Joined Apr 2011
One plot for the main rotor, and a second plot for the tailrotor. You can analyze it after a flight, or in real time, on the ground as you run up the rotor. Here's the link for the demo on UTube.
I think the Robird is worth the price just for this feature. |
Hong Kong
Joined Jan 2010
This is the reason why many modellers here pay professionals to install their FBL system for them. Things have just got so complicated now as it you need to have a degree in engineering. It often costs more than US$300 to have a Vbar installed and set up by a professional. If you don't set up correctly, the heli may not even fly.
Joined Aug 2010
Besides the added fuselage, daytime strobes and lugging around an iPhone, there were some Radio Shack heat sinks attached to the stock 35 (40?) amp ESC to keep it from overheating. Otherwise stock V450.
Anyway, NOTICE: The swashplates being sold by wowhobbies.com, helipal.com and a few other sites i have ordered from recently have the old version v450D01 swashplates listed for sale and pictured in the listing. THEY ARE NOT THE OLD VERSION! I only ordered one this time from wowhobbies instead of 10. A "New" swash plate is what arrived today. This is worthless to me because it has a very much limited movement compared to the old version. It's great if you want to dumb down your cyclic and flip/roll rotation speed though ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() SO ANGRY... So if anyone wants to buy this "New" Swash off me i'll ship it USPS first class so i'll take $20 for it shipped. I will now be buying an Align DFC rotor head, swash and some servo horn linkages for my Savox servos. I'll have to see about how the Geometry lines up and everything. But i will not be replacing the rotorhead with a "New" rotor head. ESPECIALLY because they made the blade grips out of plastic and want $49.90 for the damn thing. Which is the same cost as the Align DFC head, like they have any justifiable reason to charge as much as Align for using cheaper materials and less research. Not to mention if you find a pictured and labeled "New" swashplate they are listed for $29. Meanwhile everywhere i have purchased one that was pictured as a "old style" swash i only paid $16-19 for the swash and they sent me the "new" version instead. So if anything Walkera's markup is brazen hubris at best, in my opinion. The Align DFC swash is only $27. So, in my opinion, they have a lot of nerve and are going to push them self right out of the hobby market. Maybe "push" isn't the right word. More like "laugh". |
Okay, so out of curiosity i installed the "new" swash and went though all the setup a few times. What i have found is that the swash reacts about the same with the "new" swash using linear expo and 100% DR. Where with my old swash i had to use 40-80% expo/100% DR. The rotation rate was still MUCH, MUCH, MUCH slower than with the older version swash. So i turned the swash mixing up to 90 - 90 - 90 and ran though the RX cyclic setup limits again. Even with 90 - 90 - 90 the rotation rate was still slower than with the old style swash, but almost acceptable. I have not tried 100 - 100 - 100 yet, BUT HONESTLY?!?!? Isn't this getting a little nuts? I have to drive it to the MAX limits to ride the same threshold as the old swash? I feel like not having any head room is wrong. The only alternative i have is to MAYBE try installing longer ball links on the blade grips. But something tells me finding them will be an issue. So if anyone strips their old style V450 swash. Keep this in mind because you'll have to reset the heli limits on the cyclic.
I might give one of the clone FBL heads a go or something like that. But the DFC is probably the nicer of them all. It sure would be nice if i could extract these two broken links so i can use this brand new swash i didn't even get to use. |
The 2702V-D will probably work for you and is easy to install. But with a little learning i'm sure you could setup any one of these gyros with no problem. The Microbeast is very easy and can be programmed anywhere without a PC. Not all of them can do that. The Tarot ZYX can be programmed via bluetooth with your cellular phone, using an app and bluetooth plug adapter for the gyro. That is pretty cool, IMO. I think any one of these will work great for you if your not really stick slapping 3D like a mad man. I've heard the 3GX is kind of complex to setup. But the microbeast seemed pretty complex to me at first too. I hope this info helps. If it means anything, i would argue that Align's sales would be improved if they sold their bigger helicopters with BeastX gyros. I can only speculate, but i feel like they are going to be the superior between the two. Maybe not in over all performance, but i think you need to PC program the 3GX? I am not sure about that. But it's something to check out. |
Joined Jun 2011
I'm using the 3gx on my 250 DFC. For some reason and it seems fine. If you ask me i still quite like the 2801 rx2702v as it is so easy to setup. I'm not doing hardcore 3d at the moment and I can't really tell the difference in both to b honest.....thats y im thinking if i'm going to build a 550E DFC, shall i get the super combo or just the combo set.....
Since your asking ME, and your thinking about the Trex 550, i have to strongly recommend you consider the Gaui X5. I think it's actually cheaper than the 550E, costing about $899. It's about the same cost. The super combo comes with everything you need except a RX and battery. Of course i can help you with the setup of the X5 as well. The build is actually very easy, probably much easier than the Align build. It also can be fixed easy since there are not a lot of little parts or servo brackets or anything like that. But, if you have your heart set on an align, that is a nice heli too. The 550E is just a little bit bigger than the X5 but it's heavier. I know a lot of guys sold their 550 to get an X5 and preferred it. This was one of the reasons i decided to get the X5 instead of the 600E i was looking at. Regardless, if you get an Align above the 450 size. I would go ahead and get the FBL head, not the DFC and get the full 3GX combo since you know how to set it up already. It really is a much better gyro than the 2702V. You might not be able to tell now, but if you get into wanting to do multiple pirouettes in a row or tick tocking you will start to notice the difference between the 3GX and the 2702V. The 2702V will fly and do 3D, there is no doubt. But the 3GX will stabilize the heli much better so you can concentrate more on the ticks. That being said. Learning on a "poor" gyro is probably good flight training in my opinion. It will teach you muscle memory so if your gyro fails or you ever need the skill you can probably stabilize the heli better yourself. |
Joined Jun 2011
Japan, Tokyo
Joined Jun 2011
The 3GX can be programmed via PC or directly. It's not as easy to program directly as there are way more options than on the RX2702V-D but actually, once you get your head around what you're doing (and if you can see which LEDs are flashing at you during the setup) then it's not that bad either. After the 5th run through you should be getting the hang of it. I just got my Align Trex 250 Pro DFC to fly and compared to the V200D03 it's ultra reactive - not sure how a V450D01 with 3GX would be but I think the sticks would feel waaaaaay more connected to the heli. If I suddenly get a week of free time I guess I could try it!!
Joined Jun 2011
Japan, Tokyo
Joined Jun 2011
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
