Joined Aug 2010
An added note concerning those batteries I mentioned from Value Hobby, I flew around for about 6 minutes, then hovered close for an extra 2 minutes before the motor showed signs of decreasing speed and battery run down. So 8 minutes with a full fuselage. Meanwhile the new stock battery seems to be showing signs of swelling. I've been running all of these batteries for about 5 minutes, including landing time. I may order some more of these 30C batteries from Value Hobby since they are only about $19 a piece. They do a great job IMO.
![]() I notice the stock battery has no specs at all on the label. |
Stock battery is 2200mah/25c, on my stock pack......its written in black on the opposite side of the silver lable. Since its black on black its hard to see.
Some really good packs you might consider are the GensAce brand from hobbypartz.com, they also offer free priority shipping with an order over 25.00. They are getting rave reviews from other pilots who use onboard data-loggers to test thier power systems in flight with graph analysis. I buy all my generic batts from them now, and the name brands from the LHS (Voltz) which are a little more. Gone are the days of ThunderPower 70.00 a pack 2200/45c's. These Gensace are almost as good and the voltz are just as good IMO & can give 100's of cycles if treated right. Plus they can be charged at 5c. ![]() http://www.hobbypartz.com/gensace3s25c.html |
Unfortunantly they just bumped up thier free shipping to 50.00 minimum order
, it was 25.00 a month or so ago, but i think they do a flat 4.95 rate for batteries. I would be curious to see what your results are with these, they have a 2600/25c that might work better with the fuse you have. Honestly though you should probably be running a 45c for the extra headroom so your not frying the lipo with the extra fuse weight. My most recent improvement to the V450 was to mount the esc under the battery tray to shift the COG forward, because stock out of the box the V450 seemed tail heavy to me. So I had to mount the battery forward and that caused a problem with getting the canopy on. Now I can put the battery all the way up & back towards the servos and theres room to spare for a longer lipo. |
Tampa,FL
Joined Dec 2003
I'm using hobbypartz'z sky lipo 2200mah 40c packs and they seem to work well, just a little warm after a full run.
Japan, Tokyo
Joined Jun 2011
Nearly had a whoops moment today as I made a collective pop... turns out having a higher head speed is indeed quite important!
The torque got away from the tail and it nearly paid a horrible visit to the graveyard behind my flats as you shall see briefly if you watch this:
New pair of shorts please. I increased the curve 10% throughout and it improved back to the original behaviour and I later discovered that in idle-up 1 the tail was totally solid. Otherwise, things went well today, I used the swash leveller tool I finally received today after it having made a stupid world tour before arriving at my place, I used the similarly well travelled pitch gauge to check my pitch (-8/+8) and flew 2 packs without a crash (just). Looks like it's time to go to the field and learn to fly this thing. RE: recent posts... Hand turn head rotations. On mine, I can get about 5 or 6 full rotations out of a fast hand windup of the head. As long as that one way doesn't stick then it all spins quite nicely. Batteries. I'm using the stock 2200mAh 25C plus 2 STORM 2200mAh 35C. They all come in warm +40C (though it is +30C in Japan at the moment). One STORM appears to have some gas build-up after 5 cycles. I just got a Turnigy 2200mAh 40C which I have yet to try. It seems, despite the Gens Aces being made next to Hong Kong it's nigh impossible to get them here and shipping back from hobbyparts means I need to buy about 10 or more to make the postage remotely bearable. What sort of voltage are you all getting after a flight? I'm down around 10.8V and I'm wondering if I should reduce my flight times by 30s/1m to stress them a little less. |
Japan, Tokyo
Joined Jun 2011
I just found this:
http://www.4-max.co.uk/pdf/What%20th...Po%20cells.pdf Seems an nice concise guide to the information which is available but often not all in one place. |
Joined Aug 2010
Thanks for sharing that info thwaitm.
My camo full fuselage V450 was overheating and going out of control after about 2 to 3 minutes in hover. I looked at the WOW setup sheet and adjusted almost everything back to specs and it no longer goes out of control. Notably out of spec was a high pitch curve. Stock ESC's have no heat fins on them. don't know why. I need a water cooled ESC. |
Japan, Tokyo
Joined Jun 2011
I took the advice of HF711 and got myself a 60A ESC with 4A BEC.
http://www.hobbyking.com/hobbyking/s...dproduct=10942 I installed it last night under the battery tray as per your suggestion Urrl. I hope to take it out today or tomorrow to see how it flies. It has logging capabilities (I'm a bit of a geek for graphs) so I'll be curious to see how many amps this is drawing. For those with the GE Power B6 type chargers out there and it appears to work fine for others, on the battery charging logging I suggest 'Logview V2'. Donationware. http://www.logview.info/cms/e_logview_info.phtml It's great software though it helps if you know a bit of German as not everything is correctly translated. Though for functionality it's by far the best logger I've seen and it's as cheap/expensive as you wish to donate. |
Lipos are a highly debated suject, but theyve come down in price so much now that really if you fry a 15.00 battery in a season........no one really gets upset about that anymore When they cost 70.00 a pack though people got heated. Personally, with the V450 I fly with a 5:00 min timer set on a 2200/25-45c and try not to go below 11.1v per cell end of flight. A lipo will rebound slightly a few .v's so if you go a little below it's ok. But remember its not so much what the battery is doing when you land but what is happening in the air, which under load the battery could be reaching close to 9V or 3v per cell.......way less than what you read when you land on a meter. I have some Turnigy 2200/25c's from last summer with 100+ cycles on them that still give a full power 5 min flight. ![]() That PDF you posted is great info, the only part that is outdated are the C ratings for charge rate, most batteries today, even the cheap ones can be safely charged @ 5c (Always Check the Lable). It will however still degrade the life of the battery, the lowest C charge you can do will always be the best. At the field when im flying I do a 2.5 C charge rate on the 2200's or 4.8A, but at home I will do a .800mah charge or less than 1/2 C to extend the life of my lipos. A 2200mah 11.1v lipo @ 5C = 11A max charge, which would get your lipo fully charged in about 15 min's or less. Proper C rating for the application, flight times and charge times will get the most out of your lipos, also storing them at 3.82v per cell in the off season or in between flights ( over 48hrs) is recommended by many. With some of the Cheaper Chinese cells it is normal for the lipo to swell a little during discharge and then go down after about 1/2 hour back to normal. The one last thing to mention is the power system on the V450 IMO is underated. They use a 40A esc with a 3A Linear BEC to power all the digital servo's and the RX, The 40A is ok and so is the 3A Bec, the issues is that the BEC is linear and not switched and this can generate a Ton of heat. Or excessive draw on the lipo, plus we all know how hot the stock motor gets By using a 60A/3A switched ESC, the motor still gets hot but the lipo stays within range after a 5 min flight.
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
