Old Jul 27, 2010, 06:48 PM
Dan203 is offline
Find More Posts by Dan203
Dan203's Avatar
Joined Mar 2007
Torque tube vs. belt drive?
I assume there are advantages and disadvantages to each, but I can't seem to find a defensive list of what they are. Most helis sold with both options are about the same price, so there doesn't seem to be a price advantage to either. Can anyone explain the pros and cons of each?
Dan
Dan203 is offline Find More Posts by Dan203
Old Jul 27, 2010, 08:06 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
The debate continues.
My opinion is the torque tube is the way to go, on a properly designed helicopter.
Downside is if you drag the tail on the ground often, the belt can be more forgiving.
Roto Rob is online now Find More Posts by Roto Rob
Old Jul 28, 2010, 12:03 AM
Dan203 is offline
Dan203's Avatar
Joined Mar 2007
So it sounds like belt drive is more forgiving in a crash. What are the disadvantages? Does it require constant adjustment to maintain proper tension?
I honestly want to know, not debate. I've been flying a lot of small Walkera's for a while and I'm thinking about getting a bigger 450 for outdoors. The cheap HK Trex clones come as either belt drive or torque tube for the exact same price, so I'm confused as to which one to get.
Dan
Old Jul 28, 2010, 01:22 AM
emberjelly is offline
Find More Posts by emberjelly
emberjelly's Avatar
N.S.W, Australia
Joined Mar 2010
It really depends I think how confident you are at keeping the tail blades from hitting the ground.
Torque tube gives better power and control to the tail for advanced flying and dosn't have interference issues and what not.
Belt drive allows for more error.
emberjelly is offline Find More Posts by emberjelly
Old Jul 28, 2010, 06:41 AM
micronut is offline
Find More Posts by micronut
dont play with rc anymore
micronut's Avatar
United States, MO, St Joseph
Joined Feb 2005
TT= more efficient, faster, more crisp response, but also more fragile. Almost any tr strike will result in stripped gears.
Belt= less efficient than TT or shaft, slightly slower response(usually only noticeable by advanced pilots doing fast maneuvers), but much tougher when it comes to crashes and ground strikes.
Once set up correct, belts require very little maintenance. I check the tension before each session, which requires only a touch. I probably have to re-tension my belts about once every 20 packs.
Belts all the way for me!
micronut is offline Find More Posts by micronut
Old Jul 28, 2010, 06:56 AM
micronut is offline
micronut's Avatar
Joined Feb 2005
BTW, I am currently building Shoguns #2 and #3.
#1 is a v2 belt drive which is by far my favorite of all of my helis
#2 will be a direct drive variable pitch tail.#3 will be a torque tube.
I may not got them finished and flown for a while, but that should be the definitive answer.
My money is on ddvp!
Old Jul 28, 2010, 08:18 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
There is some belief that belt drive creates a static electric buildup that interferes with the ESC. This is the reason I've heard for why Align came out with the TT drive version 450. I'm with micronut, the DDVP system looks very promising.
Balr14 is offline Find More Posts by Balr14
Old Jul 28, 2010, 09:50 AM
Robertwav1 is offline
Find More Posts by Robertwav1
Robertwav1's Avatar
Delran NJ
Joined Jan 2004
I have both and fail to feel a big difference. Then again I'm not advanced. I heard a shot of silicone on the belt does away with any static issues. I've never had any without the silicone though.
Robertwav1 is offline Find More Posts by Robertwav1
Old Jul 29, 2010, 03:00 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Yup, Belt is cheaper in crashes, They survive 90%+ of crashes that take out the boom.
TT will survive nearly 0% of crashes that take out the boom and often you have to replace the front or rear gears even at the slightest hit.
If boom slips at the front mounting block, the belt will slip.
Belt tightness is somethiing people sometimes struggle with.
EVery time I"ve thought I had a static problem, I found another reason for the issue.
I silicone spray my belt every 10-20 flights.
Melnic is offline Find More Posts by Melnic
Old Jul 29, 2010, 03:16 PM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
I'm a belt guy, I use dry graphite spray to lube my belts, you need to treat less using grahite but I still spray the belt most maintenance cycles...which is about 25 flites for me.
I'm not a very advanced pilot, flips, loops and rolls, for those I can't tell the difference between belt and TT, if I wack my TT gears I will likely buy the EXI belt conversion for my Pro ....then fix the TT for the next big crash
ewoodcox is online now Find More Posts by ewoodcox
Discussion Holy War: Torque Tube Vs. Belt Drive Tails Bukkene Bruse Mini Helis 115 May 18, 2010 02:33 PM
Poll T-Rex 500 belt vs tube drive Spidious Large Electric Helis 5 Jan 16, 2010 08:06 PM
Sold TRADE My Complete Trex 600 Torque Tube Tail For Your Belt Drive djdaveq Aircraft - Electric - Helis (FS/W) 7 Jul 28, 2009 12:15 PM
Poll Tail belts- to lube, or not to lube- that is the question / belt vs torque tube Gadget01 Electric Heli Talk 24 Dec 22, 2008 04:53 AM
Discussion Torque Tube Vs. Belt Drive tails... tailStrike Micro Helis 10 May 23, 2007 11:03 PM
