United States, CT
Joined Mar 2011
If anyone needs lipos, i just ordered a couple of these from HK, price code good 14 days from 7/29:
http://www.hobbyking.com/buddy.asp?c...0-761D118CD52C I have a 1300 mah but seems a little heavy, (86 gr. versus 53gr.) so i'll try these. |
Canada, BC, Nanaimo E
Joined Dec 2010
I have been using one of these for 3 months and they are good. Unless you cut open the battery compartment at the front you will not be able to close the battery lid as they are 5mm too long. I just fly with the lid open. The leads are heavy gauge wire as well.
Tampa,FL
Joined Dec 2003
Tampa,FL
Joined Dec 2003
United States, CT
Joined Mar 2011
Tampa,FL
Joined Dec 2003
....along with a few slightly larger motors to try and get a little more power in my 4f180. I may have to drill out the pinion a bit to get it to press on but they were cheap enough that it's no great loss if none of them work. keeping fingers crossed![]() Anyone know what pitch the main gear is in the v200/4f180? It's smaller the 0.4 mod because that's what I thought it was and purchased some gears in that size but no luck...I emailed wowhobbies and they don't know, I also emailed Walkera but I'll be suprised if they respond at all. I can't find any gears with a smaller pitch than mod.4 online anywhere either...why couldn't Walkera have used .4 mod gears? I think it would have reduced the main gear stripping if you breath on it too hard issue and would still have been nice and quite running. |
Joined Dec 2010
V200 D01 - tail servo
I've been having a problem that when I bind I'm having to give more and more right rudder trim as when you move the rudder it just keeps going. Is this because of a memory problem because I've been shutting off my 2801Pro before I unplug the battery on the Helicopter. If so how do you get it that at 0 trim the rudder will hold where you move it when you are bound and still sitting on the ground. Is there a way to reset it?
Also, make sure that all your TRIMS are set to 50% BEFORE powering off the TX. Each time you power-up with left-over trim, the servo thinks that the old setting is nuetral (center). Eventually the servo will reach the end of the half-gear and lock-up. Servos on the V200D01 often return to center when you let go of the stick when stationary (on the ground). But in the "air" it is different, especially for the rudder. It will (should) stay locked on the last input position. Recently, I had a rudder servo that seemed to keep moving. As it turned out, the Tail Steering Set had gotten bent a little. Once I replaced it, everything was fine. The servo was just working against the resistance of the bad part. Finally, if your Rudder Servo Extend is set too high, the servo will keep trying to move, but has no more physical travel. Adjust Servo Extends so that the servo stops when the Tail Steering Set reaches it's limits at the end of each shaft. Hopefully, the servo has not been damaged (bad gear) that is making it run all the time. So, the bottom line is that it could any of the above. Hope this helps! |
Joined Nov 2010
Yes! I've flown with the sleeve mod... and glad to report that everyone has been right. It makes it more stable and controllable in the wind and it does fly like a bigger heli. It doesn't totally eliminate pitch ups but it does reduce it's tendencies and extent significantly. I increased ail gain about 15-20 percent without wobble in the wind. Bravo once again to the developers of this mod
![]() Btw I also like this mod because it is removable and maybe even transferable. |
United States, CT
Joined Mar 2011
| Thread Tools | |
| Discussion V200D01 Walkera 200 size FBL FP, yep another newy! | Ampdraw | Micro Helis | 143 | Apr 23, 2011 01:42 AM |
| Mini-Review Walkera UFLY helicopter mini review | ehirobo | Micro Helis | 8 | Jan 16, 2011 08:21 PM |
| Discussion NE Free Spirit or Walkera V200D01 | JHawk19 | Micro Helis | 11 | Jul 19, 2010 11:53 PM |
| Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) | Z06 Tony | Micro Helis | 0 | Jun 25, 2010 09:34 AM |
| Discussion Walkera 52#1 Mini Review | Swilson50 | Micro Helis | 0 | Apr 05, 2007 12:19 AM |
