 AM
nycheli is offline
Find More Posts by nycheli
This is correct. The receiver firmware was updated and Walkera engineers did an excellent job on this with the help of the DKfuji report. The tail servo has some over heat problem but now it runs like a champ at .08 speed. The hardware failure report was generated by a Taiwanese Pro who has also greatly contributed.
Jonathan
wowHobbies.com
Hey Jonathan... My heli is in that 1/5 batch and I'm really looking forward to it. I just want to clarify... The latest batch with the new firmware corrects the tail servo failure issues? That seems to be a really common complaint among owners of the first couple generations of this heli.
nycheli is offline Find More Posts by nycheli
Old Dec 29, 2010, 02:39 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
I have sent my Tx settings to another member here and I thought it might help if I post them here.
Here are my settings:
Revers: Elev - Norm, Aile - Revs, Thro - Norm, Rudd - Revs, Pit - Norm
Subtrm: All "0"
Trvadj: All 100%
Swaats: Swashmix -> Elev - 70%
Aile - 70%
Pit. - 65%
Gyrhld: Gyrosens -> Gyro/Aux2 -> 0: 80%
1: 20%
DR&Exp: Elev -> Pos-0 ->D/R 100%
Exp +45%
Aile -> Pos-0 ->D/R 100%
Exp +45%
Rudd -> Pos-0 ->D/R 100%
Exp +35%
Curves: Thrcuve -> Norm: 0-25-90-95-100
St-1: 90-90-90-90-90
St-2: 100-100-100-100-100
Pitcurve -> Norm: 33.5-41-50-75-100
St-1: 0-25-50-75-100
St-2: 0-25-50-75-100
Hold: 0-25-50-75-100
That is what I am flying with and she is awesome. Make sure that you program a new model number (not changing an existing one). Also, follow the set-up of the gyro very carefully. The entire set-up must be done in order for the 3 axis gyro to work correctly. Hope this helps.
dkfuji is offline Find More Posts by dkfuji
Old Dec 29, 2010, 04:52 PM
Teckos is offline
Find More Posts by Teckos
Teckos's Avatar
Joined Jan 2009
Sounds like she's a must buy! Hey Darryl, would you say she flies as good as your TRex450? Is the motor powerful enough and do the align blades fit in? Cheers!!
Teckos is offline Find More Posts by Teckos
Old Dec 29, 2010, 07:18 PM
ri0grand is offline
Find More Posts by ri0grand
Addicted Again
Wylie TX
Joined May 2009
Subtrm: All "0"
Trvadj: All 100%
Aile - 70%
Pit. - 65%
1: 20%
Exp +45%
Exp +45%
Exp +35%
I see you have your Gyro 1 setting at 20%. Are you able to get the 2702V to work in a Rate mode?
ri0grand is offline Find More Posts by ri0grand
Old Dec 30, 2010, 01:00 AM
dkfuji is offline
The OC, California
Joined Feb 2007
IMO, she flies as good as my T450 FBL 3G set-up. The stock motor is surprisingly strong and is able to do 3D. I have done loops, rolls, flips, inverted, climbouts and tic-tocs with her. Not bad for an unmodified model from Walkera. It comes with Stealth CF blades so yes the Align mains will fit as well.
Old Dec 30, 2010, 01:03 AM
dkfuji is offline
The OC, California
Joined Feb 2007
I only use this for set-up purposes only. Once I have the tail neutral and the feel is where I like it, I always fly in HH mode. Just my personal preference.
Old Dec 30, 2010, 05:18 AM
nycheli is offline
Can you post a video... We'd love to see it in action! There are only a few v450d01 vies out there right now and most are pretty old.
Old Dec 30, 2010, 11:53 AM
Teckos is offline
Teckos's Avatar
Joined Jan 2009
Yea, and also lend her to Manny please for the video
Old Dec 30, 2010, 12:44 PM
dkfuji is offline
The OC, California
Joined Feb 2007
I will do what I can to get her to him for a "real" test. LOL.
Old Dec 30, 2010, 01:14 PM
ri0grand is offline
Addicted Again
Wylie TX
Joined May 2009
Old Dec 30, 2010, 02:20 PM
Teckos is offline
Teckos's Avatar
Joined Jan 2009
I'm sure you're qualified enough to conduct a "real" test Darryl I meant more a "hardcore" test
Old Dec 30, 2010, 04:48 PM
ri0grand is offline
Addicted Again
Wylie TX
Joined May 2009
So do you set up the tail pitch in Rate first (negative pitch)? Or do you just set up HH with zero pitch? It seems to work either way....
Old Dec 30, 2010, 06:29 PM
thloh85 is offline
Find More Posts by thloh85
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
So, the tail hold perfect? Even in 3D? That's a rather great surprise... Sounds like Walkera is getting a hang of this industry and will push Align/Protos price down
thloh85 is offline Find More Posts by thloh85
Old Dec 31, 2010, 12:54 PM
martin_ is offline
Find More Posts by martin_
Joined Sep 2010
What Futaba and Ino-Lags servos did you try for the tail?
Did the Align servos you used need to be reversed? I know the ones I have are reversed relative to the Walkera ones I have had. If you had to reverse the direction, the Gyro would need to be reversed too. There are switches on the 2702V to do this. When you tilt the heli, the gyro should tilt the swash in the opposite direction. If the Gyro needs reversing it will tilt the swash in the same direction as the heli is leaning which obviously will cause big problems.
And do not forget to interchange mechanically AIL/PIT servo when you switch ELEV R. gyro function, because that switch only affect the ELEV servo itself, not the function.
martin_ is offline Find More Posts by martin_
Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 07, 2010 08:03 PM
Discussion Walkera 4#6 or Walkera 4#6s? red_storm Micro Helis 8 Jul 07, 2010 12:17 AM
Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? tumble2k Micro Helis 7 Mar 26, 2010 07:30 PM
For Sale Walkera 68 & Walkera 36 Parts bretware Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 05:23 PM
Wanted Walkera Lama2 or Walkera 5G6-1 night_life Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 04:20 AM
