Sunday was a great day out at the field. The sky was clear and the wind was very low. Almost non existent at times. It was a good day, for the most part.
Vids for the X5 V120 vids, both crashes lol. |
Japan, Tokyo
Joined Jun 2011
On your 2nd flight of the V450 where you did a loop & thought you had a dropout: What I saw at around the 2 O'clock position was that your pitch changed & it looked like you released some of your aft cyclic while pointed towards the ground. I didn't hear any motor speed slowdown.
Are running 7 point throttle & pitch curves & are they divided equally between each point? [QUOTE=IntegrityHndywrk;23366074]Sunday was a great day out at the field. The sky was clear and the wind was very low. Almost non existent at times. It was a good day, for the most part. |
here is what your looking at roughly based on a 30C pack. |
Does anyone know where to get the fatter washers for the spindle/feathering shaft screws? The ones that secure the blade grips. I have a set that probably came with my Walkera rotor head and the tapered type Walkera feathering shaft. But Walkera does not sell individual Feathering shafts or screw/washers for them. I always end up with some variant of Align or Align parts. Those are always 1mm washers, if they are even that thick. But the 2mm washers are needed on both sides of the Walkera rotor head to eat up some of the play left from the shaft being a little bit too long. I can't seem to find them to order anywhere. The hardware store does not have any that small. There must be some out there somewhere?
Hopefully any of that made sense, because i think i confused myself. But basically i didn't want to risk grinding or cutting the shafts. Using the right washer for a shim seems to be the better idea. I think the tail blade grips come with 2 thicker 2mm washers too. They have to be available somewhere.
Here is something interesting for anyone in the US. I placed an order with Wowhobbies last weekend. The shipping cost was slightly more than usual and they no longer had insured shipping available though the USPS. Today i went to place another small order. The shipping that was now the default by wow was FedEx insured shipping for like $17 just for a $9 V120 swashplate and some canopies. But it doesn't end there. The only other shipping available was for FedEx uninsured for $15.50 or USPS Priority mail -UNINSURED for $13.70. I suppose it could just be wow's site screwing up. But i doubt it.
The USPS is going out of business basically. Don't worry though, economic collapse isn't on it's way or anything. (total sarcasm implied) |
My mistake, I thought you were talking about the main blade feathering shaft.
I need to look at my grips and see what you are talking about before I put my foot in my mouth. Quote:
Joined Jun 2011
Does anyone know why i couldn't finish off the rudder servo end point settings.....? i have set this rx2702v so many times but today when i finally got my replacement parts for the tail and tried setting up the rudder servo before i bring it out again....
so what actually happened was when it went on the triple fast blink (which is for the right end point), i couldn't get it to finish off the setting....ie...press setup button again did not have any effect, the light still blink 3 times even though i keep pressing the setup button.... i tried the rudder servo on the rx2703h-d and it worked just fine....in fact this rx doesn't need any setup at all....as like plug n play.... does anyone here know what is wrong with my 2702v? could it be faulty...i hope not... =( |
I don't have a 2702V RX but I have seen the complete setup on YouTube, do a search for that RX you will have all the info you will ever need. I think the key in the rudder setup on the 2702V is you need to move the rudder stick for it to know the end-points. But watch the video, ok?
I was worried about shaving off too much or unbalancing the lengths. Or possibly ruining the threads inside. I'm sure i could grind/cut some off. but using washers is just SOO much easier. Quote:
Just in case this helps. Setting Rudder end points: 1. Press and hold the setup button till you enter rudder setup mode (make sure the switch is in the right position) 2. Check full range of motion. Right now the gyro is turned off and FULL range of motion is available. 3. Let the rudder return to "neutral" or the center point. 4. Press the setup button to confirm the "neutral" point. 5. Push the stick to the FAR left and back off a little so there is no binding. 6. Press the setup button to confirm the LEFT end point. 7. Push the stick to the FAR right and back off a little so there is no binding. 8. Press the setup button and the rudder should throw back and forth about 3 times confirming that setup is complete. If you did in fact go though all of that in those steps. You might just need to play with your button to get it to work right when it's not working. Otherwise i'm not sure what is going on with your RX since i'm not there. |
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
