The new 2702V with long antennas flew nice. It was real nice and stable, just like the "good" Rx i moved to the heli i have for sale. It didn't lock out at ALL, which is a good sign. Nothing too exciting but it was cool to have it back in the air. I will eventually probably replace the 2702V with a microbeast with SX or a AR7200BX. Even though this 2702V flew very stable and smooth, i don't think it's going to touch the BeastX. But i will know more after i get farther along with my X5. Pirouette compensation should be worth it alone, i think.
Anyway, here is the video. Nothing special. Few flips and rolls while i get back used to flying. It's been a week or 2 since i flew anything.
One hell of an air frame though on the v450! It takes a beating. It just needs a new ESC, servos, RX and apparently even the TX is a problem these days.... /sigh. I feel your pain and have lived it too. |
I'm not getting pissy at you just, I never said I was using a LiPo battery in the TX.
I just said that I could smell a burning smell from the battery compartment. But, I am using a 900 Mah Lipo 25C But I don't charge it in the TX, I take it out each time to charge it in balance mode. The reason I smelled a burning smell when I opened the battery compartment & extracted the battery is because all of the other electronic circuit boards are located near there, plus I was hoping maybe a diode or fusible link smoked, but I wanted to halt all power to the TX I opened the TX & checked for a fusible link or diode, none to be found! I took out the charging socket to be sure, there is not one iota of protection there even for reverse current, that is really reassuring! I started sniffing the circuit boards to see which one smelled the most of smoke, I picked the left board (from the front) which gives you your exit key/scroll up/down. No problem there, nor any burns or even any components except the 3 switches. With that board removed, I sniffed the bottom middle board which is the LCD display/HID board, it reeked of smoke, plus the next board up is the transmitter section & it also smells of smoke. I'm not sure I want to disconnect at least 25 connectors to be able to turn the boards over for visual inspection. I may do it depending on what Helipro has to say about what I want from them I.E. a new TX & they don't get my TX back, or if they want it back they can pay for the shipping, plus the repair parts for my heli. I will photo the inside of the TX, but it really shows nothing. No smoke stains,no melted parts. So this reply is for Clearprop88 & Integrity's post. |
It's note worthy to mention that my new DX8 comes with a Nickel Metal Hydride or maybe It was NiCad i can't remember. I'm pretty sure the standard now a for the TX side is NiMH like Clearprop said. I'm not placing any blame or fault on the use of the Lipo. Because i used them in all 3 of my 2801-pro TX and the TX's acceptable voltage is 15v, at least on my 2801. I just think it's important to notice that Spektrum and Futaba use NiMH. Although my TX comes with different foam inserts so you can shim the battery you put in the back. I assume it's either for different type of batteries or for different size batteries. I don't know. But i figure they have a reason for having a few different foam wedges to shim the battery. I'm pretty sure i've seen a Spek branded Lipo battery for the DX8, but mine came with the NiMH. I suppose it's for preference. But i'll be sticking with the NiMH for now. One more thing about that. It notes in bold text in the manual not to charge for longer than 12 hours or over charging will occur and ruin the batteries or worse. |
I got the response I was expecting.
Send photos because factory wants to see the damage (of course they will see nothing) then send back transmitter via air mail at my cost & they will replace the TX & landing skids. I think I will take the TX section apart so I can view the underside of the circuit board, I want to find out what component burned. Pictures coming later. BTW NiMh batteries, you are correct, they don't & won't stand for overcharging. Ni-Cads will as long as you charge them at "C" rate if you charge at higher than "C" when they are fully charged & don't discontinue charging after it hits delta peak, they will open their safety vents & release their electrolyte. This prevents a explosion. |
I had such a great day today out at the field. Lucky for me there was no one parked or in my field and i just flew over the lighting rigs they left in my way. I'm thinking this weekend the area will be full of people though. Anyway, i brought my charger with me today and got 3 flights on the Gaui and about 7 flights on the V450. Here are some of my best flights on the V450. As you will see, i don't even start getting warmed up till I'm almost out of batteries. Maybe i just need more packs? Oh well, with things going this smoothly maybe i can dust off the sim and start moving into some new ticks and stuff.
