Old Jul 29, 2011, 11:47 PM
nese is offline
Find More Posts by nese
nese's Avatar
Joined Nov 2010
Here it is
nese is offline Find More Posts by nese
Old Jul 30, 2011, 07:01 AM
HeliGriff is offline
Find More Posts by HeliGriff
my mental eXcape!
HeliGriff's Avatar
USA, Ohio, Catawba Island
Joined Jan 2011
Originally Posted by nese View Post
Here it is
Got enough heli to get that equipment off the ground?
HeliGriff is offline Find More Posts by HeliGriff
Old Jul 30, 2011, 12:30 PM
dsobbe is offline
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
Anyone know where I can get an Exceed Classima 300 canopy?
dsobbe is offline Find More Posts by dsobbe
Old Jul 30, 2011, 01:27 PM
dkb194 is offline
Find More Posts by dkb194
Canada, BC, Nanaimo E
Joined Dec 2010
Nese: Is the fuel gauge just to tell you actual volts of the battery so you can fly till 3.7x2=7.4???
dkb194 is offline Find More Posts by dkb194
Old Jul 30, 2011, 02:24 PM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
I have one. $1,000,000.00
Seriously, xheli took away the Classima 300 Replacement Parts webpage. However, they will "special order" any original Classima parts. If for some reason you can't get one, I'll let you have mine, for sure. Let me know.
Old Jul 30, 2011, 03:45 PM
dsobbe is offline
Joined Jan 2011
Sorry, but I won't pay less than 10,000,000.00
I'll check out Xheli. I want to replace the canopy on my 4F180. It's too dark to stand out at a distance. Besides, the color scheme looks like it was picked out by a Chinese restraunt decorator.
Thanks for the offer. I appreciate it and will keep it in mind.
Old Jul 30, 2011, 08:14 PM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
Originally Posted by adrenahelin View Post
0.3 mod according to post #50, pg4 of this thread.
Ah! thankyou!...Now It's a matter of finding them to buy somewhere. I found a UK store with exactly what I'm looking for but they don't ship to the US, sent a email to see if they can make an exception.
candy76man is offline Find More Posts by candy76man
Old Jul 30, 2011, 09:13 PM
2dmatt is offline
Find More Posts by 2dmatt
I haveno idea what I am doing
2dmatt's Avatar
United States, SC, Lexington
Joined Jun 2011
If anyone needs lipos, i just ordered a couple of these from HK, price code good 14 days from 7/29:
http://www.hobbyking.com/buddy.asp?c...0-761D118CD52C
I have a 1300 mah but seems a little heavy, (86 gr. versus 53gr.) so i'll try these.
Thanks for the link I picked up a coupla those.
2dmatt is offline Find More Posts by 2dmatt
Old Jul 30, 2011, 10:01 PM
nese is offline
nese's Avatar
Joined Nov 2010
Oh yes. Plenty... depending on how its flown . Here's a video I took of my V200 - Fully Loaded, lights switched off, except for the front pilot light which is always on
There are 3 set points for voltage alarms: Level 1 (I set this at 3.7V per cell), Level 2 (set at 3.6V per cell) and total voltage (set at 7 V).
Y'know I actually forgot to remove the old voltage indicator that still stuck to the back.
My V200D01 with telemetery flying outdoors in the wind (1 min 21 sec)
Just trying to see whether it can be done.
Old Jul 30, 2011, 10:08 PM
nese is offline
nese's Avatar
Joined Nov 2010
And yes, there was wind from my left and behind me. The mic that's next to my face picked this up especially at he start of the video and there were some flags behind me (not in the video) that were flying about 40-50%. I'd say it was ranging about 2-4m/s wind with gusts changing direction. The sleeve mod works well - thanks guys!
Old Jul 30, 2011, 11:02 PM
my mental eXcape!
HeliGriff's Avatar
Joined Jan 2011
http://www.youtube.com/watch?v=tleQlswE_Yk
Very nice! I like the equipment! I could have used that today when I forgot my timer!
Even more, I like seeing all the nose-in & lazy piros. It really helps when you have to recover from disorientaion!
I had my V200 out today and got it all spun around at quite a distance away. It was going down sideways. First, I had to spin it just to tell which way it was pointing so I could recover. I saw some yellow come into view and was then able to correct, quite nicely I might add! I couldn't have done that without all the hours I've spent practicing that very thing.
Thanks for the video!
Old Jul 30, 2011, 11:28 PM
adrenahelin is offline
Find More Posts by adrenahelin
United States
Joined Mar 2011
good luck with your upgrade, I thought i had a bookmark for a pinion supplier but don't have it here, i'll check my work computer.
thanks for using the code!
nice setup nese, i haven't gotten to the mod yet. what lights are you using? i got some of these in blue and white, sort of a strobe effect.
http://www.hobbyking.com/hobbyking/s...dProduct=17194
adrenahelin is offline Find More Posts by adrenahelin
Old Jul 31, 2011, 02:22 AM
nese is offline
nese's Avatar
Joined Nov 2010
Kinda, yeah. But you know how the voltage dips and then "bounces" back up when the load is removed. Different batteries behave differently but I think it gives me an idea when a particular cell in a battery is giving in. I flew today for about 6-8 mins a pack before I got the second alarm (i.e. one of the cells reached 3.6V). When I got back to charge them on my B6 charges I got about 830+mAh on the stock 1000mAh batteries so that's about the 80% mark.
Of course when you look at it all it's quite an overkill as a timer or a voltage indicator would have sufficed. I'm just loading the V. Then there is the optional kit allows temp and current readings to be sent back to the screen unit, but I think practically it would add too much weight. Anyways, I bought this from hobby king. http://www.hobbyking.com/hobbyking/s...mp_mAh_V2.html
and added on the flexible antenna to lighten the load.
Old Jul 31, 2011, 02:42 AM
nese is offline
nese's Avatar
Joined Nov 2010
[url
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17194[/url]
I built mine from scratch after amassing all these materials over the last couple of months or so - servo extension cables from ebay and from local electronics stores around town like these LEDs, connectors, mini switches, really thin wires and and some resistors.
Other than bling I was going for basic functionality of landing and navigation lights - to help me with orientation and take-off/landing when the field is dark. The conventional green and red for the different sides help me confirm which way it's pointing (right or left) and 2 bright white lights means its headed back at me.
LEDs these days are quite bright. My wife says the only thing she sees when she looks at the dark field is my heli, and she can see it land on the bald patch on the field
Old Jul 31, 2011, 02:46 AM
alexaglob is offline
Find More Posts by alexaglob
alexaglob's Avatar
Joined Nov 2010
If anyone interested these flash leds with wires http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT have wide range of voltage, i tested 3.7V-12V. No resistors required.
alexaglob is offline Find More Posts by alexaglob
Discussion V200D01 Walkera 200 size FBL FP, yep another newy! Ampdraw Micro Helis 143 Apr 23, 2011 01:42 AM
Mini-Review Walkera UFLY helicopter mini review ehirobo Micro Helis 8 Jan 16, 2011 08:21 PM
Discussion NE Free Spirit or Walkera V200D01 JHawk19 Micro Helis 11 Jul 19, 2010 11:53 PM
Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) Z06 Tony Micro Helis 0 Jun 25, 2010 09:34 AM
Discussion Walkera 52#1 Mini Review Swilson50 Micro Helis 0 Apr 05, 2007 12:19 AM
