Joined Feb 2011
Hello everybody
I am living in Paris, France, i am 30 years old and the V450 is my second CP heli with the V120D02.I bought a week ago, the vendor told me that this heli was made one month ago so I think it's the last version. But I ask just two questions about this helicopter: - the tail baldes control is in plastic on my V450 (the others tail spare parts are in metal) but this parts is sold in metal. For example: http://www.wowhobbies.com/hm-f50d01-...rav450d01.aspx. So I wonder if this piece is in metal or plastic on your v450? - I think I have the same problem as Kutyafal about deflections servos. just i gotta redo rx setup to solve the problem? sorry for my English. thank you |
los angeles,ca
Joined May 2010
When we where at the AMA EXPO the V450 that flew had a TA motor. May try an email them ask your question about the motor. We are still waiting on the 9g motor that was in M120d01 and V120d02 in DK videos it is Turbo Ace 915 no motor yet
Geneva, Switzerland
Joined Oct 2010
Quick flight report...
OK, quick... that is the operative word here. With the weather being a balmy 13° near where I live I took it out to the field where I could finally do some proper flight testing. Tell you my worries about not having enough collective or cyclic pitch are gone now.
I started with max settings (about 10° collective and 9° cyclic) and quickly landed it after a few circuits. Mucho quick. Then I dropped to like 6° on collective and 6° on cyclic and it was much better to get familiar with the bird. The RX pots were set to the middle. I had 35% expo on the controls. Had to drop the tail dual rate to 70% as it was super quick also. At these settings the bird flew beautifully. Nice stable inverted hover, flips and rolls are quick enough still and axial. Even did Tic-Tocs OK but it needed more collective for that as it was still losing altitude. I think I will dial collective back up to 8° - 9° and the cyclic to 7° and it'll be perfect for 3D. No problem with power at all! Absolutely no bogging but we'll see later with a bit more pitch. No bad tendencies at all. Tracks straight and true in fast flight both forward and back and inverted. I'm loving it so far. It being initially tail heavy I added two big nuts as weight in the nose and it was a bit nose heavy for the test flight and therefore a bit sluggish in 3D. However for FFF it scoots like bat out of hell! I think in general and for 3D a slight tail heavy config will be much better. I asked my son to shoot some video but he was cold and shaking so much that the footage is an incomprehensible blur. I'll try to get some next time with my helmet cam.I hope Walkera gets the 500 out the door quick and with attention to quality as it should be a hoot with this RX. It's amazing how they got all the non-adjustable settings right where you don't need to be a programmer to configure 29 settings to make it fly right. Here is to hoping!
Geneva, Switzerland
Joined Oct 2010
Forgot to mention that I flew both the stock pack and the Turnigy packs I bought (http://www.hobbyking.com/hobbyking/s...idProduct=8934) and I can say the Turnigys have noticabely more power.
My ST-1 is 90-80-70-80-90. After the 6 minute timer I put around 1100mA back into the Turnigys. I would wager you could get 8 minute of good flight out of them. For $11 they're a steal! |
Geneva, Switzerland
Joined Oct 2010
Nah, I'm too lazy for that. I actually made up a 7cm long 3.5 mm banana plug to XT60 converter/extender. I zip-tied the original connector coming out of the ESC to the rear landing gear strut so I would stop yanking on the ESC every time I try to unplug connectors cuz mine are a bit tight. Also, when I install a battery I run the battery lead in front of the front canopy pin as to keep it out of harms (and main gear) way so I needed an extender anyways.
On the other side of the frame I have my only bling on the bird, an LED battery monitor with beeper stuck to the back side of the frame. I use a balance connector extension to plug this into the battery balance lead. I can take some pics if needed but it should be clear enough. Next time I'll also take my tach with me to get an idea on head speeds with stock vs. Turnigy batteries. |
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