Japan, Tokyo
Joined Jun 2011
My morning with the 450 started well... I got it out of the box and actually put it in the air!
Got a pack and a minute in and then got chance to do my first auto as the motor shaft sheared... Seems like even with it correctly spaced (which I was always very careful about) the old stock motor has a tendency to fail in this manner. My SuperBrain 60A which has previously made the same motor smoke worked wonderfully today with an updated firmware. The soft start is very soft and hopefully the log with show some thing interesting in terms of temps, amps etc. Broke the canopy and the swash follower at first glance. Everything else is looking ok. It wasn't too bad an impact but it wasn't graceful either! |
Sorry to hear about that. The stock motor has a buttery soft shaft. I think it's been said before. (maybe once or twice) But for the money, the CopterX 3550kv motor was recommended to me by clearprop. I've been using it since, well since going though and replacing everything else didn't work, so i figured better try the motor! Then it flew great for like 5 flights and locked out on me again! YAY. But ever since figuring out that the RX was bad. I can honestly say that the CX motor is a little beast. It performs good compared to other motors that are running twice the cost. I did like the Turbo Ace 804 too, it was a beast of a motor. But really, running the turbo ace 804 at with a 11T pinion is not much difference from running the CX with a 13T pinion. Some would even say that the 13T is too much (pushing 3200rpm at 100%). Just a suggestion for only $20 you can't really beat the value. |
United States, GA, Covington
Joined Mar 2011
YEs , sorry to hear you wrecked. Good to hear , it doesnt sound bad, I strongly suggest the align motor, its been a perfect beast.
I flew 450 as well this morning, time change tonight will shake ings up a bit, but morning are still calm. Funny thing is i took all the expo out of my ele. And after all my sim time , it feels good, but i wonder if i had it reversed, i had positive expo, to calm down center stick....but i think it made it more responsive! Anyway now im walking a straight line of expo! Integerity, your flying is looking great , you are making me sick with the inverted stuff! I did some inverted movement today ....i call it. Lol . the new heli looks awesome. Quote:
Joined Apr 2011
I have been using a Copterex motor since then, and it holds up really well. Runs fairly cool, and has good power. Integrity has been using the same motor. The one I like even better is the Turnigy 2215. It runs very cool, has good power, and is very efficient. It will give you more flight time. I have been using the 2215 in my Trex 450 Pro. |
Japan, Tokyo
Joined Jun 2011
Thanks for the advice guys. I already got a couple of spare motor options in after my SuperBrain smoking incident but since the original was still working I didn't swap it out.
The shaft failed exactly at the circlip groove so it's a manufacturing issue in my eyes. I think I have all the parts needed to rebuild but shame it didn't fail on the last pack rather than the second! I never get to fly her and then when I take her out I get 5 mins!! Arrrgh! The X5 looks wonderful Integrity. When I grow up that's what I wanna fly!!
All this talk about motors has me curious and wanting to install the 804 again. But, if it ain't broke, as they say.
For now i'll stick with the CX motor. I switched to the pro 3d 335mm blades because they are bigger and the motor has no problem swinging them. In fact the v450's stock blade size is 335mm. With the stock size blades on the motor produces plenty of juice for what I do, as you can see in my videos. Never had any kind of bog down or issue, anything like that. It's pretty good for the cost. It DOES come with a, i think 11 or 12T pinion. Which will probably give you right at 2800 rpm or about, if it's a 11T. I installed a 13T on mine, so it's geared up 2 sizes and still holding out and does not run very hot. Maybe 110° or so, maybe hotter in the summer. It's hard to say because i think my old RX was giving me issues with that too. The Align motor is giving Biggie like 3600 rpm or something?!? DAMN Biggie, gear it down some fella! lol! |
Though, i could just save the money and keep flying where i do now. I actually found a new place near by there too with 10 foot tall grass.... Hopefully i don't crash. I'll take my trusty friends advice, here, if i'm told to just bite the bullet. But how safe do you think my site really is in a "situation"? The new site there is nothing around for thousands of feet. But the grass is literally like 5 feet tall and full of bugs and all kinds of Florida wild life. A landfill turned air field might be a better alternative?
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
