Old Feb 07, 2011, 01:25 PM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
Originally Posted by kutyafal View Post
Forgot to mention that I flew both the stock pack and the Turnigy packs I bought (http://www.hobbyking.com/hobbyking/s...idProduct=8934) and I can say the Turnigys have noticabely more power.
My ST-1 is 90-80-70-80-90. After the 6 minute timer I put around 1100mA back into the Turnigys. I would wager you could get 8 minute of good flight out of them. For $11 they're a steal!
Is there room for a larger mah say like a 2650 and fit under the canopy ok? Say this one http://www.hobbyking.com/hobbyking/s...dProduct=15018
I just bit the bullet and ordered a v450 yesterday. I already have some of the 2200mah turnigy packs from my Creata I can use for now but looking for longer flight time
stretch1100 is offline Find More Posts by stretch1100
Old Feb 07, 2011, 06:43 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Nah, I'm too lazy for that. I actually made up a 7cm long 3.5 mm banana plug to XT60 converter/extender. I zip-tied the original connector coming out of the ESC to the rear landing gear strut so I would stop yanking on the ESC every time I try to unplug connectors cuz mine are a bit tight. Also, when I install a battery I run the battery lead in front of the front canopy pin as to keep it out of harms (and main gear) way so I needed an extender anyways.
On the other side of the frame I have my only bling on the bird, an LED battery monitor with beeper stuck to the back side of the frame. I use a balance connector extension to plug this into the battery balance lead. I can take some pics if needed but it should be clear enough. Next time I'll also take my tach with me to get an idea on head speeds with stock vs. Turnigy batteries.
Great idea, I think I may do the same on the short extension. I would not mind seeing pictures of other's set ups, I love pictures
ViperZ is offline Find More Posts by ViperZ
Old Feb 07, 2011, 06:47 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
I just bit the bullet and ordered a v450 yesterday. I already have some of the 2200mah turnigy packs from my Creata I can use for now put looking for longer flight time
Good question, I would also like to know. Congrats on your V450!
Old Feb 08, 2011, 12:20 AM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
I think I'm going to try a few of the 2200mah 35C packs. For the price why not? They are very close to the stock pack in dimensions and weight.
Stock = 100 x 23 x 33 LxWxH 180g
NanoT = 115 x 27 35 LxWxH 199g
Old Feb 08, 2011, 08:33 AM
lavneetgyani is offline
Find More Posts by lavneetgyani
lavneetgyani's Avatar
Delhi, India
Joined Jan 2007
Hi all,
just got mine without the TX since i have a 2801 pro already, please guide me with the original Tx settings for normal sport flying. The Ones DK fuji has given seem too hot. Can someone pls give me the original settings for stable sport flying.
Lavneet
lavneetgyani is offline Find More Posts by lavneetgyani
Old Feb 08, 2011, 08:59 AM
kutyafal is offline
Find More Posts by kutyafal
mSR,120SR,4G6S,UFLYS,1#A, v450d
Geneva, Switzerland
Joined Oct 2010
If you're familiar with the 2801pro and know how to set up helis in general then just set the collective and cyclic to 6, throttle curve to around 0-50-60-65-70 and pitch curve around 40-45-50-65-80 for normal mode. Set the RX pots to around 1 o'clock and your gyro gain on the radio both to around 70. Add around 30% expo on AIL, ELE and RUD and set your rudder DR to around 70% for a nice slow-ish tail.
Of course make sure you do the RX initial setup via the set button and radio properly. The best way is to put the RX in setup mode and while the red LED is blinking set the collective to around 10 and cyclic pitch to 8. Then do the RX setup steps. When finished use the swashmix menu along with a pitch gauge to dial everything down to the milder values.
kutyafal is offline Find More Posts by kutyafal
Old Feb 08, 2011, 01:58 PM
USA, IL, Elgin
Joined Jan 2006
Has anyone had any problems with the esc on this not doing a slow cutoff when the battery runs down? I replace most of the walkera esc on my helis cuss some don't have soft cut off programmed in.
Old Feb 08, 2011, 11:24 PM
Delhi, India
Joined Jan 2007
Thanks a lot. This is my first experience with a FBL. I have programmed and flown the Creata for over a year but I am getting a little confused here.
I would be grateful if you could give me a step by step instruction of setting up the V450 with a new 2801 from scratch. Thanks in advance.
