m2x12: helidirect.com/esky-m2x12-hex-head-screw-10pcs-hb-cp3-p-16854.hdx m2x14: helidirect.com/compass-cap-head-bolts-m2x14-warp-360-p-29232.hdx m2x16: helidirect.com/compass-cap-head-bolts-m2x16-warp-360-p-29231.hdx |
United States, GA, Hoschton
Joined Feb 2013
Devo 10 Setup Help
I just received my Walkera V450D01 BNF and need a base line setup for my Devo 10 Transmitter. I have searched the Threads and can’t seem to find one. Any help would be appreciated. The manual only has the settings for the WK-2801PRO tx.
![]() I'm not sure if there are any major differences in setup? |
Joined Jun 2012
![]() I've mounted using the original pad, the white one, just removed the part inside. It flyes awesome, it rock steady, the 2702 reciver was good, but this is another planet... I can also fly with zippy compact 3700 mah and the heli is perfect balanced. I used them with the fusuno canopy for v450d01, they're the maximum , no more space available... http://fusuno.com/product_info.php?products_id=15859 Maybe the 4000mah could be allocated but not sure... They're only 25c but not so bad at all, if you need some more fly time and little less power. Also very cheap ![]() http://hobbyking.com/hobbyking/store...dproduct=21355 Now I need some time to test all.
Believe it or not, i only use 20C packs in my 450. On windy days, it's a problem. But, they are only $9 each at hobbyking. When new i can get 5-6 minute flights out of them. Thats all i need. Now that i have over 100 cycles on them they are only flying about 4 minutes. My next packs will be Turnigy Nano packs because the regular have been so good. But i don't mind paying $17-$20 each for the Nano packs because they can be charged either 5C or 10C. So the cost is made up for by not needing as many batteries and being able to fast charge them at the field in about 15-20 minutes or whatever. |
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
