Old Feb 15, 2011, 05:22 AM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Originally Posted by LevTor View Post
Banana 3.5mm.... The newer ones are 4mm (ones on the after market batteries)......
Thanks, I should measure them to be sure then....
*update*
3.5mm, is measured ID of the female connector.
They look like these here which are called bullets. Bullets, Bananas, same thing?
http://epbuddy.com/index.php?main_pa...roducts_id=100
ViperZ is offline Find More Posts by ViperZ
Old Feb 15, 2011, 05:45 AM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Okay, I now know why the Heli was drifting left on me during my trial hovers....
Answer is at 0:53
Day 4 - Learning To Hover (7 min 23 sec)
Old Feb 15, 2011, 05:59 AM
kutyafal is offline
Find More Posts by kutyafal
mSR,120SR,4G6S,UFLYS,1#A, v450d
Geneva, Switzerland
Joined Oct 2010
*update*
Yeah, I tell you these are the biggest pain-in-the-butt connectors I worked with. Someone please tell me how you seat the bullet into the housing once the wire is soldered on (and without destroying the housing) ? By the time I got them seated the half-destroyed housing become too loose and the bullet would just slip out.
I sure was refreshing my vocabulary when I was in the process of making the extension/converter I use now.
Oh hell, I should just change all of them to either EC3 or XT60.
kutyafal is offline Find More Posts by kutyafal
Old Feb 15, 2011, 06:03 AM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Originally Posted by kutyafal View Post
Yeah, I tell you these are the biggest pain-in-the-butt connectors I worked with. Someone please tell me how you seat the bullet into the housing once the wire is soldered on (and without destroying the housing) ? I sure was refreshing my vocabulary when I was in the process of making the extension/converter I use now.
LOL I was thinking they would be like the Amp connectors, in that you pass the wire to be soldered through the body, solder on the the metal end, then pull the unit back in to the body to be locked in place. This is not the case...?
Old Feb 15, 2011, 06:08 AM
kutyafal is offline
Geneva, Switzerland
Joined Oct 2010
Oh man! Ur telling me I was stupifying it the whole time? I didn't even think of that but thanks for the tip. Probably, that's how it should work. And I was pounding it in with a screwdriver and a hammer from the other side...
Old Feb 15, 2011, 06:13 AM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
No, it sound slike you were doing it it right.... God bless Youtube
LOL A heat gun? @ 3:11
http://www.youtube.com/watch?v=KqbnW...eature=related
Old Feb 15, 2011, 06:31 AM
kutyafal is offline
Geneva, Switzerland
Joined Oct 2010
Yeah, u can see in that vid that he pushed it all the way through then it was a lot easier to pull it back in from that direction. I think that's how it's supposed to go. I did the same thing with the EC3, don't know how it skipped my mind. That way you can use the opposite bullet to push it back in from the other side nice and straight. Brain fart...
Anyways, back on topic. So who's doing piro flips with this thing yet?
Old Feb 15, 2011, 07:37 AM
urrl is online now
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
I converted both my 4F200 and my V450D01 to these connectors, bought from my local hobby store. They seem to work great and are easier to grasp and pull apart. I find the bullet connectors can be quite stubborn to pull apart when inserted fully together.
urrl is online now Find More Posts by urrl
Old Feb 15, 2011, 10:29 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
Since my belt is showing signs of wear again I ordered front and back metal rudder gears, but I'm wondering if anyone uses silicone or some other spray to lube the belt?
Old Feb 15, 2011, 11:55 AM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
Use silicone spray on any belt driven heli. Regarding the connectors I like the xt60 connectors as pretty much all the turnigy lipos you buy from hobby king come with this connector
stretch1100 is offline Find More Posts by stretch1100
Old Feb 15, 2011, 06:06 PM
urrl is online now
urrl's Avatar
Joined Aug 2010
Although I could not find any aberrations on the gears I did my best to sand them down. I replaced the belt and put on some silicone spray lube. I went through a battery and noticed no wear whatsoever. But I will certainly keep an eye on it. Thanks for the silicone info. I'm new at this as you may have guessed.
Old Feb 15, 2011, 10:07 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
I agree, those bullets are tough to get disconnected, once pushed together. I think I may convert entirely over to XT60. I'll see how the cord length works out, or if I have to solder new leads to the ESC
Old Feb 17, 2011, 07:47 AM
fishysteve is offline
Find More Posts by fishysteve
Thorndale
Joined Mar 2009
fishysteve is offline Find More Posts by fishysteve
Old Feb 17, 2011, 05:56 PM
USA, IL, Elgin
Joined Jan 2006
Tested out the Align Night Blades. Now I just need to wait for night :-)
Walkera V450D01 with Align Night Blades (2 min 36 sec)
Old Feb 17, 2011, 11:25 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Wow!! Thats awesome on many accounts!
I love the way it sounds in your livingroom
Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 07, 2010 08:03 PM
Discussion Walkera 4#6 or Walkera 4#6s? red_storm Micro Helis 8 Jul 07, 2010 12:17 AM
Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? tumble2k Micro Helis 7 Mar 26, 2010 07:30 PM
For Sale Walkera 68 & Walkera 36 Parts bretware Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 05:23 PM
Wanted Walkera Lama2 or Walkera 5G6-1 night_life Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 04:20 AM
