On top of this likely, and very possible eventuality. I would also assume many people out there would like to upgrade to better servos and have proper mechanics with proper geometry but are not so lucky to already have a swash. That being the case they probably would rather spend $5 instead of $16 when they place their order for new servos too. I'm sure somewhere out there is a 450 sized ball system that will work and can be purchased as individual parts, unlike Walkera's 450 parts for the rotor head assembly that if they were available individually we would not even be talking about it. I suppose no matter what you have to pay. It's just nice to find a better way then to just muddle through everything and pay when you don't need to. |
United States, GA, Covington
Joined Mar 2011
Yes it was free for me , but i stripped my own swash ball tightening up everything, i was very lucky to have the 2 balls i needed ,lol. I think align makes replacement extened swash balls. They may fit or not, im not sure.
http://heli-heli.com/items/heli-part...450-detail.htm I srill have not test flown, but i am on vacation, and its to windy at home anyway. Quote:
At least you have customers to worry about. This rain is keeping me from working and from working on side projects or even flying. Plus now my bathroom wall had to get ripped out today on the second floor because of a leak that wasn't even from the rain. Lousy no good contractors. Anyway, I found these linkage balls available on their own and probably in stock at some LHS. Apparently for no good reason other than my own as I've been told. Just "to get attention". Since when suggesting the last link all i got in response was basically being told that they are too long and are too big to screw into the "swash up front". Even though the purpose was to put them into the plastic servo arm as a means to keep the stock ones in the swash and not have to disassemble the swash in the first place. I have to assume the point was that they are too long for proper geometry even if they did fit? So i found the following from Eflite that will probably work. I have no idea if they will work for sure or what their measurements are. But I wouldn't doubt if they can fit a servo arm screw hole being that you have to apparently glue the WK swash linkage into the Align/Savox servo arm to make it fit anyway according to HF711. Next time I'm near my LHS maybe i'll see if they have some and compare, you know, at the risk of being called a show off or something. Looks about the same in the picture anyway. http://helidirect.com/eflite-control...00-p-25019.hdx |
Ball Links 101
But from also owning both the Blade 400/450 and a Belt CPv2 and knowing that Eflite uses 4.75 mm balls similar to Align which is the industry standard size ball for a 450, I couldnt use the balls from the Blade to repair the V450 swash. Luckily though the Esky Belt CPv2 also uses a non-standard 4mm ball that is compatible with the V450, though a different design with an actual screw that goes through the balls head. I was able to fix the stripped inner swash ball by rethreading a new hole and using blue loctite to lock it in. Now, since I've done the DS410M servo arm Mod I have extra short 4mm balls from the old servo arms and used them instead as it makes a better repair. On another subject; Here is an initial review that I posted on HeliFreak comparing the Walkera V450 to the Align Trex 450 Pro, both of which I also currently have now.. http://www.helifreak.com/showthread.php?t=311118 Anyone that makes a comparison between the Align 450 Pro and the V450 as being similar in quality (minus the electronics), like some hard headed person has posted here recently that doesnt even own an Align heli...... Let alone telling NAV to connect 2 BEC's from 2 different ESC's with 2 seperate ground potentials to the same RX power Bus...... which defies all basic electronics theory 101 and is a great recipe to let the smoke out of the RX....Id would be careful about listening too or taking advice from. I knew from Nav's reply that he figured it out this was BS. This is the correct way to do it using one ESC with 1 Lipo; http://www.helifreak.com/showthread.php?t=256172 @Integrityhandjwork , even though after I posted about it in detail, took pictures of it and made a video explaining it..... you still do not understand the DS410M servo arm mod needs a non-standard 4mm ball to work with the plastic non-standard Walkera 4mm Ball links on the V450. And the only place to get them is from the V450 swash extended arms, as they are a perfect stock fit that keeps the original design intact for a cyclic servo upgrade.But Im sure you will keep trying to figure it out....LOL ![]() For the guys who are interested, check my blog for updates to the V450 build log, going to be doing the Gyro/RX install and going over different servo tapes and mounting techniques for the RX-2702V next.......I got a few tips on how to get some extra vibration dampening on the RX mount. .
For the V450 inner swash short balls the thread is 1.4mm (4mm ball), but for the extended swash balls its a 2mm thread ( also 4mm ball size).
There was a guy here in the last week or so installing an Align DFC FBL head on the V450, he ran into the same problem in making the Align head/balls work with the V450 Swash and ordered a set of Align Ball links, but the Align ball links have a 2mm thread and wont fit the 1.4mm inner swash threads on the V450. And I had mentioned that to him.... Wonder how he made out with it since we havent heard back from him. This stuff isnt as easy as it looks, or something that you just slap together... it takes a lot of time and effort to understand and logically put together. Especially when trying to match parts from one manufacturer to another. BTW thanks for the Friend req thwaitm....accepted!
Joined Mar 2011
So, i cant find the green that everyone is talking about, but how about these??
http://heli-heli.com/items/heli-part...450-detail.htm These should fit my v400 and v450 |
| Thread Tools | |
| Wanted Walkera 400d or Walkera Brushless Cb100 or Heli max 6 channel heli | blueindian | Aircraft - Electric - Helis (FS/W) | 0 | Jul 07, 2010 08:03 PM |
| Discussion Walkera 4#6 or Walkera 4#6s? | red_storm | Micro Helis | 8 | Jul 07, 2010 12:17 AM |
| Discussion Upgrade my Walkera 4#3B or just get a Walkera 4#6? | tumble2k | Micro Helis | 7 | Mar 26, 2010 07:30 PM |
| For Sale Walkera 68 & Walkera 36 Parts | bretware | Aircraft - Electric - Helis (FS/W) | 0 | Aug 29, 2009 05:23 PM |
| Wanted Walkera Lama2 or Walkera 5G6-1 | night_life | Aircraft - Electric - Helis (FS/W) | 2 | Aug 27, 2009 04:20 AM |