Cheers
Old Feb 09, 2011, 09:14 AM
badbob10 is offline
Find More Posts by badbob10
Carbon Z Cub, Stearman, Splend
Long Island NY
Joined Sep 2010
V450 Setup Sport (not so scary)
Hi lavneetgyani
I am also new to FBL including CP, I've been flying FP for almost a year. I got the V450 for Christmas and have the Wow set up which are easy to program but when I hovered the V450 first time in my living room it was scary, the V450 is an animal. I made some friends on this forum and I was given another set of setup parameters that are less scary. I will paste them below but if you'd like, I can email you a nice easy to read/use PDF. I now have both setups in my V450 but the second one is more sport than 3D but I really am new at this so untill I get this chopper out to the field so a pro can check it out for me, I'm just hovering inside. we're under ice here in NY.
Happy hovering,
~badbob
WALKERA ALT SETUP
Modell
Fernsteuerung 2801PRO (V2.3)
MDSET REVERS 2&4 REV
All 0
TRVADJ All 100%
SWAATS SWASHMIX ELEV 40,00%
AILE 40,00%
PIT 40,00%
ATSMIX ALL 0%
GYRHLD GYRSENS 0 80,00%
1 63,00%
DR&EXP ELEV POS-0 D/R 100%
EXP +45%
ELEV POS-1 D/R 100%
EXP +20%
AILE POS-0 D/R 100%
EXP +45%
AILE POS-1 D/R 100%
EXP +20%
RUDD POS-0 D/R 100%
EXP +35%
RUDD POS-1 D/R 100%
LIN
THRCURV NORM 0-25-39-56-70
ST-1 60-60-60-60-60
ST-2 80-80-80-80-80
PROGMIX All OFF
SWASH 3-servos120
INPUT
AUX 2 AUX2/GYRO
AUX 3 F.MOD
EASY HOOVER
Einfacher Rundflug
V450D01 (Dec/2010)
Subtrim
Gyro/AU2
Gear Gear
badbob10 is offline Find More Posts by badbob10
Old Feb 09, 2011, 09:26 AM
kutyafal is offline
Geneva, Switzerland
Joined Oct 2010
badbob10, the list is missing the pitch curves. At any case it's not a big deal. The main thing is to get the max + and - pitches right for all flight modes. I would recommend +6 and -3 in normal mode for indoor hovering. That plus the pots on 1-2 o'clock should be gentle enough. Now for the sound it makes in a small basement.... there is no cure for that!
Old Feb 09, 2011, 09:52 AM
Delhi, India
Joined Jan 2007
thanks all.... I'd love to have the PDF setup file, pls email them to:
lavneetgyani@gmail.com
and
rcd@nsouthlaw.com
Thanks a lot guys
Cheers
Lavneet
Old Feb 09, 2011, 10:46 AM
USA, IL, Elgin
Joined Jan 2006
Cheers
Lavneet
Sent
Old Feb 09, 2011, 11:27 AM
Delhi, India
Joined Jan 2007
Sent
I cant seem to see the attachment with the mail....is it zipped that the macbook cant see??
Old Feb 09, 2011, 11:37 AM
Delhi, India
Joined Jan 2007
just managed to open it, thanks!!
Old Feb 09, 2011, 11:43 AM
Delhi, India
Joined Jan 2007
Originally Posted by badbob10 View Post
Hi lavneetgyani
Happy hovering,
~badbob
WALKERA ALT SETUP
Modell
All 0
TRVADJ All 100%
AILE 40,00%
PIT 40,00%
ATSMIX ALL 0%
1 63,00%
EXP +45%
ELEV POS-1 D/R 100%
EXP +20%
AILE POS-0 D/R 100%
EXP +45%
AILE POS-1 D/R 100%
EXP +20%
RUDD POS-0 D/R 100%
EXP +35%
RUDD POS-1 D/R 100%
LIN
ST-1 60-60-60-60-60
ST-2 80-80-80-80-80
PROGMIX All OFF
SWASH 3-servos120
INPUT
AUX 2 AUX2/GYRO
AUX 3 F.MOD
EASY HOOVER
Einfacher Rundflug
V450D01 (Dec/2010)
Subtrim
Gyro/AU2
Gear Gear
Thanks a lot!! A nice cool 70 deg here in New Delhi...lotsa flying the creata and the bigger birds ....and not through windows
Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli blueindian Aircraft - Electric - Helis (FS/W) 0 Jul 07, 2010 09:03 PM
Discussion Walkera 4#6 or Walkera 4#6s? red_storm Micro Helis 8 Jul 07, 2010 01:17 AM
Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? tumble2k Micro Helis 7 Mar 26, 2010 08:30 PM
For Sale Walkera 68 & Walkera 36 Parts bretware Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 06:23 PM
Wanted Walkera Lama2 or Walkera 5G6-1 night_life Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 05:20 AM
