Japan, Tokyo
Joined Jun 2011
.....yeah, really. all the roll overs you apparently had and you didn't record any of them.... Look man. Thats just insensitive! So inconsiderate!! Don't you know RC helicopters are like nascar? No one wants to see the cars drive. They only go to see the crashes!!
lol, in all seriousness though. Video might help us help you. Thwaitm has a point. |
Joined Mar 2012
![]() I did think of reverting back to the old servos but didn't follow through. |
So i have the heli on the bench doing some maintenance. Lubing things and this and that. I noticed my brand new main shaft bearing is a little grainy already.... Its only got maybe 10 flights on it and 2 crashes. I think the crashes did it. /shrug.
Next point of notice.. The Align FS on the Walkera Rotor head. As we have discussed there is a small bit of play. I never had much of an issue with it because i adjusted the FS to the center and used the screw in the stopper cap to lock the FS from being able to rock back and forth inside the rotor. Well the hole is now stripped out completely from a crash a long time ago. I can no longer use a stopper cap on this rotor. So the FS moves around more and seems to have more play because it will often slide to one side or the other instead of staying center with the screw. Over time this rocking motion has bent the blade grip mounting screw's washers into a concave shape, which has exacerbated the slop on the FS/blade grips. I added a tiny 1mm thick washer behind the existing washer on one of the blade grip screws, as well as bent the other washers back to flat. The rotor head seems quite tight now with no play at all on the FS. I'm not sure that it will be okay like this? |
Below is a PDF file explaining how to set it up. All these options can be set preliminary on the bench without the blades on, especially motor timing. You can just hear if the motor is running smooth or not as far as spool up and running it at max 100%. If the timing isnt right then the motor will skip and not sound smooth etc.. The rest of the tweeks can be done in the air with the field card or Castle link/laptop. For more DOC's/PDF's check my blog ; http://www.rcgroups.com/forums/showthread.php?t=1656159 |
Joined Apr 2011
[QUOTE=HeliFlyer711;22288098]To setup the auto bail out feature have to fly in heli St1/St2 and not use normal mode anymore. With the ICe you can actually start up in St1 since it has such a soft start. Coming out of Throttle hold into St1, by the time you get to mid stick (0 Pitch) the heli is still spooling up and then to land its TH. For Auto's just click into throttle hold and then if bail out is needed when TH is clicked back on Throttle comes up instant.
************************* Thanks very much for the info. Good stuff. I'm working on installing a Robird in my V450. Not that it needs it, I like the way it flies with the 2702, but I'm just using it for a testbed. I'll report on how it works out. Very good reports are coming in on the Robird, so good that suppliers are raising their prices. Some say it's better, and it is much cheaper, than the Beast, and you can program it with your PC. |
United States, GA, Covington
Joined Mar 2011
Today was the real test. No problems so far.
Please enjoy. Other new videos of the 600 and v400 from today. |
Joined Mar 2012
Thanks for the kind words Integrity! I packed up the V and put it away in the basement for another time. Took the M120 out tonight and flew 42 minutes flight time on it, it felt good to fly and even better to fly 7, six minute back to back flights and not worry about temps. It was a good day. Viking |
![]() ![]() Hey Viking, when you get a chance check to make sure the setup on your V' s 2702V/2801-pro corresponds with whats shown in these pics. It could be a simple switch with the new servos is not set. This is the correct config for Align Ds410M cyclic and DS520 Tail servo setup. The rest is the 10mm on center extended swash arm mod and to make sure 0 pitch at 1/2 stick. The swash shouldnt move when the set button is pressed and the RX goes into SW set mode. |
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
