Old Aug 09, 2011, 08:17 AM
nese is offline
Find More Posts by nese
nese's Avatar
Joined Nov 2010
I like the V200. It's a really fun trainer and up to the task for the little experiments. My public holiday today is done so time to get my feet and skids back on the ground for a few days. Happy flying!
nese is offline Find More Posts by nese
Old Aug 09, 2011, 10:09 AM
HeliGriff is offline
Find More Posts by HeliGriff
my mental eXcape!
HeliGriff's Avatar
USA, Ohio, Catawba Island
Joined Jan 2011
Happy Holiday Nese!
HeliGriff is offline Find More Posts by HeliGriff
Old Aug 09, 2011, 12:02 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
[QUOTE=nese;18997320]
Originally Posted by HeliGriff View Post
Thanks in return. The point to note would be the obvious weight issue. This was probably my last helicam video with this camera since I could "feel" the strain on the motor and drivetrain. The gears thankfully survived this experiment including the crash in the short grass during the dry run Next time I'll use a HD keychain cam.
Would you post the info on the Helicam.
Where did you buy it?
clearprop88 is offline Find More Posts by clearprop88
Old Aug 09, 2011, 02:04 PM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
[QUOTE=clearprop88;18999429]
We need Nese' camera info. He has the correct configuration. I bought mine from xheli. It's actually designed to fit your shirt pocket. This was a bad choice because it must be verticle or at a 45 degree angle for heli use. But.. what do you expect for $22?
Nese is also correct about the weight being too much for the V200D01. Mine weighs much less than his and it is still too heavy for the V200D01. I'll use it on my 450 where it can mount verticle and the heli won't even know its there.
Old Aug 09, 2011, 04:56 PM
2dmatt is offline
Find More Posts by 2dmatt
I haveno idea what I am doing
2dmatt's Avatar
United States, SC, Lexington
Joined Jun 2011
The keychain cam wouldn't be a problem for the 200 would it?
2dmatt is offline Find More Posts by 2dmatt
Old Aug 09, 2011, 06:43 PM
dkb194 is offline
Find More Posts by dkb194
Canada, BC, Nanaimo E
Joined Dec 2010
Keychain Cam
I mounted my key chain cam and it is no problem. Even tried tape over the mic but still have to cut sound on playback. My cheap cam is 720x640. Can get a 1280x960 for under $20 shipped on ebay.
dkb194 is offline Find More Posts by dkb194
Old Aug 09, 2011, 08:03 PM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
Mine is the size of the keychain and it really made the heli fly horribly. Too much for a 200 size, in my opinion. Personally, I think it would be better to spend the money on Video Glasses so that you can watch your flights and use them for reference too. i like the idea of a heli-cam, but I'll put mine on a bigger bird.
Old Aug 10, 2011, 12:34 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
I just use the cheap sky glasses for my videos. They work best on cloudy days as the sun can make the colors flair. No need to put the mrs or kids in danger being your cameraman either.
Link- http://www.ebay.com.au/itm/720-x-480...item4aad7a2bad
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Aug 10, 2011, 08:33 AM
dsobbe is offline
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
For a long time I've been wondering how the V200's undercambered rotor blades effect handling. The 4F180's symmetrical blades seemed to be more stable and less effected by gusts. So, l bought a cheap set of symmetrical wood Trex 250 rotor blades here:
http://cgi.ebay.com/ws/eBayISAPI.dll...=320711958988&
ssPageName=ADME:L:OU:US:1123
and made a set of brass pitch plates to adapt the blades to the V200D01 hub (see photos). The pitch is 12 degrees. With the blade lengths trimmed to match the original blades I only lost one half square inch of blade area, total.
With these blades my V200 has similar handling characteristics to the 4F180. Gust stability is markedly improved and I can comfortably fly in stronger winds and rougher air. Control response is unchanged from the undercambered blades. At hover RPM the current draw is lower and both the motor and ESC run much cooler. Like the 4F180, there is some lag in throttle response and I do have to lead throttle inputs a little. Rate of climb is less than the undercambered blades. I should be able to get better climb rates with slightly wider blades and lower pitch. All of these changes are characteristic of symmetrical airfoils. But, so far, all are good.
This is a work in progress. I may replace the rotor head with a 4F180 head with two blades. Then, I can do away with the pitch plates and be able to easily adjust blade pitch. Or, if I can find a two blade fixed pitch head I'll use that. Anyone have a suggestion?
dsobbe is offline Find More Posts by dsobbe
Old Aug 10, 2011, 07:42 PM
Joined Apr 2011
Take a look at the M200D01 2 blade head.
It looks like a 2 blade version of the 4F180.
Old Aug 10, 2011, 08:36 PM
dsobbe is offline
Joined Jan 2011
Thanks for the info, clearprop88.
You're right. It is a two blade version of the 4F180 head. Looks like I made my own m200 head. From that experiment I can tell you that I will definitely be putting one on my V200D01.
Old Aug 10, 2011, 09:28 PM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
Keep it up Dsobbe and you'll have it flying 3D!
Old Aug 10, 2011, 10:09 PM
Bravo47 is offline
Australia
Joined Jun 2010
Its a shame Walkera dont offer the separate complete heads as upgrade options like they did with the 4#6Bell. Ive done some piece meal head conversions in the past, and general the cost blows out with buying everything separate. Offering "bare bones" heli's for spares with Walkera stuff would also be popular I think.
Mick
Old Aug 11, 2011, 07:45 AM
dsobbe is offline
Joined Jan 2011
Mick
I fully agree. Forgetting the extra blades, which are fluff, the only difference between the V200D01 and 4F180 is basically the rotor head.
Of course, from a marketing point of view it makes perfect sense. The swashplate mounting and rotor head on the V200D01 is very tough; a necessity for a basic starter helicopter. If you could easily and cheaply replace the rotor head to give it sport flying capability a lot of 4F180 and M200D01 sales would be lost. Same thing with cars. More cup holders and electronic fluff for much more money.
It's all about the E. Ego and Economics.
Old Aug 11, 2011, 12:44 PM
2dmatt is offline
2dmatt's Avatar
Joined Jun 2011
This thread has officially gone above my paygrade.
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
