http://heli-heli.com/items/electroni...7mg-detail.htm http://heli-heli.com/items/electroni...7mg-detail.htm |
United Kingdom, England, Devon
Joined Sep 2011
On this subject I installed 2 grommets today on my V450d01, as an experiment I used the rubber dampers that fit inside the main rotorhead. I had one spare and merely cut them in half and fitted them to the aileron and pitch servos. The shake has now completely gone. The 09 metal servos do seem to be poorly made as they have a lot of backlash in them. I intend to fit 'o' rings when I source them as someone here as already done. Jim |
What i found was that I could find servo dimensions that would fit the V450D01 but the new servo arm was either too far out, in, up or down to preseve the 90* angles of the links to the swash. That would mean modify the frame or lose geometric setups. Thanks for the links, it be nice if he could post a picture and some tips for us here if possible. |
Joined Aug 2010
My black Airwolf spun out and crashed due to a bad rear rudder servo. Had to replace the fuselage but the stock metal cyclic servos held out and no other damage. WOW hobbies carries a rudder servo for the V450D01 which is not stock, which I am trying now.
As for the fuselage, two different ones were available at LHS. The Align MD500 definitely does not fit (I bought the V450 mechanics to the store to try it out) even after relocating the Rx and rear servo to fit better under the boom. The Align Black Airwolf was chosen, but it is not as black as the one from the last time I bought, perhaps from RC Aerodyne. This could be trouble when the time comes to touch up with black paint but for now I am happy with it. Oh, something else I discovered about the V450; the thing will act crazy, spin, tilt over on the ground and will never take off if the rudder servo arm is swinging the wrong way. Reversing the TX control will not help. I found this out when I re-installed the new servo and had the arm centered pointing up instead of centered pointing down. |
Japan, Tokyo
Joined Jun 2011
Urrl, I know what you mean with installing stuff reversed. I now like to take a few snaps with the phone before I muck about with the servos/linkages. I had the Mode 2 PIT-AILE issue and couldn't understand how it was possible having triple checked the manual.
I sometimes wonder how impossible it would be to fly with the throttle and elevator linked together... one to try in a sim! I guess it might be possible in idle up with a little brainware update. |
Long Island NY
Joined Sep 2010
I just took a look at my V450 which is stock except for the metal gear servos and my tail servo has the arm pointing down, it flies fine...
Joined Sep 2011
New tail servo for V450d01
I fitted a new Align DS520 servo to my V450 today and after 3 ten minute flights the servo remained cool. I have had 3 stock servo failures with this heli with all of them burning-out. The stock servo was always hot to the touch after a flight so am hoping the Align one will be an improvement. The DS520 drops in as it shares the same 4 screws as the stock unit. The tail gyro reverse dip switch needs changing on the RX2702 and the rudder reversing set in the transmitter. Tail hold is perfect, but I have to say the stock servo was also good in this area when it worked.
Now to sort out the rubbish cyclics ! When this is done the V450 will be a truly superb helicopter. Jim |
Joined Sep 2011
Hey guys,
New to electric RC helis (but i've had larger nitros for awhile), and just got this heli for $75 . Some kid thought it was a toy, crashed it, and now his grandfather sold it to me for a cheap price. I'm trying to fix it up since i've long given up on nitros but was wondering if you guys could give me a hand with diagnosing it. http://www.rcgroups.com/forums/showt...3#post19388502 i figure i'd start a new thread for it so it doesnt disturb what's going on here. Any help would be appreciated. |
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
