Old Aug 04, 2011, 12:34 AM
thwaitm is online now
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Hi Alex, I think I had the same problem and in the end the solution is just to swap the plugs on the receiver if you follow the manual's locations for the servos. Pit and Aile are reversed.
It should make things work properly again.
Good luck!
thwaitm is online now Find More Posts by thwaitm
Old Aug 04, 2011, 12:37 AM
HeliFlyer711 is offline
Find More Posts by HeliFlyer711
♘ Heli's Lives Matter ♘
HeliFlyer711's Avatar
United States, PA, Philadelphia
Joined Oct 2009
Yes thats true, I had this problem also, almost sent my RX back to the dealer because of it. The manual is wrong....
HeliFlyer711 is offline Find More Posts by HeliFlyer711
Old Aug 04, 2011, 12:44 AM
Alex1971 is offline
Find More Posts by Alex1971
Joined May 2011
Thanks guys, I was thinking the same way.
Alex1971 is offline Find More Posts by Alex1971
Old Aug 04, 2011, 04:51 AM
Team WarpSquad
Joined Jun 2011
I actually started to rewrite the manual in English and with corrections but I ran out of energy to complete the job!
Old Aug 04, 2011, 02:01 PM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
Hay guys Tom Z needs the settings for v450D01 so he can post on his setup guide.
vronny is offline Find More Posts by vronny
Old Aug 06, 2011, 08:14 AM
badbob10 is offline
Find More Posts by badbob10
Carbon Z Cub, Stearman, Splend
Long Island NY
Joined Sep 2010
Tracking
I had the strangest thing happen, I had my heli set up with perfect tracking, I brought it to our flying field, (about a 30 minute drive) I had it in the trunk of my car along with another heli and a Piper cub. I always lash the two heli's to the side of the trunk to keep them from falling over. I didn't fly the helis at the field but I decided to fly it when I got home , the tracking was way off, how did it change just sitting in my trunk??
badbob10 is offline Find More Posts by badbob10
Old Aug 06, 2011, 10:48 AM
Team WarpSquad
Joined Jun 2011
The gravity of the moon?
If it can pull the sea about surely it can manage a little Heli!
That said, it's more likely to be temperature related I guess. As your Heli warms up or cools down in the trunk I guess parts can move, flex or creep and then when you come to fly later it's cooler and bits are shrinking but others are not moving back to their original starting points.
Don't you just love physics? :-)
Old Aug 06, 2011, 11:16 AM
badbob10 is offline
Long Island NY
Joined Sep 2010
Thanks for the explaintion thwaitm, that's what my wife said....but that was not it, as soon as I saw how out of wack it was I put it back in the house and it sat overnight in it's normal, airconditioned habitat. If it was the physics then this morning it should have gon back but it was still way out, I'm talking about over an inch! I checked the feathering shaft, pitch, all the links, rotor blades etc..and then finally adjusted the control links and brought the tracking back to where is should be. She's back to normal but I'm still baffled. Thanks again for your explaination. Happy Hovereing!
Old Aug 06, 2011, 07:42 PM
Team WarpSquad
Joined Jun 2011
Well that is very odd then isn't it! Did you check the trunk for Gremlins?
What sort of main blades are you using? There's always a possibility with wood or resin that humidity might make a difference, but there again you'd expect the air-conditioned hangar to have sorted that out. How hot was your trunk? No chance that the blades were heated and suffered a subtle but permanent deformation? Though an inch is a long way out of whack. I'd be curious to hear if it stays sorted or it happens again.
(I studied Materials Science whilst at college).
Old Aug 06, 2011, 09:25 PM
urrl is online now
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Flew this morning and evening. Wish I had the video cam this evening; it wasn't raining but a humongous flash of veined lightning flashed behind it in the distance while the 450 Air Wolf was in flight; would have been a great shot. Left after my second pack.
Edit: three packs this morning. Adjusted landing gear retract travel in Tx after noticing the servo was straining, trying to travel past its limits causing it and the ESC to overheat; at least that's my theory. So far no more overheating problems. Noticed the tail cone was loose in this video. A bit of Gorilla Glue on the tips of the screws should keep them from loosening during flight vibration.
Airwolf7_11.wmv (2 min 25 sec)
urrl is online now Find More Posts by urrl
Old Aug 10, 2011, 07:37 PM
DEWorley is offline
Find More Posts by DEWorley
Joined Feb 2002
guys, i installed a cc phoenix ice 50 esc & i'm thinking of trying the govenor mode, it lets you set 3 rpm targets. i have the stock motor & 2200 25c batteries, what would be good rpm settings for the 3 flight modes? i'm still trying to master basic forward flight.
DEWorley is offline Find More Posts by DEWorley
Old Aug 13, 2011, 02:54 AM
Team WarpSquad
Joined Jun 2011
It'll buff out...
So I was getting all confident having managed a battery and a half, plus one on the V200 and things were going well... then fwwooomp!
I wanted *right* but my fingers said 'more left?' and in she went, main rotor first. I have it on video so I'll upload to YouTube later.
In the meanwhile... do you think I need to replace the main shaft or can I bend it back straight... same goes for the boom... they're only a little bent. Bit a duct tape on the red blade and we'll be flying again in a jiffy.
Now where did I leave the chisel - just need to carve those missing teeth back into the main gear...
Old Aug 13, 2011, 05:53 AM
Team WarpSquad
Joined Jun 2011
The walk of shame... (0 min 51 sec)
Old Aug 13, 2011, 07:19 AM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Ouch.. sorry to see, but that was an impressive "Thump" sound when it hit the ground!
I would say for sure replace the main shaft, as that will be tough to get straight
ViperZ is offline Find More Posts by ViperZ
Old Aug 13, 2011, 11:10 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by thwaitm View Post
fwwooomp!
Ah, %$#@!^&*#!
I feel for ya, man.
tracknoob is offline Find More Posts by tracknoob
Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 07, 2010 08:03 PM
Discussion Walkera 4#6 or Walkera 4#6s? red_storm Micro Helis 8 Jul 07, 2010 12:17 AM
Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? tumble2k Micro Helis 7 Mar 26, 2010 07:30 PM
For Sale Walkera 68 & Walkera 36 Parts bretware Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 05:23 PM
Wanted Walkera Lama2 or Walkera 5G6-1 night_life Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 04:20 AM
