Old Mar 01, 2011, 09:24 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
You maybe right, but it looks like most typical ones would work, that or the zip tie
ViperZ is offline Find More Posts by ViperZ
Old Mar 01, 2011, 10:00 PM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
I cheat and remove the blades then lay a long rod inside the blade grip and set it level
stretch1100 is offline Find More Posts by stretch1100
Old Mar 02, 2011, 03:04 AM
kutyafal is offline
Find More Posts by kutyafal
mSR,120SR,4G6S,UFLYS,1#A, v450d
Geneva, Switzerland
Joined Oct 2010
The problem with the zip tie is that you can only level the swash at 0 pitch. On the v450 I think there is not enough room for the zip tie to level swash at full positive and negative also.
I got a universal leveler with different shaft modules and adjustable legs and it works well.
kutyafal is offline Find More Posts by kutyafal
Old Mar 02, 2011, 03:09 AM
LevTor is offline
Find More Posts by LevTor
United States, NJ
Joined Jan 2011
Hi Kutyafal. Please share link. Tnx.
LevTor is offline Find More Posts by LevTor
Old Mar 02, 2011, 07:25 AM
badbob10 is offline
Find More Posts by badbob10
Carbon Z Cub, Stearman, Splend
Long Island NY
Joined Sep 2010
Great tip! Thanks!
~bob
badbob10 is offline Find More Posts by badbob10
Old Mar 02, 2011, 08:30 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Would like to see this!
Old Mar 03, 2011, 01:30 PM
dado099 is offline
Find More Posts by dado099
Italy
Joined Sep 2007
Cyclic problem at top/bottom pitch
Hello everybody.
I'd like to know if anybody found this problem on this rx-2702v (3axis gyro).
After setup correctly terminates, everything is well, but not the cyclic
travel at full top and bottom of pitch.
In that condition cyclic is somehow limited and cannot do full extension,
like at center pitch.
I found also a trick at this forum :
http://www.heliguy.com/Forum/viewtop...95.html#467295
(heli is t-rex, but it is the same)
that claims to resolve the problem, but in spite of following step
by step the instructions, I'm still affected by this problem.
Anybody that has a rx2702v can check if this always happens ?
Is there any way to resolve the issue ?
dado
dado099 is offline Find More Posts by dado099
Old Mar 03, 2011, 03:18 PM
rew-7 is offline
Find More Posts by rew-7
rew-7's Avatar
UK, Leeds.
Joined Mar 2009
Re calibrate Rx with Swash Mix all set to 100%. Then after calibration put back to your normal settings.
rew-7 is offline Find More Posts by rew-7
Old Mar 04, 2011, 11:30 PM
secretsg is offline
Find More Posts by secretsg
Joined Feb 2006
How is the spare parts situation on this heli? Looking for a park flier for spur of the moment flies.
secretsg is offline Find More Posts by secretsg
Old Mar 05, 2011, 10:05 AM
dado099 is offline
Italy
Joined Sep 2007
Thanks, it helped a lot !
Old Mar 05, 2011, 01:57 PM
rew-7 is offline
rew-7's Avatar
UK, Leeds.
Joined Mar 2009
No problem.
It has been mentioned that you can run the swash mix past 100% for even more travel. I couldn't see much difference when I tried but I run 12-13 deg pitch which this Rx wasn't really designed for anyway. The swash travel is fine in the middle usable part so I live with it.
Just glad it helped with your frustration because I've been there.
Andy
Old Mar 05, 2011, 10:21 PM
USA, IL, Elgin
Joined Jan 2006
Before heading out to fly tonight I went through all the screws on her. Didn't even put hardly an pressure on this ball and it snapped right off. This is the first time I've tightened it after having done a handful of sport flights. Will have to check my parts bin and see if I have a ball that will fit. The hard part for me will be getting the rest of the threaded piece that's broke off inside out without jacking up the swash. Suggestions?
Old Mar 05, 2011, 11:28 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Bummer... :-(
I suppose good thing that didn't break while in the air....
I don't know if they make EZ-outs that small Maybe try a small dab of super glue on the end of a Allen key small enough to fit in. However be care full to not use too much as you don't want it to ooze and glue the broken piece in, other wise it would be FUBAR.
Old Mar 07, 2011, 01:21 AM
USA, IL, Elgin
Joined Jan 2006
http://www.youtube.com/watch?nomobile=1&v=knsJe8moGn0
Old Mar 07, 2011, 01:23 AM
USA, IL, Elgin
Joined Jan 2006
Bummer... :-(
I ended up ordering one from hobbypartz.com as they have free shipping. Cheap swash to replace at $17
Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 07, 2010 08:03 PM
Discussion Walkera 4#6 or Walkera 4#6s? red_storm Micro Helis 8 Jul 07, 2010 12:17 AM
Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? tumble2k Micro Helis 7 Mar 26, 2010 07:30 PM
For Sale Walkera 68 & Walkera 36 Parts bretware Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 05:23 PM
Wanted Walkera Lama2 or Walkera 5G6-1 night_life Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 04:20 AM
