Australia
Joined Jun 2010
The antenia wire just looks like a bit of servo wire to me, but i could be wrong. Mick |
Chicago, Illinois
Joined Jan 2011
The decreased range was most likely caused by the missing antenna. 10mw radios have roughly a 700 foot range. That's about a city block. But, with the Rx antenna missing I'm surprised that you had any range at all. I assume you're talking about the Rx antenna on your V200. If so, the antenna is just a 1-1/2" length of stranded hook up wire. The wire size (diameter) isn't important. But, the length is. The missing antenna was soldered into a land (hole) in the front corner of the bottom circuit board on the Rx. There may still be some white silcon rubber over the hole. If you know how to solder and have a low power (35 watt) pencil point soldering iron you can replace the antenna yourself. Find a piece of stranded wire, not solid wire, and cut it to length. Scrap any silicon off the circuit board, unsolder any remaining piece of the old antenna and solder in the new one. Then, put a small blob of RTV (bathtub caulking) on the wire and board. It will protect the wire from sharp bends that could cause it to break easily. |
Joined Nov 2010
HeliGriff, there's a thread I've been following for my FPV ambitions (http://www.rcgroups.com/forums/showthread.php?t=1159968) that has detailed info about the radio part of things.
In short it's good to note that the length of the antenna is quite important and ideally should be matched to the exact frequency used. Since the Walkera system fixes onto any frequency in the 2.4G band there is this 'rough' length that is used. The one on my V200 rx is 40mm and what looks like 24-26 AWG wire. Wire lengths should vary thereabouts. |
Joined Nov 2010
Just curious, anyone lost range with their Walkeras before? What about glitches? |
Tampa,FL
Joined Dec 2003
Joined Nov 2010
I haven't flown my Walkerized King3 that far yet, but this inspires confidence.
I think as far as visible distance is concerned the 2801pro is more than enough to cope since I've read that its max range is about 3000ft - and that's way beyond what I can see. But what about the 2402 or 2403 that comes with the v200? |
Tampa,FL
Joined Dec 2003
I have a 2402 and 2603 and never had any issues with those either . I don't use them anymore since I got the 2801pro though which works with any Walkera rx. I think the range on any of them is going to be much farther than anyone could see to actually fly.
Joined Nov 2010
Today was a good day. I managed to find an art shop that had aluminum tubes with a 4mm lumen - an ART shop. They also had a small tube cutter so I've got my top sleeve all done up and installed - all 6.3mm of it. I've tried hovering it in my living room and found I needed to adjust the ail gyro but that's all the time I had today - it took me a good 3 hours since I had to bevel the edge closest to the swashplace to prevent it from getting in the way just as HeliGriff had done.
I'll take it out tomorrow and see if there's any effect on the bucking. I think I'll be spending some time re-adjusting those pots too. |
| Thread Tools | |
| Discussion V200D01 Walkera 200 size FBL FP, yep another newy! | Ampdraw | Micro Helis | 143 | Apr 23, 2011 01:42 AM |
| Mini-Review Walkera UFLY helicopter mini review | ehirobo | Micro Helis | 8 | Jan 16, 2011 08:21 PM |
| Discussion NE Free Spirit or Walkera V200D01 | JHawk19 | Micro Helis | 11 | Jul 19, 2010 11:53 PM |
| Discussion SNEAK PEAK Walkera 7.4v 2S Flybarless 4#6 (V200D01) | Z06 Tony | Micro Helis | 0 | Jun 25, 2010 09:34 AM |
| Discussion Walkera 52#1 Mini Review | Swilson50 | Micro Helis | 0 | Apr 05, 2007 12:19 AM |
