Old Sep 01, 2011, 09:51 PM
nese is offline
Find More Posts by nese
nese's Avatar
Joined Nov 2010
I needed a (very) large space. I practiced in a field about 200m x 100m after crashing it badly in my living room and had it zooming past me FFF before I could control it. Days of the cold sweaty palms - I'm glad those are behind me, except when I'm flying it in the living room :P
nese is offline Find More Posts by nese
Old Sep 02, 2011, 07:51 AM
HeliGriff is offline
Find More Posts by HeliGriff
my mental eXcape!
HeliGriff's Avatar
USA, Ohio, Catawba Island
Joined Jan 2011
You guys ROCK! It's nice to see your still out there flying the V's!
If anyone would suspect weight shift, it should be you. LOL! It was your Mod Dsobbe!
Good idea having a backup, BHicks. Along with my two V200's, I have twin 450's now! Ya gotta have backups to fly when parts are on order! Thanks, I'll try the 3.0A on the 1200 batt's.
I lost a tail blade like that, Nese. Not a pretty thing! I never found it As I mentioned, I learned to fly the V200 in a 25x25 room. That was very Expensive!!
Nese & Adrenahelin, I caught a power line last night with the 450. I should not have been out there with that size bird. Glad I have spare parts! Be back up tonight! I can see where a 120 would fit a backyard nicely. Hmm..
I've been practicing my video recording. Heli-cam onboard and video-glasses for me. I'll post some, as soon as get anything "worthy" of y'all!
Stay in touch!
HeliGriff is offline Find More Posts by HeliGriff
Old Sep 02, 2011, 01:50 PM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by HeliGriff View Post
Hey, you're still flying! Does the TRex 250 have a one-way bearing? I wish the V200 did. I've probably replaced 30+ gears since I bought it.
The Trex 250 do have a one way bearing. My main flying field is now a construction site and I have hardly flown my 250 and 450 since. I am now back into submicros and have been flying the MCPx and 4G6s lately. For some reason, I can't get my M120D01 to fly properly.
zadaw is online now Find More Posts by zadaw
Old Sep 03, 2011, 02:14 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
Does anyone know what's in the puffy batteries?
Is it just air inside the sealed battery case, or is it some toxic gas that's being generated?
I have 5 batteries that are about 4 months old, and they are all puffed out.
I'd like to punture the seal to let the gas out, but I'd like to know what's in there before I do.
Any battery experts out there?
clearprop88 is offline Find More Posts by clearprop88
Old Sep 03, 2011, 03:00 PM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
STOP!!!!!!!!!!!!! They are damaged and they WILL catch on fire!! That's not me saying this, it's the entire heli community! Puffy batteries mean fire! They have been run too low, or overcharged, or were junk to start with.
Old Sep 03, 2011, 08:33 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Lipo's if exposed to air will catch on fire. Even a new battery in a crash or dropped that breaks the seal will cause a fire. That's what I heard. Like HeliGriff says Stop !!!!!!!!!. it's time to buy new batteries.
Crash Survivor is offline Find More Posts by Crash Survivor
Old Sep 03, 2011, 10:32 PM
ChopperJack is offline
Find More Posts by ChopperJack
Moving Parts
ChopperJack's Avatar
United States, AR, Texarkana
Joined May 2011
Tail Drive Shaft Gears
Greetings all, I am wondering if anyone else has had the same experience as me with these gears. I try to keep a bunch of these in stock. I noticed about half my stock have different diameter shafts (the part where the washer and bearing fit).
Half the gears have a larger shaft that will not accommodate the washer or bearing. It is about 3.1 mm in diameter.
The other half seem to be correct with a shaft diameter of about 3 mm.
It appears I probably will not be able to use those larger diameter gears.
Has anyone else had this problem?
Thanks - Jack
ChopperJack is offline Find More Posts by ChopperJack
Old Sep 03, 2011, 11:19 PM
Moving Parts
Joined May 2011
I'm glad you brought this up because both my 4f200 batterries are puffy.
Old Sep 04, 2011, 08:06 AM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
Thanks - Jack
The main thing is to buy original replacement gears from a Walkera dealer. The worse thing is when dealers substitute parts for other parts. Xheli will do this. WowHobbies usually does not do that. I prefere getting my V200 parts from WowHobbies. Their shipping is quicker and cheaper too!
Another factor is, the Chinese tolerences are not as accurate as we'd like and you'll see differences now and then on extruded plastic parts.
As far as 3mm vs 3.1, it shouldn't make any difference, as long as the number of teeth and the diameter of the gear are the same. The pin should hold the 3.1mm on the shaft. The 3.1 gear will sound a little differently and not be as true, but I fly them with no problem whenever I get them.
Old Sep 04, 2011, 11:03 AM
Joined Apr 2011
Thanks for the feedback on batteries guys.
My guess is that there are going to be a lot of battery orders going out soon, me too.
The battery suppliers should give me a cut, lol.
I know that I have seen recommendations for cheaper batteries from past posts.
Any new ideas on good, cheap, batteries?
Old Sep 04, 2011, 11:13 AM
adrenahelin is offline
Find More Posts by adrenahelin
United States
Joined Mar 2011
what manufacturer are your lipos? I have a couple nano-tech 1000mah, 1300mah and a couple stock ones, so far so good but i haven't used them much.
adrenahelin is offline Find More Posts by adrenahelin
Old Sep 04, 2011, 11:59 AM
Joined Apr 2011
I have Walkera's, 1000mah, that came with the heli's. I don't use them much, so they're not pufffy. I use the GE 1200's from WOW, a lot, they are puffy. I have 1, STORM, 1200, I think it's from Helipal, it's puffy.
Where do you get the nano-tech's from?
Old Sep 04, 2011, 02:03 PM
United States
Joined Mar 2011
from HobbyKing:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
mine came with xt60 conn. though. i think someone posted recently that they liked the Gens Ace lipos. (lithium and hydrogen gas in contact with air causes the fire hazard)
http://www.ehow.com/facts_5594715_do...tch-fire_.html
some info here
fwiw, hk buddy price from classified section, post #847:
http://www.rcgroups.com/forums/showt...427400&page=57
Old Sep 04, 2011, 04:11 PM
Joined Apr 2011
from HobbyKing:
some info here
The "Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack", looks a little large for the V200 battery tray. Does it fit OK?
Thanks for the "ehow" link, that's what I was looking for.
HEY Y'ALL - LISTEN UP!!!
Check out this link.
Old Sep 04, 2011, 04:38 PM
United States
Joined Mar 2011
1000 2s nano's are 2 or 3 mm too long, can't quite close the door. I removed the front of the battery tray on one of my V200's. otherwise fit is good, actual size: 34mm W x 12mm H x 71mm L (best i could measure with a ruler)
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
