If you follow my V450 build log you can upgrade your helicopter with a CopterX motor, Hobbywing Skywalker ESC and Savox servos for under $200 total. As long as your RX is not the reason why you crashed (lock out from rx), after doing those upgrades you should be flying great for a much, much longer time. It would be cheaper then getting a whole new helicoper in my opinion. It's actually most of the reason why i did the build log. Trying to save people time and money. http://www.rcgroups.com/forums/showt...6#post22809788 |
NYC
Joined Aug 2010
It's probably easier to see then explain. Here is the healthy gear drive assembly. Notice the flanged stopping point on the shaft, below the bearing. ![]() That flange on the shaft is there to keep everything together and tight. It just wore off. This is what mine looks like now: I did get a few good flights in. Here is the best flight of the day, followed by a very interesting crash caused by this failure. I did a pogo stick landing on the tail. The tail did not bend and the blades did not strike, well, anything. It literally bounced on the tail at an angle! Then landed on the skids. Total damage so far at first glance. Tail rotor shaft and a new tail drive assembly of course. Thats all. Everything else is in one piece. Not even a crack in the canopy or anything. The Fusuno knight head brace, i have no doubt, helped keep the tail strong enough to take 2+ bounces on the end of the boom and not buckle.
Joined Jun 2012
![]() Align H45099T |
I just installed a new CF frame where mine was split and all sloppy. It didn't remove the tail vibration and the funny noise on the main rotor. So for the hell of it, i double checked the pitch and removed the blades and weighed them. There was a difference of 0.02g between the two. Not even close to enough difference to cause this kind of vibration. This is the second time i've been though this now with these blades. I put it all back together and checked the tail again. Then checked over the rest of the heli. Nothing looked out of place. I went out to spool up in my driveway and the vibe starts to appear rather quickly. So by now i'm pulling my hair out on this. I went inside and removed the Pro 3D CF blades and installed the blue Align CF blades off my other 450. Went outside and the Align blades were right on track, no noise, and no vibe. Was running true...
So I'm confused on whats going on here. I guess the problem might be blade weight CG? If it's a tracking issue, one blade is messed up or something because they are both set with a digital pitch gauge and double checked with my eye. This is my first set of screwy Pro 3D blades. |
Joined Jun 2012
Please let me know I'm interested if also this parts is compatible and better made. Ps: I'm waiting also for your info about main shaft and dfc rotor head
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
